dpmiller
Everything posted by dpmiller
Which mobile mast am I reaching?
dpmiller replied to epsilonGreedy's topic in General Self Build & DIY Discussion
I have two apps- Network Cell Info and Cell Tower Locator. The former tends to show the coverage centre of a tower whereas the second has the actual tower location -
the grey bits are European sized IIRC.
Washing Machine / Dishwasher Cleaner
dpmiller replied to Onoff's topic in Kitchen & Household Appliances
why is copper a must? -
Love a neat bit of TIG
It's an Afriso pump station for the boiler stove, Like a Laddomat. Recirculates the water in a boiler stove until it heats to a useable temp before letting it into the tank. Improves combustion efficiency and boiler life.
- 367 replies
- ireland
- timber frame
Loft Conversion is cold
dpmiller replied to Rikki Holland's topic in Lofts, Dormers & Loft Conversions
Fakro do a smart sealed and insulated door for this kind of application,. We've a couple of similar spaces in ours ( however they're "inside"in terms of insulation and airtightness) and we put a pair of these doors in. They're pretty good quality and not at all expensive https://www.fakro.co.uk/products/all-products/loft-ladders/dwk/ -
Hot-press plumbing done, give or take. Just need to bring some cables up to a wiring centre on the wall and that'll be it for now.
- 367 replies
- 2
- ireland
- timber frame
It's as supplied, but I'll look into a copy of the MIs for the valve itself, thanks. OK for completeness it's a Reliance tempering valve and good to 99c
- 367 replies
- ireland
- timber frame
OK so what's the normal max to run a TS at? Fairly sunny today and both immersions (upper as master, then the lower one) have tripped their stats with the tank now at 82c. Aim for 85c?
- 367 replies
- ireland
- timber frame
and check out the suppliers on the "other" side of the Irish Sea too...
Site Fencing Requirements England
dpmiller replied to NewToAllOfThis's topic in Project & Site Management
regardless of the price of panels I'd suggest a trailer or something is a near-must for a build... -
And it keeps on keeping on. Down to my last stack of plasterboard. Been doing some diggering of soil and rubble outside so the topsoil mound is smaller than it was and we've an inkling of the shape of drive and garden. But more interesting stuff. As I'd mentioned elsewhere I'd ordered the thermal store- from the lovely people at World Heat- after it became apparent that Harlequin have moved away from larger and multi-coil variants of the Heatstream. Bit of a b*gger as I'd already pre-plumbed some stuff with it in mind. Hey-ho. 270l active, with expansion space above. Direct tappings from the boiler stove, an HP coil (15mx 35mm corrugated), a 15mx 25mm DHW coil, and two immersions. All in stainless. So tank is in place and sufficient of the plumbing done that I was able to fill it last night; from a stone cold start today it had got to over 51c and tripped out the 'stat (that I'd forgotten to turn up...) off diverted PV, and today wasn't terribly sunny. 7kWh diverted, according to the iBoost. I'm very happy with that.
- 367 replies
- ireland
- timber frame
dunno. No reason why tho...
what's wrong with composite?
no service void on the inside will be a pain.
on his own or does he bring someone/ use you as labourer?
Better to go 8.5kW and modulate down even on the Gold Coast... The various different calculators all come out between 2.5 and 4.5kW for our place IIRC but I'll be going somewhere between 8 and 10kW to ensure plenty of headroom for DHW.
80mm plus service void? That's LOTS of very long screws...
Nope, just the rough-sawn tanalised stuff from the local yard. While I *did* follow GSE's spec, it worth pointing out that a. the thickness needs to match your tiling battens and b. the wider the plank the easier it is to aim for...
4x1 treated.
Composting toilets and other "eco" approaches to waste management
dpmiller replied to Oxbow16's topic in Waste & Sewerage
why so focussed on warranties? -
showers aren't inductive. Bog standard 2hp induction motor may have a peak starting current of anywhere between 25A and 40A so soft-start is pretty relevant. Doesn't change the fact that the unit doesn't modulate tho...
MVHR Decisions...what to do?
dpmiller replied to Thorfun's topic in Mechanical Ventilation with Heat Recovery (MVHR)
have you tried BPC for a design quote? -
I'd caution that soft start is very different to inverter...
