Everything posted by ProDave
How much space for storage & welfare on site? Minimum?
ProDave replied to Dreadnaught's topic in Project & Site Management
We have been living in the 'van since last April, so just coming up to a year. Our old house is now rented out. It's only me working on the build now. Site office and laundry is in the part built house. If you are planning on living on site it's normal to include temporary planning permission for the static 'van on your planning application and you pay band A council tax for it. Though we negotiated that the static 'van can remain after the build for use as a workshop and studio (not for habitational use once the house is complete)- 21 replies
- storage on site
- hard standing
Because for the last year i has been what we call "home" And for that use our 28 ft 'van is at the smaller end of the scale, but we bought it for it's unusual room layout.- 21 replies
- storage on site
- hard standing
No 4 by 2 on the gables. It didn't quite go to plan as I detailed that before I got the tile end caps, and when I put it all together, it left a sliver of wood exposed, and in keeping with my low maintenance goal I did not want that, so I fitted a plastic strip before the tile end caps went on to both protect the wood from getting wet and create a drip bead (much as there will be a drip bead when I add the aluminium cladding to the fascia)
It is just style. Ours are not like that. Just lengths of 6 by 2 regularised timber, that will eventually be clad in an aluminium profile (so painting or varnishing wood is not a regular chore) This is typical of how older cottages were built for instance. It did create an "issue" with the downpipes. The standard bends were too bulky and I had to trim them a bit to get a small enough offset
Can you squeeze that 8M to 9M? A small static caravan such as the one we have 28ft by 10ft (8.5 metres by 3 metres) might fit and would provide all your needs. You can get smaller static 'vans but they are not so common. An old (and hence cheap) large twin axle touring 'van might be a better bet.- 21 replies
- storage on site
- hard standing
Has a safety boot saved you?
ProDave replied to epsilonGreedy's topic in General Self Build & DIY Discussion
On a former job I visited a factory regularly. Visitors had to wear steel toes and if you did not have your own, they provided a pair of very uncomfortable steel toed wellies. So I got my company to buy me a pair of steel toed shoes for the next visit. When I told my host at the factory my shoes were steel toed, he stamped on my foot to "check" I was telling the truth. My boots on site have saved me many times from standing on a nail (steel insole) probably more times than the steel roe caps have done anything.- 17 replies
- h&s
- health and safety
(and 2 more)
Wet UFH how to retro fit an electrical heater element?
ProDave replied to readiescards's topic in Underfloor Heating
A bit of a re plumb, but to me it would make a lot of sense to have a decent sized buffer tank for the heating, and divert excess PV to heating that. Then as well as your tank of DHW, you would have a tank of heating water for the evening. -
Can planning permission mandate a specific supplier?
ProDave replied to epsilonGreedy's topic in Planning Permission
We had this sort of anyway. The planners made it clear they wanted us to use a slate roof. I made it clear I did not (both houses wither side of us for 2 or more houses are concrete tiled) In the end they said they would "accept" Marley Edgemere Riven finished concrete tiles. So that is what went on the plans and that is what was approved. So they didn't strictly enforce a single product with a planning condition,. rather the discussions during the planning application made it clear that was the only concrete tile they would accept. -
This all started a couple of weeks back when I was asked the question" What toilet cistern are you going to buy" "The same as in the last house" was my reply. They were cheap, easy to install, dependable and (when one did play up) easy and cheap to service. What more could you want? "but I didn't like the flush plate, choose a different one." I then had to explain you can't just fit any make of flush plate to any make of cistern. So that took me to the start of this thread. The next "discussion" will no doubt be where to fit it, left, right, or middle. I suspect middle, to force one to close the lid in order to reach the button.....
In our house the Tumble dryer is actually the towel fluffing machine. If you dry towels any other way they fail the fluffyness test. That is it's sole reason for existing. We now have a condensing dryer, so at least we don't shove 3KW of heat out through a big hole in the wall any more. However the condensing mechanism is very poor. It takes in room air at floor level to pass through the condenser. That might work okay in an old house with no floor insulation so the floor is always cold, but in a well insulated house with under floor heating, the room air it sucked in was simply not cold enough and you could run the thing for ages and the towels came out wet and warm. I swear in the new house the TD is going in the garage where there is more likely to be cold air for the condenser. Perhaps we need ducted air from outside, over the condenser, then back outside again?
Our builders handled them all by hand picking them up with those suction cup things.
- 6 replies
- windows
- window fitter
The "problem" I am having looking for parts to make that DIY one is the 42 - 54 reducer. You need a "slip" version to allow the 42mm to pas through.. Normally there is a stop that won't allow the 42mm all the way through.
DIY scaffolding: wind - the enemy
ProDave replied to ToughButterCup's topic in General Self Build & DIY Discussion
One of my favourites- 34 replies
- 2
- scaffolding
- kwikstage
(and 4 more)
Don't know about paper blinds, but we are setting up cardboard doors.
A quick costing on ebay (almost certainly not the cheapest) and it comes out at £167 for a 1 metre long copper 42/54mm heat exchanger for the pipe and all fittings. If I could get that down to £100 I might give it a go.
Thanks. I will go and cost it up. This might have to be well and truly hidden and not mentioned for BC sign off.
Don't like the idea of the shower waste being reduced for that run. I will have a look at available pipe sizes. But a nice simple idea. He has plumbed the heat recovery into the feed to the hot water tank. I think it would be better to connect it to the cold water feed to the shower thermal mixer valve?
The idea is you pre heat the cold water feed to the shower with the wast recovery, and the thermostatic mixed adjusts to use less hot and more of the pre heated cold to maintain the same temperature.
That would do. At the moment I have separate 40mm wastes from each shower to the stack (my philosophy to only have a single item on each "small" pipe) so that would either mean 2 of them, or combine the 2 showers onto one 40mm waste. I am actually more inclined to try and find a length of 40mm copper pipe, some 10mm annealled copper coil, and get soldering......
You look to have plenty of room to move the house left a bit on the plot, then stretch the main body of the house a bit wider and perhaps a bit deeper as well. I have worked on a house up here with a very similar layout. but instead it had the downstairs bedroom where you have the kitchen shown, and then the kitchen / dining from the front to the back of the house in the now stretched bit currently shown as study and utility.
the major "problem" with that is it does not accept a 40mm input allowing you to keep the existing wet wall shower trap that is installed. It looks to want to replace the shower trap and it's too late for that now. I similar thing with 40mm in and 40mm out would be quite easy to retrospectively fit to our existing run of shower waste pipes.
Nearing completion of our main bathroom. Just one more item to buy before I can complete the plumbing. A concealed lavatory cistern to fit inside a vanity unit (with a back to wall toilet) You would think this would be straightforward. Not if "the ladies" are involved. You see the most important part of selecting the right cistern, is nothing to do with it's technical merits, choosing a reliable brand that can be serviced easily,, choosing on price, or any other such requirement. No, the ONLY criteria is choosing a flush plate that both of the ladies like. Nothing more, nothing less. So starts many hours of internet time. The first thing you find, is most suppliers treat the flush plate as an insignificant (but essential) sub purchase. IF you are lucky you will find a small poor picture of it. You have to be really really lucky to find a decent picture of it, and if you actually find someone that tells you the size of it then you have done really really well indeed. Then add in the complication, that daughter has chosen a large rectangular flush plate for "her" bathroom (I think it's grossly over size but my opinion does not matter) and SWMBO has chosen a smaller square flush plate for the en-suite. At least both flush plates are the same make. So now we know what we want, we just have to buy it. That's when you find some suppliers (a lot actually) only stock one of the flush plates. Then when you eventually find one that does supply both types and are a keen price, you start on the long journey through "checkout" only to find they want to charge £99 for delivery to our "remote" location. We finally got them from these people, https://www.bathroomsupastore.com/ being the only ones we could find with both flush plates, not quite the cheapest prices but at least they only charged £9.99 delivery. So please, nobody tell me that Tavistock cisterns are rubbish, because as already stated that is not a "selection criteria"
I had to repair the roof on our former rental house. So I had a section of Kwikstage up and my roof ladder up on the roof. I left the roof ladder there overnight (though not the ladder to get up the scaffold) I cam back next day and pondered why the roof ladder was was not on the roof, but leaning against the scaffold.Surely it had not been that windy? Then I noticed the roof ladder was covered in paint. The cheeky blighters a few doors down were painting the outside of a house and decided it would be okay to borrow my roof ladder without asking to paint the bit of gable end where the terrace was staggered.- 34 replies
- scaffolding
- kwikstage
(and 4 more)
This is one of the reasons I built my own shed. Where else will you get a garden shed built with a frame of 4 by 2 timbers, and a diagonal brace? Mose shop bought sheds have barely a 1 and a half inch frame, and the only thing giving any bracing is the nails in the planks.
