Mr Punter
Nearly there and balcony pics
Mr Punter replied to Happy Valley's topic in General Self Build & DIY Discussion
It looks very good. Personally I don't like clear frameless glass balustrading as it makes the occupant feel exposed and it is not comfortable to lean on. Lift and slide door, views over the village and the struck pointing are 10 / 10. -
ICF and Foundation design
Mr Punter replied to Renegade105's topic in Insulated Concrete Formwork (ICF)
We have some 600w x 900d ground beams with a huge amount of reinforcing on 25m deep 300mm dia piles. Total overkill but we were too far forward with the SE to change and the project was complicated. -
ICF feasibility without a Concrete Boom pump
Mr Punter replied to Mrbehr's topic in Insulated Concrete Formwork (ICF)
I think stick built timber frame may be the most viable option. Hopefully you have sorted the emergency fire access arrangements. -
Flight by name and by nature it would seem.
Yes I have had this. Extra costs were less than 5%. It was for during construction fire risk. Some floor decks were fire resistant and some wall had Fermacell sheathing. The TF supplier did all the calcs. The project was a terrace with brick and block ground floor and timber frame above, max 4 storeys. The fire engineering compartmentalises the space to reduce the radiant heat to adjacent buildings. The end units had a double layer of Fermacell on the outside walls. There are lots of ways to engineer this. We just had normal JJI joists but the FR Caber flooring.
If the ground under the floor is firm and inert you are better off with a bit more insulation and less hardcore. Blue bricks are sometimes used instead / as well as a DPC. You probably want you finished floor similar to the existing so internal doors and external thresholds are the same.
You don't want the water to weigh so much it pulls the gutter / facsia off. It can be a bit annoying if it gets used as a bird bath when you are underneath.
Convert poor cold roof to warm roof with annoying pipe
Mr Punter replied to glennpierce's topic in Flat Roofs
Really? I normally see joists, osb, firrings, OSB, vapour barrier, insulation, osb, waterproofing. How would you lap the vb around the joist ends or wall ledger if it is lapped down? -
A bee brick and six swift bricks in Brighton.
New build design & cost estimation opinions
Mr Punter replied to morgan_22's topic in Costing & Estimating
I don't see an allowance for a sprinkler system, which are mandatory in Wales and would be advised anyway as you have a staircase open to the kitchen. -
I think the panes have lots of barely visible spacers to keep them apart.
If the porch is not wider than the window above, you don't really need to worry about weep holes as there is not enough blockwork to cause an issue.
12 Meter Test Sidewall to Main Elevation Query
Mr Punter replied to Hawkwind1879's topic in Planning Permission
I have not heard of a 12 metre rule. What does it relate to? -
I guess it is just much less work to fit everything from new.
It seems a shame to demolish and build from scratch but the current building does not give you much option unless you slice off the right hand end, refurb and build plot 2 relocated slightly. I have never found that replacing 1 with 2 works out moneywise but you must have done your sums. Be careful regarding CGT, CIS, VAT and CDM.
I think that is part of the pattern. Have a look at their gallery and there are a few examples similar.
silent gliss recessed curtain track
Mr Punter replied to gravelrash's topic in General Self Build & DIY Discussion
I have not used this system but they specify fixing centres for all the tracks. -
Lots of self build plots seem to be priced at GDV minus build cost with no profit or contingencies. If you can get £280k, sell the plot.
- 11 replies
- build costs
- selling plot
Self Levelling Pedestals for Pavers
Mr Punter replied to PeteP's topic in Landscaping, Decking & Patios
I have 600 x 600 20mm porcelain on adjustable pedastals. I think some brands have the head of the pedastal self levelling. -
I have a project in Brighton and we are using a light grey brick. The standard building sand around here is from Nutfield quarry and is dark orange. When it is made into mortar it ends up drying to a buff / beige colour and looks awful with the brick. I tried adding some black dye to the mix but the mortar just looks like cow dung. I can get hold of rendering sand that is OK for colour but not good for mortar. I have tried a few builders merchants without success. I am after bulk bags, delivered with a hiab. Any ideas?
+1 The pile and ground beam design need to be done by an engineer. -
Maybe an instant electric water heater? You could use the 12kW system boiler for heat only.
The mortar colour is important here. Do a test and leave it a week to make sure it matches. Just take out the damaged bricks and the mortar joins. It will take a while but it won't make anything unstable.
