Mike
    9
Everything posted by Mike
  1. Probably. Not necessarily the glass, could be the frame or the way it's fitted, as previously mentioned.
  2. I recently bought the Festool CTL SYS - a vacuum built into a storage case. I like the way it stores away so compactly, and how the vacuum part can be detached and slung over the shoulder. I found exactly that with Festool. I imagine that if another manufacturer produces an M class then that would probably apply to their L model too, but maybe not if they don't, or if they're skimping on the filter to cut the cost (though it may be upgradable).
  3. Impact sound is when there is a direct strike on the wall - a football, door shutting, switch being switched - so you're not dealing with that. If the structure of the building is vibrating as a result of impact or airborne sound, you need physical separation of the interior of the room from the exterior - a room within a room set on dampened springs, but that's not at all viable for a regular domestic room. Airborne sound therefore the only thing you can easily reduce. And I'm sceptical that any treatment behind the bookcase would make a difference because, as you say, that's been substantially reduced by the structure already. Meaning of several different densities Yes, you can buy sound-reducing drapes that have multiple layers of fabric of different densities. They may make a worthwhile difference since the window area seems the most likely problem area and the most readily treatable.
  4. Cork is a good insulator for impact sound - for example between floors - but for airborne sound you normally need weight. Ideally heavy materials of several different weights to broaden the frequency response.
  5. Standard modern 4/16/4 glazing without lamination or toughening gives a reduction of around 31 (-1; -4) dB, so 38dB is a worthwhile reduction (though you'd need the bits in brackets to take into account the frequency range - they are correction factors for speech and traffic respectively, so for traffic noise a reduction of 31-4 = 27dB). FWIW I've just ordered some with a nominal 39dB reduction - actually Rw (C;Ctr) 39 (-2; -6) dB - so my nominal 39dB becomes 33dB (39-6) for city traffic. City traffic - around 80dB - therefore sounds like 47dB (80-33), roughly the normal level of noise generated within a home, and 6dB (approximately 1/3) quieter than 4/16/4 would have been. Unfortunately I've not done any calculations for drapes.
  6. From the look of the photos, it looks like the house is of traditional masonry construction, so the walls should already be pretty effective against airborne sound - and I presume that the BioFib is internal wall insulation, which will have boosted that further and broadened the frequency range being damped. In which case I suspect a bookcase would only make a marginal difference. It looks like you could be on the top floor; if so, did you do anything to reduce sound transmission through the ceiling? Windows are likely a weak point unless you specifically chose double glazing units & frames with enhanced sound-resistant specifications, rather than just new double glazing. And, as @saveasteading says, noise also get through gaps.
  7. But could easily find out by selecting the slightly smaller heat pump in the software and looking at the result?
  8. The rafters of a 1930s house would have been designed to suit the lighter weight of clay tiles - that's what I'd choose.
  9. Not a great situation, but given the choice between spending £5K on a misting system, of £5K on legal fees, I think the former would be the better option.
  10. Not a lawyer, but unless there is anything in your deeds requiring you to maintain the boundary wall, then my understanding is that you have no obligation to fix it - although if it is in a dangerous condition and collapses, then you could be liable for damage or injury. And, unless there's anything in your deeds requiring you to have a boundary wall, you could just demolish it.
  11. EPCs certainly have significant flaws, but At a guess, partly because people cap their heating use and live with lower temperatures due to affordability. It's interesting that the article is using the criticisms alongside the rumour that the Government is considering easing the requirements on renting lower EPC banded properties.
  12. Under the new (2021) rules in France, if the EPC is inaccurate the buyer / renter can now sue the seller / landlord for damages - probably (according to the legal advice) for the cost of bringing the property up to the declared EPC standard + reimbursement of excess fuel bills + interest, though AFAIK there hasn't been a case yet. Of course the commissioner of the report can in turn can pursue the assessor. Unsurprisingly, you can't get an EPC for €30.
  13. Primary energy = the amount of energy burnt at the power station. A lot of that energy is lost in waste heat at the station and in transmission losses, so a very different figure from the kWh measured on your meter.
  14. Either leave them as they are - or take them up and relay them tight together, and find a length (or two) of matching old timber to make up the gap against the final wall.
  15. Standard opening doors? I can see the visual appeal of pocket doors, but they do present clearing, servicing, repair and noise issues. I've got one in the room I'm staying in now and it doesn't close properly...
  16. Zehner have good units, but the price quoted for them varies considerably depending who you buy them from - and, in particular, in which country they are based.
  17. 170mm. Yes. Allow for heavy doors with edge seals & beef up the stud that the frame fixes to - you'll probably need a double vertical stud (check what the stud manufacturer says about supporting heavy door sets).
  18. The Komfovent DOMEKT R 500 V is an unusual choice. Counterflow heat exchangers are mostly chosen for domestic use, rather than rotary ones. I wonder why they've picked it? Komfovent do have a similar model on the Passivhaus component database, and the performance looks reasonable, if not class-leading.
  19. A cut of 10db = a halving of noise, 5db = a useful reduction, 3db = just about noticeable. So to go from 40dB to 60dB the airborne noise level would be a quarter of what you'd otherwise hear - a very significant difference. If impact sound is an issue, then you'd ideally want two independent studs, though resilient bars are an option. This is the one I'll be building later this year; 2 x 70mm studs, 2 x 45mm hemp sound insulation, with 1 x plasterboard + 1 x GypsoLignum each side. I'm expecting a reduction around 65db, though as I'm using GypsoLignum I can't prove that.
  20. Mike
    blocks to use
    Aerated concrete blocks are notorious for cracking, even if all the recommended precautions are taken. I'd choose a medium density block instead.
  21. Sounds OK for a detached newbuild, but can't see it working on a tight urban site or a retrofit where there is no access to the outside. And, having seen a neighbour battle with builders for years before eventually having to pay another to fix the problem (it was to make additional space for his growing family - the kids had left home by the time it was fixed) I'd add internal drainage as a precaution anyway.
  22. Fully intend to run cooling this year in 300mm loops. I was involved with a commercial development a few years back where overheating was a problem and suggested using the 300mm-spaced UFCH pipes for cooling. I don't have their calculations, but the consulting engineers concluded that 150mm spacing would be required for it to make a worthwhile difference. Of course that's a specific case, but I've opted from 150mm maximum spacing since then. It will be interesting to see how you find it @ 300mm.
  23. Personally I put loops everywhere (for maximum flexibility), and at no more than 150mm centres (to allow for the possibility of using it for cooling in the future).
  24. No - but I would run ducts so I could easily pull cable through if needed.
  25. Unfortunately that's not uncommon. That's partly why there are various discussions here about what to specify for sound-resistant partitions & floors.
