dpmiller
Everything posted by dpmiller
you didn't annoy the plasterers did ya? Polished up with a plastic bag will do this...
Tool to cut a 215 x 120 wide socket in a 100mm block wall.
dpmiller replied to epsilonGreedy's topic in Tools & Equipment
SDS drill then SDS chisel. -
What do do with waste let's have your ideas..
dpmiller replied to SuperJohnG's topic in General Self Build & DIY Discussion
Buy loadsa 16mm fittings and use it for your first fix plumbing too? I thought about it, but the ease of working in 10 and 15mm put me off tbh. -
Help settle an argument- room layout
dpmiller replied to Crofter's topic in New House & Self Build Design
Toasty telly! -
LG Therma V mono block Air Source Heat Pump
dpmiller replied to ProDave's topic in Air Source Heat Pumps (ASHP)
Inverse, ST. Bog-standard weather compensation, in other words? -
https://jharries.co.uk/product/polypipe-polyplumb-15mm-spare-component-kit/6001?gclid=CjwKCAjwqcKFBhAhEiwAfEr7zR0kBbkjry62mgdN8TdSfHz0D_ehtKUJ9Xx8iHPlmsKVMzCddGeU9xoCOkwQAvD_BwE looks like there's a grey ring missing according to the image here?
MVHR Experience
dpmiller replied to Ryan Bazeley's topic in Mechanical Ventilation with Heat Recovery (MVHR)
If you're installing it yourself why would you pay someone £600 for walking round the house with an anemometer? -
Affixing handles to a trojan supercast acrylic bath
dpmiller replied to Adsibob's topic in Bathrooms, Ensuites & Wetrooms
nope, don't need handles. Ours is pretty big, a mooring bollard might be of more use... -
tiny leak. each time pushes a wee bit of volume out of the pipe til there isn't enough to send the signal
It's possible to get great design at affordable cost with no percentages. You could do worse than spending a few quid to peruse the designs on https://irish-house-plans.ie/ or the like. Shaun did a great job for us...
Is the black plastic over the felt and battens still there? That would create a lot of ponding if so.
Digger with forks on?
New heating for terraced house in London
dpmiller replied to Ferdinand's topic in Central Heating (Radiators)
I've just had a look at the Worcester Bosch website, and interestingly, according to the ERP label their indoor oil boilers are 54-60Db yet their outdoor one is somehow 0Db. Hmmm...- 42 replies
- terraced house
- london
precisely. -
I'd be more concerned about Brinelling of the bearing surfaces off-road than simple loading.
@Dave JonesNo they aren't. Cite your source.- 42 replies
- terraced house
- london
But how do you know when the oil unit has reached setpoint? Short of going and checking if the burner is running? Rads will be putting out noticeable heat well below that. The oil unit is totally uncontrolled, the ASHP will only be putting out it's full 12.5kW *if* the heating load keeps the return temp low and as previous it wants to keep the flow deltaT within limits as well. It's the same house with the same heatload. The oil boiler will heat it more rapidly. -
it's 30kw until the flow temperature reaches setpoint. -
Every.Time. you turn it on. -
ASHPs tend not to have an orifice tube or thermo expansion valve, instead they use a servomotor driven expansion valve. So between variable speed drives and this, the actual load and efficiencies are very configurable. -
One point that you didn't note is that ASHPs like to run at a much smaller in-out delta so it's not quite as simple as running at 100% to get to setpoint. They're (internally) continually juggling flow/temp/ gas pressures and temps to try and maximise the production. Just because (say) the HP can deliver 55c water doesn't mean it's aiming to do that when turned on from cold... -
gas barrier would be outside wall to outside wall, continuous.
I think tho that it's only HETAS in their ar*e-covering wisdom that "require" Dibt tested. It's no surprise that only the very dearest Euro stoves have it. I got a really snotty response from the local big stove place and they flat out refused to even quote me for a non Dibt unit for purchase at my own risk... Don't need the turnover evidently.
two birds, one stone, perhaps? https://www.firepowerheating.co.uk/thermalux-sheets?adwordspermission=1
Dibt tested stoves are the gold standard. They've self closing doors, the doors are tested to seal after thousands of openings etc. Remember that you do NOT have to use a HETAS installer, your BCO can sign it off. It's not difficult to balance the MVHR to bring the house to positive pressure. Elsewhere in Europe room pressure monitoring is used to guarantee this/ alarm in case of issues as far as I recall from my research a while back.
