ProDave
    427
Everything posted by ProDave
  1. If you bought them all with the same batch code you would not need to worry....
  2. Thanks. SWMBO will be going to screwy's for me tomorrow.
  3. ProDave
    Initial ideas
    You have a 3 phase 11KV line there. Why do you think it is going to cost you £15K for the hydro to hang a transformer on one of those poles and drop a feed down to your house? A local build here cost £10K for the supply but that included undergrounding a section of the 11KV line that was in the way for his house. You don't have to do that so your cost should be a lot less than £10K If you are going for solar pv then you want a stored hot water system to dump excess power. I think re ASHP's the general consensus is buy one and fit it yourself. If you are intent on claiming the RHI you will most likely find the extra cost of having to get it supplied and installed by an MCS registered contractor will be more than the RHI payments would be. Many on here don't like wood burning stoves (I do) but given your woodland it would be foolish not to use all that free fuel. Make sure it is sized properly and get one with a ducted air intake.
  4. I thought about that, but aren't those tapered threads? (they always seem to be when screwing an outside tap into one)
  5. Plumbing my shower in the wet room at the moment. This is the arm onto which the rainfall head will screw onto. It looks like you should bolt it through the wall panel (wet wall in this case) and then make the plumbing connection. It is a parallel thread and a 1/2" tap connector fits onto it perfectly. However, here is the problem. Where it is going, I do not have rear access to the wall (already boarded skimmed and painted) So what I need is something I can screw (on a suitable cross member) inside the wall frame, connect my 15mm copper pipe to, fit the wall panel, then screw this arm into it. As it's a parallel thread and any fitting I am aware of almost certainly won't have a sealing washer, then it will rely on ptfe tape or similar to seal things. It's only the outlet from the thermal mixer to a rainfall shower head so pressure will be minimal ans none at all when it's off. So what fitting?
  6. Is this a busy road? Why will it take 3 days? Can they not mole under the road? for just over £3K I am pretty sure I could buy (or make) a set of traffic lights. Who gave this quote? When I was looking at getting the road crossing made for all 3 services, I contacted a local contractor with a minor street works permit as well as the Hydro and Scottish Water. The independent contractor was the most expensive as although he has the street works permit he still would have to apply for and pay for a road opening permit (even if molling under the road) In contrast the utilities hold a permanent road opening permit. Even if it is a busy dual track road, all it needs is to do one half of the road at a time with traffic lights. It should be comfortably done in a day. I suspect the 3 day thing is they cannot guarantee which day, so they will book and (you will) pay for 3 days. THIS is the bit I would be contesting with them. We had a bit of a similar farce. Open Reach would not open and work in a junction pit right by the main road, so we had a long delay while they booked and waited for traffic management. The traffic lights arrived at 10AM and set up. OR did not arrive until after mid day. The traffic lights left at 3PM and OR continued to work in the pit without traffic management. (the pit was in the grass verge not in the road) Ours is only a quiet single track road so no traffic management, they just pushed a big steel plate over the trench with the digger when someone wanted to go by. ask them if you can provide your own traffic management. Here you go, a set of lights for £211 for a week https://www.speedyservices.com/22_0248-h-xlite-traffic-signals-2-phase-radiolink You just need some cones and signs. Over £3K for 3 days is taking the urine.,
  7. Hi and welcome You seem to have the bedrooms facing the street with only arrow slit windows, and a corridor facing SW where you can have large windows. I would swap that around and have the corridor on the street side, who cares it only has arrow slit windows, it will give your bedrooms a sunny aspect overlooking your garden.
  8. Up here, BC will issue a "certificate of temporary habitation" to allow you to move in and complete the work, then issue a completion certificate later. I don't know if this is possible in England. Ask them.
  9. Or dig the hole at the wrong time of the year here, and watch it fill up with water all by itself. I have to say our partial soakaway then discharge to the burn is working well. At this time of year as I predicted it is working as a land drain to keep the water table down, there is a constant small trickle from it even when we are not discharging any water. In the summer it is the reverse with most of what we discharge being absorbed by the soakaway and very little going into the burn.
  10. Just get the builder to leave a gap and install a lintel so later you can dig it out and thread a pipe under the wall.
  11. Well foundation trench inspections are required by building control, as are witnessing a drain pressure test. So it's no a very big leap to ask for BC to witness a percolation test, other than the fact it will be a longer site visit waiting for the water level in the hole to go down.
  12. For a minute I thought you were showering with warm beer, I don't know what made me think that.
  13. I don't have much hair left and what is there is very short. Let's just say hair washing does not take long. Water heater is gas instantaneous so we will only run out of hot water if we run out of gas. The complaint is the stupid way it is plumbed making the run from the boiler to the tap about 3 times as long as it has to be.
  14. I thought I had seen just about every form of house construction, but here is a new one for me. Terraced ex LA house, been stripped bare for major refurb and rewire. In the kitchen, the party wall between this and next door appears to be just a timber frame, with 3 layers of plasterboard on the frame (presumably the same next door on the other side of the frame) Customer wants sockets on that wall. There were none before, in fact there are no electrics on the party walls at all. I can't go cutting holes in the 3 layers of plasterboard without compromising the fire rating. The only solution I can see is leave the 3 layers alone, batten it to make a sevice void and then a 4th layer of plasterboard. He will have to accept the room shrinking a little. Anyoine encountered this before?
  15. Ah a soft southerner Just coming up to a year in ours. And we picked the longest coldest Highland winter for many years. Had many nights of -10, even -12 one night. A mere -3 forecast tonight, balmy weather. The best thing we did was fit a wood burning stove. That thing has been going almost non stop since November. It's been a struggle at times to keep up with preparing wood for it, but it has saved us a fortune in heating. The first month we were in we got through 47Kg of gas in a month. We stopped using the gas fire then.
  16. The shower in our static caravan is like that. Solution: Turn the shower on. THEN start getting undressed. By the time you have got your kit off, the warm water has arrived. No time wasted. Same in the morning. I have got to know the point during my shave when it is just the right time to turn the tap on, and as I put my razor away the warm water is just arriving for a wash.
  17. But if you have a private waste water plant discharging to an infiltration field then you are adding to the water that the land has to absorb.
  18. I did my own percolation tests for building control. Nobody questioned anything. I was honest enough to highlight the problem with seasonal high water table, which is why we had the struggle to find something that worked and ended up with a permit to discharge into the burn. I could have just ignored the water table issue and installed an infiltration field and nobody would have been any wiser, except me when the garden became a swamp. While I agree it is wrong that anyone can submit false results, I would not like to see a system where you have to use an accredited testing company for things like this.
  19. How far apart from the road crossing? Ours was only a couple of metres in the field the other side of the road and it cost £1726 including the road crossing under a 3 metre wide single track road (same road ceossing used for telephone and electricity)
  20. If you are fitting internal insulation then you would create a service void for cables etc then plasterboard. Be very careful dry lining and insulating internally. so many people do it poorly and create a "plasterboard tent" By that we mean a layer of plasterboard with an air gap behind it and that air gap is open to outside either through gaps around the windows to actually open to the loft. I work as an electrician and lots of old cottages around here are like that, and on a windy day if you unscrew a socket or switch from the wall, a howling cold gale comes out of the hole.
  21. That is still not right. He has only "given you" 3 months grace. What if you are like me and expect it to be well over a year until completion? If you are happy you will finish in 3 months then fine, but I would still be fighting.
  22. We have a mezanine to the largest bedroom (extending over the smallest bedroom) It was detailed on the plans including the building warrant drawings. We are not intending it to be anything other than a "storage platform" to start with so access only by a portable ladder and no hand rail. Eventually some form of fixed steps will be installed (and a firemans pole if my daughter gets her way) which will dictate the need to fit a handrail.
  23. Hi and welcome to the forum. On a brick walled house you do the wiring by chasing a channel in the brick fitting the cable behind capping and re plaster. Are you sure it's cavity wall? unusual for 1930's most of that period were solid 9" walls.
  24. Hi and Welcome. Yes I am not far away, probably 45 minutes or about 30 miles. Looks an interesting site, but being so sheltered may be midge hell in the summer.
  25. You just bolt the pigtails to the cylinders and turn on. Remember they are left hand thread. If you bought the 'van from a dealer it should have come with a gas safety test certificate. If you have not got the cylinders yet, phone around the suppliers. You can usually blag a pair of cylinders without paying the hire charge, though when I tried this Calor would not do that so we have a different supplier (actually slightly cheaper for the gas)
