dpmiller
    4
Everything posted by dpmiller
  1. so the ASHP cuts OUT at 55c but what is it's cut IN point? It had started to reheat the tank by the time you were finished, but that's too late.
  2. @pocster are you talking about line level or speaker level here? Mixers are low-level/high impedance, and you've already said your Rasps have inbuilt amps?
  3. Are all the amp outputs simultaneously connected to only one speaker? can each Pi output a DC signal saying it's active? Some PA/ background music amps have a "priority" input for announcements/ alarm signals over the music.
  4. why would you presume that tax evasion is the only reason for preferring cash? It costs money to lodge into many business accounts -whether cheque or cash- and so if you're going to (say) need cash to buy the shopping with, there's no need to drag it through multiple bank accounts as long as you note it in your books as income. I know, I do it.
  5. So the main contractor is subbing out much of the work too then?
  6. A lot of the componentry will be the same, and (no doubt) there are only so many suppliers of the wee rubber trims for around the pipes, and the plastic top/bottom covers...
  7. the blower doors are calibrated with removable plugs to change the range of the meter. Dunno why there'd be a problem with using the kit as designed?
  8. we went to a square section nylon filament and it's incredible! So much nastier than the ordinary round stuff, even half inch brambles are dealt with very easily. Seems to last longer too...
  9. I recognise that ASHP... Just screw the isolator to the side of the unit
  10. @ProDave Take a look at your prescription, specifically the "Add" number. that's the magnification the optician recommends adding to your base correction to get the reading prescription. Go to one of the online providers, I use https://www.selectspecs.com/ the lab is in Hong Kong but the service is superb and they're cheap as chips; and when you're typing in your prescription, make the Add 0.5 or 1 less. Or both, they're so cheap, lol.
  11. just don't leave any visible marks.
  12. You pay to uplift a pallet, I'll put two on it...
  13. what a palaver. Merchant's, £15, done. :shrug:
  14. ^ that's pretty much what I'm doing with my TS @SteamyTea. HP coil buffers the system/tank to at least heating flow temp, but can raise the whole tank to DHW temps if the upper/lower immersions haven't done that using the PV.
  15. Fan will only run when it's actively heating. The fan on the better units is modulated and will change speed to suit the load.
  16. you didn't annoy the plasterers did ya? Polished up with a plastic bag will do this...
  17. Buy loadsa 16mm fittings and use it for your first fix plumbing too? I thought about it, but the ease of working in 10 and 15mm put me off tbh.
  18. Inverse, ST. Bog-standard weather compensation, in other words?
  19. https://jharries.co.uk/product/polypipe-polyplumb-15mm-spare-component-kit/6001?gclid=CjwKCAjwqcKFBhAhEiwAfEr7zR0kBbkjry62mgdN8TdSfHz0D_ehtKUJ9Xx8iHPlmsKVMzCddGeU9xoCOkwQAvD_BwE looks like there's a grey ring missing according to the image here?
  20. If you're installing it yourself why would you pay someone £600 for walking round the house with an anemometer?
  21. nope, don't need handles. Ours is pretty big, a mooring bollard might be of more use...
