Triassic
    6
Everything posted by Triassic
  1. I need spreader plates, where did you get them from?
  2. I was also thinking about buying a Tesla at the end of the build using the money Id saved. Looks like I might be just about able to buy a second-hand electric bike !!
  3. I'm with you on that one, what's a £100 and a weeks delay in the grand scheme of things, nothing worth worrying about! Just think of the poor buggers on Grand Designs wasting thousands digging holes for over complicated foundations or buying taps at hundreds of Pounds, because they look nice!
  4. https://www.ebay.fr/itm/TOSHIBA-CARRIER-B036601H03-Carte-electronique-/282837755180 The postage is listed in this one.
  5. @Gav_P Did you manage to get the board working. @joe90 has a similar problem and would be interested to know how your progressing.
  6. You’ve got to wonder if the mains voltage hitting the board has killed it !? Sorry......
  7. And the top, bottom and sides in plane and the mosaic tile at the back, set on a thick bed of adhesive on one side to get rid of the depth discrepancy.
  8. If it were me I’d tile the window bottom and each side of the window to match. Then you’ll have somewhere to put your wine glass and not leave red wine circles!
  9. @Stones Thanks for an interesting and thought provoking post and response to my question. I’ve spent the best part of three days going back over around three years of posts covering every approach to providing heating and domestic hot water and I’ve come to the concluding your approach is the one for me. Just a final question, what is your floor area of your UFH?
  10. Fingers crossed. Do you have a diagramme of your equipment set up?
  11. I'm sure the stuff I used in the last house was round in section and each wire was made up of multiple strands of copper wire, thus more flexible. https://www.edwardes.co.uk/en/products/1-0mm-3185y-5-core-white-circular-pvc-flexible-cable-50-metre-coil?utm_medium=google_shopping&utm_source=google&utm_campaign=google_shopping&gclid=Cj0KCQjwrszdBRDWARIsAEEYhrdsVf9p7MVDmx0Loc6ZcYHrXKEMsqvzubrgdkF77AT5UEugnwKVuD0aAmYnEALw_wcB
  12. Maybe he could rent the land, as an alternative to leasehold, the rent could then be set at a peppercorn rent of say 10p per year, paid in advance. Keep the receipt!
  13. I asked this question last week, here is the best answer from a sunamp owner.
  14. @Stones Great blog post, Do you go into detail around your calculations elsewhere, as I need to sit down and go through my own scenarios and make a final decision on what kit I actually need and how big? Up to now it’s all been like fantasy football, but as the TF kit has been ordered I need to finally decide on my actual lineup.
  15. I’ve not got many muddy bits, however I kept some rolls of carpet cut into 3 foot wide strips, these get rolled out as and when there’s a problem, it’s helped keep the mud down.
  16. Gloworm Eosorb tchnical manual https://www.jhplumb.com/system/brand_attachments/1435/original/Clearly_Heat_Pump_Technical_Guide.pdf
  17. If all else fails, use muscle power, 6 strong people will easily shift them into place.
  18. We had a similar problem. We found that moving the flue exit from the rear hole in the stove to the top exit hole cured the problem. Smoke doesn’t like bends it wants to go straight up.
  19. Same here, there’s no way we’ll be finished by April, so we’ll fit the PV ourselves and just use the excess power ourselves. We will also fit the ASHP ourselves to save money.
  20. Just what I need as I’m about to start researching my requirements. Just a though! This is a Good Practice Guidee, are there others, if so, where?
  21. Might be Munster Joinery.
  22. Open mesh steel flooring https://www.google.co.uk/search?client=safari&hl=en-gb&q=open+steel+mesh+flooring&spell=1&sa=X&ved=0ahUKEwiJo5qwxeLdAhWCK8AKHUUZAk4QBQghKAA&biw=375&bih=538
  23. Found the British Lead flashing fitting guide and thought it might be of interest to some here. https://www.britishlead.co.uk/basic-fitting-guides
