Mr Punter
Building a large balcony; where to start
Mr Punter replied to New to this's topic in RSJs, Lintels & Steelwork
I have a more recent timber balcony on a property and I think it is around 20 years old. I need to replace it as it is rotten. I will use galv steel. Most of the original Victorian external joinery on the building is in reasonable condition. I think the quality and durability of softwood has declined considerably. -
The first one looks easier to paint and keep clean. Do you fix them concealed at the top?
Show us yer shuttering...
Mr Punter replied to Mulberry View's topic in General Self Build & DIY Discussion
You can take them all off now or leave them for a year. Makes no difference. -
That applies to Scotland. In England there is nothing to stop you moving in.
You need to move it inboard a bit. If it comes in 30mm and you seal it to the timber stud you will prevent any outside air getting behind the reveal plasterboard and into the service cavity.
Internal doors - standard sizes v making bespoke
Mr Punter replied to Tom's topic in Doors & Door Frames
Yes, you are making things difficult. Birch veneer doors are widely available and with an excellent finish at reasonable cost. You could use birch ply for the linings, stops and architraves. -
Submitting Objections- templates / best practice
Mr Punter replied to Conor's topic in Planning Permission
Only raise points that will impact you. Drop the bit about the sewer proximity and FFLs. The balcony and windows will compromise your enjoyment of your private garden. The size, location and massing appear oppressive. You will lose natural light into your garden, kitchen or whatever. @Tony K is a planner and may (or not) be able to offer proper advice. -
If you have an estate house built pre 1990, there is a good chance the lean-to garden room will be better insulated than the rest of the house.
You need sharp sand for bedding. The particles lock together.
Is this going to be an overdepth worktop to get into the cill or is it one where they can invisibly fabricate a bit a the back?
You may need some slightly finer material to spread on the lower areas. If there are high bits you may need to scratch out some material before you run over it again.
Do you really want a worktop that high? 900mm - 920mm is fairly standard. You could just do the cill with the same material at a higher level.
The trouble is lack of availability. Where can you easily buy this? Is there an actual stockist in the UK? Also, to get this to work it would need to be fitted at the same time as the steels or slipped underneath. Normally I just see the base plates shimmed with steel and filled under with structural grout.
I know someone who has a similar Right of Way over her property but it not abused by the neighbours who benefit from it. I am afraid there may be little you can do. If the Right was not made clear to you when you bought the property you MAY have a claim against your conveyancer or the seller, but after 28 years I very much doubt it.
In a new build you normally only need level access in the main entrance. There is a lot wrong with your patio door install and I would have been surprised if you did not get water ingress.
UVC in basement plant room but no drainage for overflow
Mr Punter replied to Thorfun's topic in Boilers & Hot Water Tanks
Is there anywhere on the ground floor you could site the UVC? It would mean hot water gets to showers and taps quicker. -
A site plan would be useful. I think it may be best to have it much more level, then steps down to the front door. You will probably need a retaining wall.
Cemfloor does not require grinding to remove laitance before tiling which is a saving of time and money.
I have used strand woven bamboo stuck down to 22mm chipboard decking, It gave a really solid feel. It is difficult to cut, especially with a jigsaw as the tough strands make the blade wander.
Some advice on how to proceed self build
Mr Punter replied to Paul Alan's topic in General Self Build & DIY Discussion
You need to block it off straight away. You could just fit a dirgo on it for the time being if the basin / shower are not draining properly, but allowing sewer gasses in where people are living is very dangerous. Some houses only have dirgos and do not have an external vent pipe. -
It looks like you are making decent progress. You could get Building Control to visist just to confirm that they are happy to date. Can you get the whole thing watertight? Very neat housing of joists into the wall btw.
