Everything posted by markc
dont worry about it, im sure the door fitters will thank you for the extra packing room and give some wiggle room to get everything spot on.
Vehicle Access Via Someone Else's Private Drive
markc replied to minskin's topic in Planning Permission
hmmm, i was just thinking of a drive, but when does a private drive become a road? harsh and unfortunate for the ones building the 3rd property -
Catnic thermally broken lintel alternatives
markc replied to Olf's topic in RSJs, Lintels & Steelwork
Sounds like an excuse. Yes steel prices are up but no shortage of supply from Germany, Spain or Italy, very little British available but thats because the greenies and our government dont want dirty smelly industry spoiling our carbon promises. Cheap Chinese steel is harder to get at the moment but thats the same with most things. -
Interesting questions, i would say the access was existing and therefore cannot be regarded as new even though the build would be and use would increase. -
Yep! far too much easy money made available. Furlough was set too high so why work when you can stay home for almost the same, Why stay open and trading when you can stop paying rent and rates, claim a percentage of profits and cover your regulars. We have had local tree surgeons and jobbing builders walking in with tons of cash to buy machines and bragging how much they are getting for not working! ... great when first thing we get is "As suppliers to the Rail Network you will be expected to continue as normal" ... blaaa blaa blaaa so working straight through, no money for anything, no grants, still have to pay rent and rates, not seen as key workers, not allowed into supermarkets etc as key workers, no money to implement covid measures, Covid police visits every couple of weeks and its all those having to stay at home on furlough who are the real victims! arghhhh .... rant over.
If gates will only open one way then you can mount hinges on the inside or outside face to save space. If gates will swing either way then allow approx. 3 inches space between gate and post for the hinge
I nearly watched it last night, dont think ill bother now.
As above, im not aware of any specific requirements
More info? photo? Really not sure what you are wanting to know
10Kn is nothing (1ton) but I agree you should have a plate to land the truss on. Could be steel or even plastic, couple of layers of DPC etc. Truss bottom cord is plenty wide enough to give a good bearing so really just an isolating layer unless you want to include fixings in which case a steel sole plate would be the best option.
I would leave it alone and grow to hate it … more incentive to get the house built
Totally agree. ive been using arc welders on very long extension leads for years. All the above information is valid but to get back to your lad using a welder … get him one, plug it into a 13amp socket and get him welding. I doubt you will end up drawing more than 10amps with the machine set at 80-90amp and that will do you fine for most steel you will use
Seeking advice re standard of roofing work
markc replied to dave1899's topic in Roofing, Tiling & Slating
- 45 replies
Dulux trade will go over most things in one coat, with white I would use anything else. but do you really want a brilliant white box to live in? and does the finish on a caravan really matter?
What’s under the office? Is it free standing or on a solid concrete base. Good insulation will keep the heat in and cold out. But without a big thermal mass it will heat up quickly and keep that heat in too.
Glue or if you have a local place that does plastic welding its even better - quite often small mororbike places have a plastic welding gun to repair fairings. If gluing, reinforce joint with a thin strip of plastic under the joints - helps when people sit on them.
Anyone know what I do with this membrane before laying the floor?
markc replied to Roz's topic in Wood & Laminate Flooring
Turn it upwards, lay floor and then trim back to floor level. This way leaves the membrane with an up stand on the inside to prevent any water travelling back and under the flooring -
If using CT1 or similar then no need to screw or bolt ... assuming floor is tiled / solid. Did once see one glued to vinyl flooring.
Definitely! CT1 or similar flexible sealer/adhesive. stops rocking, creaking and breaking tiles.
go for the 140 and run 2.5mm rods, usually around 60-70A, machine will run pretty much all day and not pop a 13A fuse Assuming your 2.5mm supply cabe isnt 100m in length etc.
Hacksaw blade slid underneath .. works a treat
