Mr Punter
Just when I thought I’d seen it all.
Mr Punter replied to Canski's topic in House Extensions & Conservatories
I often see plumbers who drill from the inside. No pilot or careful drilling, just straight through for an overflow, condense or blow off pipe, spalling the brick face or render as they go. -
I think it may be better with 75mm x 50mm vertical at max 600 ctrs fixed with screws, then 25mm x 50mm horizontal fixed wiith Paslode nails. You will use less timber and the horizontals will be less prone to twisting off. Another vote for slate hooks as they are more secure and no chattering in the wind.
That does look very impressive. Could your average sparky, tacker, plasterer and decorator achieve this without messing up and blaming each other?
The links you posted seemed to be from vested interests so I take them with a pinch. I have a WC on the top (fourth) floor of my house. It has PIR in the roof and walls but no window. South facing wall. The door connecting to the landing is normally closed. In spite of it being baking elsewhere in the house, the top floor WC has remained pretty stable. Anywhere with a window (which are triple glazed), even when the sun is not on them, gets considerable heat gain. I also have a similar space but below a sloping roof with PIR and it is used to house the boiler. It is always fairly warm but not noticably more so in the hot weather. I really don't think that PIR is the cause of your troubles. More likely solar gain.
I don't think this really backs up your claim that PIR makes a building "sweaty in summer". I appreciate that it does not have the decrement delay of some materials such as woodfibre or cellulose, but plasterboard can have a similar buffering effect. Regarding breathability, many modern buildups include a vapour resistant plastic layer. Cold stores and freezer rooms often use PIR as thermal insulation.
In-Ceiling Height Norm for Flats
Mr Punter replied to Jack O's topic in New House & Self Build Design
Also, you cannot always cut out plasterboard. It could serve as fireproofing or soundproofing. -
Are all the trusses on now? The span looks quite big. I think you will have to wait for Monday for it to cool down.
I thought it was flexi insulation?
If it were me I would make the 2 x 2s a bit longer and nail them into the sides of the rafters.
I still don't get it. The bit with the motor is normally inside. Was this just a plastic vent, or a fully wired in mechanical extract? -
Could you lay the bricks on the lintel and neatly point them, wait for them to go off then lift the whole thing into place?
It looks like solid walls as well. If you could do the whole block with external wall insulation and take it around the balcony it could work well with no loss of floor space, ceiling height or internal disruption.
The end ridge tiles are often mortered at the ends and have a hole drilled through the top with a stainless steel screw fixing to keep it in place.
Yoiu could get single leaf lintels. They will be properly designed for given load capacities and shoud be galvanised.
Tell me about Liebherr fridges
Mr Punter replied to Radian's topic in Kitchen & Household Appliances
I have had a freestanding Liebherr fridge freezer. The only problem was the door handles broke and needed replacing, othwise very good. -
Silicone render at night with lights on. Is this normal?
Mr Punter replied to Piggybagpop's topic in Plastering & Rendering
It looks like it has been applied by a with the back of a shovel. Was the substrate reasonably flat? -
I am not sure what the point is. I ca see a hole in the outer leaf of a wall and a lintel or floor plank where it looks like someone has tried to core through? -
If this is for 5 properties, could the cost be shared? You may mitigate a fair bit if you can get consent from whoever owns the verge.
Air Source Heat Pump in Stone House
Mr Punter replied to Bemak's topic in Ground Source Heat Pumps (GSHP)
If the walls are dry and properly pointed they will have a bit of thermal resistance anyway. The floors, roof and windows also play a big role in thermal efficiency. You can use a heat pump but if the house is poorly insulated and not fairly airtight it will cost a fortune to run. -
Oak beam versus steel/concrete lintel strength comparison
Mr Punter replied to jfb's topic in RSJs, Lintels & Steelwork
The UC will be a bit lighter than even 1 concrete. Cost may be similar. I can't help on the oak. SEs like softwood with a known strength grade. I was surprised when an engineer recently specified 3 ply 220 x 45 C24 to support a loadbearing wall 1.5m span. -
The door threshold will sit on the masonry or a cill, which in turn will be on the masonry. Make sure that your internal finished floor level is lower than any inward opening doors. Sometimes, with a bit too much screed, some timber flooring and some miscalculations and there can be quite a workaround.
Make a frame using 2"x2". Cut 2 lengths at 290mm and 2 at 360mm. Fix the longer pieces to the ends of the shorter ones with 80mm screws. Offset the frame with a couple of blocks and pour the grout slowly into the offset bit until you can see it coming out all round. Take the frame off the next day. Should look like this:
