Oz07
Everything posted by Oz07
Structural opening dimensions for window frames
Oz07 replied to Moonshine's topic in Windows & Glazing
Depends on colour with pvc I went 15 overall with grey -
MVHR in large volume New Build
Oz07 replied to Triassic's topic in Mechanical Ventilation with Heat Recovery (MVHR)
That's what I did. Im not sure their sales dept is that knowledgeable but you can discuss with the technical side. -
Have you looked at a don Carlos yet? Your scraper could be crap
Google don Carlos double glazing
Is there not guidance on poison manufacturers which makes clear? Can't you borrow Jeremy's super trap lol. Seriously though does anyone here worry about rodent damage to airtightness membranes? For such a critical part of the build it is susceptible to damage from them
Don Carlos is your friend
Im tight myself but being new to this system I just went with a one stop shop and accepted that I probably overpaid a little. I'm happy to start shopping around once I grasp a subject but just wanted this to be all supplied by one firm. My 2 pence! -
New sewer connection required - any recommended firms in/near Midlands?
Oz07 replied to gwebstech's topic in Waste & Sewerage
A mole for a sewer connection never heard that. Water supply yes -
After so many loads they are supposed to now. I think you could circumvent by using a different company this time.
You want some 6f2 or something around the outside of that beam will be a bit nicer under foot. Did you have to take any drains inside or can you dig in after? Did the beam being on too of ground push up your ffl or did you dig off first?
Just watch you aren't trapping water if beaded both sides. Sure he knows what he's doing
first two about the going rate depending where you are
Very nice whats going in the bottom?
Power equipment with no wayleave or easement
Oz07 replied to Randomiser's topic in General Self Build & DIY Discussion
So rather than chase the matter of re routing would your efforts not be best spent just serving them notice? If they then have 12 months then so be it but the line will defy be gone or will secretary of state intervene? Your kind of starting on a back foot with the negotiating by saying your happy for it to stay but you want it underground. The (excuse the pun) middle ground for them is you can either pay for it or help to do it (trench). Surely if you change your argument to "heres your notice get the cable off my land" then they will have more incentive for you to offer you what you actually want (underground cable)? I appreciate I have no knowledge of how these matters actually work i'm just looking at it from a negociating point of view. -
I had a standpipe put in for a future planned property. They weren't interested in changing anything after I completed the house. Perhaps as they knew the standpipe was going to be used for house within the near future they didn't bother restricting flow
You don't have any rights to just stop them using it then after serving notice? -
Building regs on new doors for new build
Oz07 replied to gwebstech's topic in General Construction Issues
Think it depends on the security part of building regs. Think all ground floor Windows have to be laminated etc etc. I'm not sure when it applies and when it doesn't. Just tell your door man to fit the standard one at your risk -
Cheers Nick thanks again. Will have towel rad without trvs so will act as bypass. Plumber seems to think we will be able to push the air round like you say. Got pipes connected up to manifold today think I will swap the clips for screw on ones. Get the pipes off the board then bin the airfelt.
Cheers Nick. I can't have manifold higher as will then be through my air tightness layer. Would it be possible to periodically purge air locks in each circuit if it became an issue? Ie turn all circuits off then push it through? How often is air likely to accumulate in the pipework rather than rad and cause this issue? I was trying to eliminate most of the joins in the building by having it done this way.
I think glue down is beneficial as it's paid upto arcs and skirts rather than these laid ontop. Good luck making a nice diy cut around these I'd leave to the pros I have the floating stuff in current place but only because it's diy whereas gluedown you have to get someone in. What's the going rate for the Labour and glue got to be 20-30?
Last I heard your tile floor was floating sorry couldn't resist!
The pump is with the combi. As had been said I can force the air through by closing off all but one circuit. Pressure would be mains pressure so same as a garden hose would be. Does this mean I'd be able to push any lock through? Unfortunately can't mount the manifold higher than pipework I'd be going up through airtight layer onto unheated loft. Pita.
We've set up all the pipework for the manifold on the heating. Spoke to speed fit they say fitting manifold upside down is fine you just swap the air valve and bleed off valve to upper and lower bars, then turn them the right way round. My pipework is going all up into ceiling void then back down to rad's. Property is a bungalow with direct runs to each rad. What is the likelihood of air becoming trapped in the system? I'm fine bleeding air off from radiators and from the manifold but am I risking any air getting trapped up top or does the pressure in the system push it round? Do i need to take any precautions? Air doesn't get trapped in a garden hose when you turn it on and it goes up and down so I think i'm over worrying but I don't understand the physics or whatever is involved.
