Oz07
    6
Everything posted by Oz07
  1. With what on the outside and inside?
  2. I think that would be a terrible idea. Create problems down the line. I'd be looking to either chop out and replace with similar reclaim of you really want to or accept it for what it is. Character!
  3. Yeh use some kind of a grit sand then like you say got to consider drainage
  4. Worrying too much dave. Crack on
  5. Guessing eps won't have dpm below so the only considerations are what is easiest to work with
  6. Or you go in with the same attitude they give you and be prepared to walk out. I'm no expert buyer but if they make you feel uncomfortable give them the same.
  7. Since when do sparks come back to test during works?! @Markblox
  8. Any local trade tile shop. Go independent. Call first
  9. Since I've had mac laptop I've never bothered with anti virus. Aren't they supposed to be a bit more secure or less targeted?
  10. It did go up after a bit of a shortage last year. @nod will be the man to ask. I'd be wanting the number to begin with a 5 excl vat for a sq edge 8x4
  11. Can't be 7 quid where abouts are you
  12. On your return you just fill in the box for vat reclaimed from other eu member states. (For vat registered entities)
  13. Usually If you get something big and bulky delivered damaged they deliver a new one or refund and leave damaged with you. Not a bad score if you can source spares
  14. Yeh we were doing a kitchen job for a woman with probably 7m by 5m floor. Was a garage conversion with timber floor with pir between. I talked her out of that Elec ufh after asking sparks the question. Radiators it was!
  15. An electrician once compared that Elec ufh uses same amount of leccy as a kettle on boil. Is that true? I don't understand the need tbh I live in a house now with vinyl bathroom floor and never feel like feet are cold. Had tiles on 1st floor bathroom in last place, again never really felt cold feet
  16. You can set 2 accounts up to email on iphone/pad then either view both inboxes at once or one. Forget how to do it just Google it
  17. Easy. 5m carpet and a nice runner offcut!
  18. Surely if you had a massive hose with no bucket you would always get same level? Mark a line on first leg take hose to other. Make sure water line level with first mark then mark second leg.
  19. Think a plan sketch be better for others to advise. Mark window door way drains etc
  20. You don't build a room to suit the carpets. Build roof first imo.
  21. would the spreadsheet @Jeremy Harris made to give you fabric losses be a start for your heating requirement
  22. quite a few of these sold off near me recently, went for crazy amounts
  23. I often think surface water drainage requirements as a bit heavy. For instance before the house was there water drained away. I'd perhaps just use a gravel filled French drain for now perhaps digging so there is a section which takes water away from the founds and gets deeper
  24. @nod how come you get a builder in to get the structure up yet aren't put off doing first fix wiring and plumbing yourself?! I'd be well frit of those two trades
