Everything posted by PeterW
I've never seen a Labrador with a wheelbarrow but I have seen some real dogs on a night out in Swansea .....
Bathroom Mixer repairer required please ?
PeterW replied to Fallingditch's topic in General Plumbing
Remove the aerator (12) and ball joint (11) and the fixings from the outlet - look into the body and see if you can withdraw the tag (9) from the body releasing the mixer body. Grohe taps have something similar - that sometimes needs levering out too... -
Planning permission and boundaries & ground level
PeterW replied to Carrerahill's topic in Planning Permission
Doh ..!! Never considered that ..!- 21 replies
- setting out
- permissions
I think it's the first bit that is key there @Stones - duly authorised in writing. I'm not sure if they can just rock up with a tape measure for a wander but I could be wrong ..! Welcome to the minefield of planning legislation ...- 21 replies
- setting out
- permissions
1+1 gang and mixing on site ..? Reckon we are 230 a day but we have all pointed and full filled as I like them looking pretty ...
Ah yes apologies you are correct...! I was treating it as a private path on a property from the description.- 21 replies
- setting out
- permissions
Private road or one with public access...?? Council have no right of access to private property so even if you did build it closer unless they took enforcement action they cannot access your land to prove it...- 21 replies
- setting out
- permissions
Floor Build Up: from theory to practice
PeterW replied to ToughButterCup's topic in General Flooring
That's a very good price too ..!!! Set into the floor, it looks the dogs danglies..! -
Saving Money by Trade Accounts
PeterW replied to Ferdinand's topic in General Self Build & DIY Discussion
My merchant account with MKM is as good as trade - better in some places. I have Wickes and TradePoint anyway, local timber merchant thinks I'm trade anyway so I never question that one ...! -
22mm tray plus 3mm adhesive isn't unusual - and ya get 25mm... -
Fitting concealed shower valves and taps - tips?
PeterW replied to jamiehamy's topic in Bathrooms, Ensuites & Wetrooms
Use plastic ..! Doesn't need to be tightened up then ... -
Glue it and 35mm staple to hold while it's drying.
So this is tile warming not room warming ...?? 25mm to play with ..?? 10mm tile 2mm adhesive 6mm SLC with heat wire in it 6mm thermal board leaves you a mil to account for floor unevenness .... -
Is this electric over a cold slab ..?? -
28mm pipe fits into 28/25mm Armaflex that feeds into 80mm duct ... or 22mm pipe fits 22/25mm and 68mm rainwater Both are DIY
Appliances: brand new or brand name?
PeterW replied to Crofter's topic in Kitchen & Household Appliances
Have a look at Amica - been quite impressed with the quality of them and pricing is good -
There is a BIG difference between formwork and ICF...!! Formwork is either temporary wooden or steel shuttering designed to retain the concrete mass - ICF is just an outer insulation shell and normally needs additional bracing to retain the pour. I've never seen a manufacturer of ICF recommend a poker used on their product and most actively discourage as a poker touching the side of ICF will most likely blow a hole in it. If you have pump grade concrete it usually includes various chemicals to make it flow - air in pump grade is highly unlikely as its much more fluid than normal concrete. The issue is that because of this if you vibrate it too much then it will separate the aggregate and it will become weaker.
Have a quick search online @jamiehamy as they can be had a bit cheaper -
Installing a concrete lintel, reassurance please
PeterW replied to 8ball's topic in RSJs, Lintels & Steelwork
Give yourself 25mm each side unless you can guarantee it's perfectly plumb ... -
Utter newbie questions about financing a self-build
PeterW replied to dakid's topic in Self Build Mortgages
Electric gates and control by phone is where it's at ........ 7:30am mortar delivery sorted from bed ... -
Shouldn't need it really - blocks will hold up, butter the lintel well and the wedge it into place. You are leaving enough space to get the frame in with some room for alignment aren't you ..? -
4:1 by volume will be fine - don't be tempted to use rapid set ..! you can buy the bags but they are usually slightly weaker. -
Easy - just go North !! South of London the prices are silly...! You can get a plot near Grantham / Newark to build on for around £275k, that house would "fit" well in a semi rural plot and £375k build gives you £100k for contingencies and an East Coast season ticket for 20 years...
Make your life easy... https://www.plumbnation.co.uk/site/hep2o-male-adaptors/?gclid=CjwKEAjwxurIBRDnt7P7rODiq0USJADwjt5Dzd74qVsfugO8BwtyxI7Qkj7_rsSfRlHQ-6nGj87-sRoCLULw_wcB Hep2O HX29 in various sizes, screws straight into the brassware and makes it push fit. -
Any chance of knowing which ones as that makes a difference... Grohe have their own way, as do others
