Mr Punter
Sometime the rubber seals can get dislodged during fitting. If you have a multi tool you can neatly and easily cut into the pipe and use a band seal coupler to repair.
I had some full fill Celotex (now withdrawn) boards fitted. Some were upside down / cut badly round openings / back to front. Bricklayers can be decent at brick / blockwork but mostly the insulation just gets in their way.
I am considering blown EPS beads for a new build with brick outer, 140mm cavity and plastered blockwork inner. Rigid board insulation is often prone to lashups, with gaps between boards, at corners and around openings, as well as damage on site.
Looks a bit cleaner than earlier. The pocket door looks promising (and expensive).
First post - back of house extension & reconfiguration
Mr Punter replied to JK1983's topic in Introduce Yourself
It would be a big job to replace the suspended timber floor with a suspended concrete floor. Probably easiest with concrete beam and block but will need insulation, then your concrete topping. Allow 150 depth for the beams, 100 for insulation and 75 --100 for the concrete topping. The new bit of floor could be ground bearing if you are not on clay. -
Please review my foundation/floor/wall junction detailing
Mr Punter replied to Hilldes's topic in Foundations
140mm wide blocks are widely available. -
Also, make the supporting block and Marmox 140mm so it supports the whole of the soleplate as it is currently straddling 3 materials which are unlikely to be completely level with each other. -
Cavity tray and weep holes. Holding down details for sole plate. What size is the block under the Marmox? I would want something factory sized here, not cut with a bolster. -
I am also bored of grey. I have gone for black on the current property and will do white on the next development. Colours can look really crappy unless very carefully selected and muted.
S3 is the slump. The higher the number the runnier the mix. This sounds a good system. Do you mesh the concrete? Is it 75mm?
I would prefer contractors to read / look at install instructions rather than wing it, which a lot do. I once had some chippies install expensive cement cladding. They decided on a 155mm lap although it should have been 180mm. Cost me an extra £1,800 and some of the junctions looked crap.
Glass gable ends. Looking for examples..
Mr Punter replied to Olly P's topic in General Self Build & DIY Discussion
Good luck with the curtains and blinds! -
Shared Driveway Access Issues
Mr Punter replied to mediumbuild's topic in House Extensions & Conservatories
If they sued for breach of covenant they would need to establish their losses, which would be minimal. It would cost them a fortune to get to court and they would probably lose. -
Be good to get him to detail the pricing eg prelims, foundations, demolition, brick / blockwork, floor, roof structure, roof covering, elecs, plumbing, plastering, carpentry, kitchen fitting, decoration and tiling. You can easily see how much of each is complete and pay accordingly.
Is the staircase open to the rooms below or does it lead to a hallway, with doors?
Are the opening windows the IdealCombi tilt / turns? Do you need to turn the key to get the window into turn mode? If so, they will not be suitable and I do not think they can be easily adapted.
They normally ask for a fire door between house and garage. You can see why I guess. Make sure the frame is the right spec as well.
Where to run services - Vaulted Roof
Mr Punter replied to NewToAllOfThis's topic in Roofing, Tiling & Slating
No there should be no condensation in the gap, although it is common to have some thinner insulation under the rafters to prevent cold bridging. -
Yes, enough for a waste pipe. Also space under units.
What is the daily rate for a roof slater?
Mr Punter replied to epsilonGreedy's topic in Roofing, Tiling & Slating
Where we are almost all the roofers use the same lead man. He is very reasonable and does really neat welding etc. I sometimes ask the roofers to exclude the cost of any specialist leadwork. If they get the job they liaise with him and he bills me. They still do soakers etc. -
Stairs - Concrete vs timber
Mr Punter replied to Conor's topic in General Self Build & DIY Discussion
The upside is no string - if you like the minimalist look. These took ages to finish compared to a timber staircase but like you we had Bison in to do the floors so it was one less thing to consider and straight away we had safe access between floors. -
Yes the concrete stairs are expensive. I have clad them in timber before and extra for glass balustraded and stainless handrail. Also lining up treads with floor finishes can be tricky. You often have to screed the hollowcore to take out the camber, as well as batten the underside for plasterboard. Carpeted timber stairs are practical and inexpensive. -
The architect on my scheme has put in a pocket door. So annoying, especially as the rest of that level is done in blockwork. AHHH!!! I think I will just leave an opening if BC accept it. It is second only to curved walls as an expensive ball-ache.
