Everything posted by IanR
I've never posted anything about mine in the Barn Conversion section as the stuff I've posted about hasn't been unique to a Barn Conversion and I can't think of much that would be. You're in the right place and I'm not aware of a more relevant forum. Welcome.
Members' experiences of Timber frame and slab suppliers
IanR replied to TerryE's topic in Timber Frame
Censored? I can't locate it either. -
I used linear gullies, same method to install a central drain. Discussion on a previous thread:
For me Touchwood were slightly cheaper on the Frame, but in the same ball-park, However the slab, AFT via Touchwood, was much cheaper than MBC.
Don't forget this thread: -
Insulating to Min Building Regs
IanR replied to Ian's topic in Energy Efficient & Sustainable Design Concepts
I remembered it as 3. I know Airflow don't advise their MVHRs are used in properties with a figure of more than 5.- 26 replies
Floor, Roof, Windows and air tightness all appear to exceed Regs, or are the Welsh Regs more stringent than the English ones I'm familiar with.- 26 replies
Plaster board ceiling gradient?
IanR replied to 8ball's topic in General Self Build & DIY Discussion
I'd go with another layer of 12mm on the new side. Can't see that you could loose 12mm without a physical step. -
We've got a Monarch system, Ultimate Master is the model. We've not had a softener before and previously really suffered with limescale on everything plumbing related, ours is a moderate-to-high hardness area. Really like the result of having a softener in the system, so far no signs of any limescale after 6 months (apart from slight milky residue on glass shower screen that wipes off), and very noticeable how little soap is required. I thought we were using a lot of salt, ie. 25kg covers approx. 30,000 - 35,000 ltrs, but on research that seems about right for an electronic softener. While the salt shouldn't get into the supply for the house I have noticed on one occasion a heavy brine taste on the softened water. This surprised me and I'm working through the installation instructions to make sure everything has been done correctly.
VAT on builders purchases
IanR replied to Mark A's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Welcome, As long as you are building a new build for yourself or family member to live in then you are almost correct. Builder 2 will invoice you inclusive of VAT at 0%, so you will not incur any VAT on materials (or labour) he uses on your build. -
Why not just bung the air tester a drink and save all that work!
Why are most PV installed "portrait" rather than "landscape"
IanR replied to DenkiJidousha's topic in Photovoltaics (PV)
They look like a standard roof-integrated system. Could you post a link to the system you use, that fits in-between the joists, I've not seen that before. -
It's a win-win with an insulated slab, not only out performing "traditional" foundation systems, but costs less also (for a flat site like mine with a reasonable bearing capacity of the sub-soil) IF there was an issue, I'd only have myself to blame, but the tails are no higher than is normal, the photo is taken at ground level to exaggerate any out-of-flat of the slab so the appearance of the height of the tails is a parallax effect.
There's quite a few here that have a different experience. Here's mine, 465m2 of C35 reinforced insulated raft, with UFH included and ready to take final floor finish. U Value: 0.1W/m2K Might be worth having a read up and update your knowledge on Insulated raft/slab foundation systems. Here's a few links, if you search Google you will find many more. http://www.advancedfoundationtechnologylimited.co.uk/our-product/ http://www.springvale.com/products/groundshield/index https://www.kore-system.com/kore-products/floor-insulation/kore-passive-slab/what-is-kore-passive-slab http://mbctimberframe.co.uk/passive-foundation/ http://www.isoquick.de/construction-process.html Edited to add: Very cost effective as well.
Just in case you've not looked at it before: Excellent with UFH!
3G glass supplier for fixed rooflight
IanR replied to divorcingjack's topic in Skylights & Roof Windows
Is that detail complete? What's fixing the glass down? is it the metal angle on 3 sides? For me, this needs a re-think... Not just a weak point, but condensation will be running down the inside of the up-stand, I would have thought... It also looks a difficult detail to get airtight - the corners will be especially difficult. Are you specifying a black-out around edge of the glass. If not I wonder if the "normal" compressive sealants are UV resistant Personally, I'd go with a framed glazing unit as it gives you a chance of breaking the thermal bridge between glazing and upstand, and somewhere that get's covered to hide the airtight tape. Then I'd insulate the up-stand inside and out. I used insulated plasterboard internally and celotex externally. -
Per m2 cost discrepancies, enthusiasts v. national figures.
IanR replied to epsilonGreedy's topic in Costing & Estimating
What are you saying here (the bold bit), are you saying that once you have made a claim you won't be able to reclaim any further VAT on the build, or, once you have moved in you won't be able to reclaim any further VAT on the build. You can only claim once so the former is true, but just wondering if you have seen something that states the latter. I believe that once you have a completion Certificate you can't claim any VAT incurred there after, but hadn't seen anything similar regard an occupation date. I'm just doing my reclaim form and they do ask for an occupation date. -
I believe the rules are that if you are adding more the 100m2 to an existing residential unit then CIL is owing on the extra. But check the rules, not sure if that was a local rule or a National one. The exemption is easy to get, but you must take the appropriate actions before commencement and after 3 years. An out line is acknowledging that you are responsible for paying CIL, then giving notice that you are about to start, which must be before you do start, and then confirming after 3 years that you still reside at the address. But read the rules to check how they apply to you. Edit: cross-posted - I see that your LPA haven't implemented CIL yet.
I have an Airflow DV1100. They've been mentioned a few times, It was good value for what I needed. Well built and good service from Airflow themselves. A very comprehensive design service that is free.
- 2 replies
- mvhr units
- airflow
I went to Airflow. They supply only, via distributors, so you'd have to self-install or find your own installer. They were cost effective for me, but I used a small commercial unit instead of two large domestic units, so don't know how their domestic units compete. They offer a free design service which is very comprehensive. Although do charge for future changes if you start changing your requirements, and no commitment is necessary. From the systems design, they provide a full Bill of Materials and a target RRP that you should be able to do better than from their distributors.
VAT on CCTV
IanR replied to Badger's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Unfortunately not, It's specifically listed as not allowable. -
Insulated foundation ( passive slab )
IanR replied to Russell griffiths's topic in Building Materials
Even at the localised 200mm thick EPS below the beams the U value is still better than Building Regs, so I wouldn't characterise it as cold spots, and certainly not "majour". But it does need to be taken into consideration when calculating the whole floor U Value, just as timber fraction does when considering the whole wall U Value. Taking my floor as an example, I have a 475m2 slab, of which 79m2 "only" has 200mm EPS underneath, due to integral beams. But 396m2 has 300mm EPS underneath. So 83% at 300mm thickness and 17% at 200mm. The overall effect on U Value is quite small. Your suggestion is to remove the top layer of EPS and have the 100% of the floor with 200mm EPS. Still an OK U Value, but not as good as good as keeping the reductions localised. It's really not a lot of work to set out the EPS formers. I believe AFT allow 3 days for 3 people to get from compacted sub-base to concrete pour for an average slab. There's really not a lot of work to do the whole floor with beams, so very little to save by not doing the beams. The additional reinforcement would still be required to strengthen the slab where the load bearing walls will be sitting. -
I have a quote from Kore that puts the cost of 1 cu m of EPS100 at £58 delivered. I paid £96 for 1 cu m of C35 concrete delivered. -
EPS100 is quite a bit cheaper than concrete per unit volume. It's not stupid, but if you're happy with the U Value that 200 EPS provides, and you have the bearing capacity in the subsoil that can take the higher pressures from the line and point loads, why put in the extra concrete if it's not required? The localised 200mm thick integrated beams are very easy to produce, you just leave a gap of the desired width in the top layer of EPS, so there really isn't any extra labour needed to produce them. Since UFH is generally included within the insulated slab, there is a benefit to keeping it "thin" - to keep its heat-up time as low as possible. Edited to add: I have an AFT engineered insulated slab, which is on similar principles to the MBC version. -
Welcome Albert. Has your Prior Notification been submitted & approved? It's the same route I went for my "modern" cow-shed conversion. There was a real lack of knowledge with both Consultants and Planning Officers on how to apply the rules, 3 years ago when I went through it and I'm not sure it's much better now.
