JohnMo
    196
Everything posted by JohnMo
  1. You can run all your pipes in plastic barrier pipe, except within 1m of the boiler or hot water cylinder. You could also leave the gas boiler there, as a fall back if you have maintenance ongoing on the ASHP, or in very cold weather when the cop is less than ideal. A hybrid system.
  2. We went 3G wood. Eucalyptus, factory finished. Main reason they are made about 3 miles from the house. They came measured, manufactured and installed. So basically any issues were down to them to sort out. Happy with the results. But wasn't cheap.
  3. You can get wood coloured marker pens for that specific type of job. Or use you kids felt tips and then wax
  4. Your all lucky, our front foundation width was closer to 2m wide and reinforced. All the fun you have an a sand hill.
  5. Used 90mm to keep velocities down, managing to use a single run where in 75mm, it would have been ideal to run two runs to the outlet. No issue getting bits.
  6. To answer your question, structural calcs would need to be redone
  7. Schools and COVID precautions are not really appropriate settings to aim for in a living or sleeping space. My recommendations are taken from. https://www.paulheatrecovery.co.uk/air-tightness-standards-testing/
  8. eBay - GRANT HPID6 AERONA³ AIR SOURCE HEAT PUMP 6kW INVERTER DRIVEN ASHP inc controller £2k. Others available from £1200. 300l uvc pre plumbed £1k. £1k for stuff and install. My price does not include UFH or radiators.
  9. Or buy one yourself at the time get local plumber and electrician to install. £3-4k all in, instead of £15-17 being quoted on other threads, they may get a fair bit back over 7 years, but have to spend now.
  10. I would strongly suspect 4x2 3mm wall steel (not iron) over 3m will sag quite a bit with it laying flat. 6 or 8mm wall would be better, the calculations would have to be done for wind and and snow loading etc. But it needs to be designed.
  11. £150 applies to England and Wales, NI, Scotland will be announced by Nicola.
  12. I would look up passivhaus recommended flow rates and use that as the minimum. Oxygen levels will never be the issue. You need to worry about CO2. CO2 in bedrooms can be the worst. Get a monitor, tweek flows, monitor bedrooms, somewhere around 1000ppm or below should be the target. Once you have that move monitor to living room and check that also. I have our living space at below 800ppm. So if we have guests CO2 levels don't get too high.
  13. We have a flat section at the apex, but it's painted white, there are no lights pointing at the apex, so you just don't notice what up there. The big windows at the front grab the attention. Long spans equal either structural steel or glulam beams. Our glulam beam are 450mm deep. So even with 350mm insulation, you still end up with a small flat spot. We are Scotland and the outside is covered in sarking board, breather membrane, then slates.
  14. BER say DHW allowance for calculating should be 4kWh per day for 2.4 people. So there is a big over estimate on DHW, unless you have bedding for about 10 people. Did the people doing the heating calculation have the wall, floor and roof build up? Also did they have your postcode for allocating degree days for the heating calculation?
  15. Shouldn't have an undue affect on anything, but the flow meters will not read correctly, as you have noted. Not sure how they balanced the system, or if they did? May be worth fixing to allow correct balancing. If you are changing the pipes around, install isolation valves on the hot and cold pipes to make any future maintenance easier.
  16. Same with us, pretty much the standard in Scotland. You need to use tapered edge plasterboard, not square cut.
  17. Also missing from your drawing and worth noting if you are doing any calculations, is there will be an insulation upstand from the insulation below the screed, to screed top, against the wall, I used 70mm PIR. But is more normal to use 25mm
  18. If you already have gas and a 32kW boiler, just hook up to your existing system, job done. Not sure why you would install an ASHP just to provide the UFH loops and keep the gas for DHW.
  19. I always found them overpriced, so never used them, always felt ripped off.
  20. The way I looked at this. The thermal bridge you are mitigating is downwards to the ground. Comparing Marmox and Thermalite "R values", Marmox is approx 3x better. But thermolite blocks are more than 3x as thick (215 compared to 65). So the resulting u value is better for the Thermolite block, certainly no worse. Thermolite easier to install and get hold of, cheaper to purchase, win, win.
  21. Why does MVHR need complex control or even coupling to home automation. It's supposed to run at a constant flow 24/7, except when on boost? My option is you are making thing complex for the sake of it.
  22. Did you add anti freeze? Either way not sure there will be an issue. Tap water is treated with chlorine, so any bugs would be killed. Once you get ready to commission you will be flushing to get rid of air, so water will be replaced anyway. If your UFH water goes through a boiler of any sort you should use the manufacturers recommended chemical treatment.
  23. I have a jacket for my buggy, keeps you well toastie. There was an article a few years ago, about heat poverty. This women never heated the house, just wore heated under clothes, for a few pounds a year running costs.
  24. And a big jumper. Or heat your body, look at motorcycle and walking body warmers, battery powered. Then you can what ever temperature you like, for way less effort and expense.
  25. No more like a concrete matrix. You can do a render direct to the outside. We did an internal parge coat (sand cement and lime) then battened and plasterboard with taped joints. Outside is mix of stone slips and vertical larch cladding.
