Mr Punter
Prices of building materials moving forwards
Mr Punter replied to James Frome's topic in Costing & Estimating
In May I was paying £6.50 a meter for 9 x 2 joists. Now £4.60. (Plus VAT) I am still probably being ripped off but it is less painful. -
Plumbing is not my thing but those fittings look like they are in the wrong orientation. I looks like you are doing a below ground design but with above ground fittings.
Those scratches could have been made during manufacture of installation and only apparent after cleaning. We have lots of scratched panes on the larger windows, probably caused by fitters lying them down / dragging them around to install. Only noticeable in certain light but I am OK to ignore it. A development near me had loads of scratched glass and I think the installer ended up going bust. They are very difficult to remove.
I have only used it for the inner leaf of blockwork and it works out about £16 per linear metre. I guess for a 300mm sole plate it would be triple.
Preparing for an air tight test
Mr Punter replied to Happy Valley's topic in General Self Build & DIY Discussion
Double v triple glazing will make no difference to air tightness. Just how well sealed they are. You could still get brilliant airtightness with single glazing. Cold and condensation would be an issue though! -
A course of Marmox Thermoblock or Foamglas Perinsul blocks under the sole plate should largely eliminate the cold bridge.
You may be best getting someone local. Are you an agency?
Yes, I have had 3 of these. The first was 16 years ago for a single house and was done by the local archaeological group in return for a £100 donation. They now insist on so-called professionals to undertake the work. The latest was for a terrace of 7 houses and cost £800 for the WSI and £3000 for the watching brief and report. What a waste of money, but no choice. You can also get extras on your bill from the groundworkers if they hold things up.
But the holes only have about 10mm of material under to stop it levering off the wall. Send a photo when it is fitted.
The mounting holes on the sink are much too low down. It does not look like it will work wall mounted. Maybe it is for a pedestal or countertop.
Skimming would save a load of hassle.
Because the condition did not further specify that the property must maintain the rate of consumption indefinitely there is nothing to prevent a future owner from putting in whatever appliances they like.
- 20 replies
- building regs
- water consumption
I am doing a 150mm cavity with beads on a project. The brickwork is getting a coat of StormDry. I will watch the bead installer to make sure they have got to all the voids. I may suggest to them that we will use a thermal image camera on completion.
I found the manual fairly straightforward but lowered the normal airflow percentage to 20%. Is yours at 30%? Have you tried holding down the boost button for 5 secs to put it into purge mode 100%? Do it a second time to switch back to normal.
- 1 reply
I have also known black pipe used for pumped drainage. You did well not to damage it. If it is in the road I would definitely want some reinforcement above. Try to get the utility firm to do it to their spec and cost.
I did a development and the ground was clay. Did a French drain to an old well and pumped to a ditch at the top of the drive.
With the pound being so strong against the dollar why don't you just buy it you tight git? With duty, VAT and shipping you will still see change from £10k. You really can't put a price on a longhorn motif lampshade!
Neighbour selling without Planning Permission
Mr Punter replied to Becks1974's topic in Planning Permission
If the raised patio causes any overlooking or loss of enjoyment to your outside amenity area, report it to the council. They often have target response times for planning enforcement and tend to be keen to meet them. -
Floor loading understanding check please (long(ish) & maths content)
Mr Punter replied to dnb's topic in Boffin's Corner
Often the floor calcs will include the allowable line loads for parallel and transverse to the joists. Meant for partitions but I guess would work for bookcases. -
All quiet at the builders merchants
Mr Punter replied to nod's topic in General Self Build & DIY Discussion
I have been messed about by bricklayers who have not returned after summer as they were too busy. Got a new one starting Monday who is 30% cheaper! -
Can you have this work carried out under your buildings insurance? Subsidence can be expensive to remedy so if you make a claim, make sure the works are comprehensive and covered by long term guarantee.
A couple of coats of latex paint on the normal will go a long way. The main issues with moisture in a loft is via warm air air passing through the loft hatch, light fittings, cable pipe and vent holes and then condensing on the cooler structure where if not well ventilated can lead to rot.
