You may find that you need to treat exposed timber to stop spread of flame not make it fire proof, we are single storey and this is what bc have asked for.
If that Nicholson’s stuff is a bit pricey, even though it looks very good, you could probably get a support tray folded and add an insect mesh, then lay your lead over it.
Nudura icf
Russell griffiths replied to Russell griffiths's topic in Insulated Concrete Formwork (ICF)
No, like chalk and cheese. -
Not sure I see that as a plus, mine is 150mm core and I look at it sometimes and wish it was thicker.
You will need a hidden gutter detail at that junction, or soakers it depends if I’m looking at what I think I am as it’s a poor picture to be honest.
First version, second is hard to drill through and inject the resin, with the tabs on the sides you can see what your doing.
Phone up Redlands and ask why you should use their product instead of the Marley one. I have done this with a number of companies, I like to be frank and I like frank to the point answers.
I personally think that 80mm is very over the top, but that’s for you to decide. 145kg is the weight of two men sitting on top of those brackets plus all other timber. Your original brackets where going to be 40x40 i think i would go with 50x50 box 3-4 mm wall thickness 8mm plates to wall with 13mm holes to except 12mm studs chemical fixed avoiding brick joints your latest drawing looks good, I would notch those side verticals a bit deeper to carry more load on the brackets. Treated timber c16 not that crappy csl
Two things, don’t like those gallows brackets, I would look at the angle iron version available from most builders merchants. I would look at the brickwork and find how stable it is to take fixings that bit under the bay window looks a bit suspect, according to this it may pay to get a couple of brackets fabbed up so you can get fixings lower down to pick up better brickwork. I have just just had a couple of posts fabbed by a local steel company and they where cheaper than expected.
Angled wall: Pretty, but worth it?
Russell griffiths replied to puntloos's topic in New House & Self Build Design
I suppose the big question is do you have planning in place ? what do you think will get passed and what won’t. -
Our last house was shaped like a Z so lots of angles but it cannot be random they where specific parts of a 90degree corner, so two 45 opposite each other and a couple of 22.5. You will have real dramas with internal corner beads and external corner beads if you just pick some weird angle. It worked very very well in a long hall with an off set door at the end, took a fair bit of sorting out on paper first. Cost, allow a lot of extra dosh for that roof. -
please.
hydraulic stone cropper wanted
Russell griffiths replied to scottishjohn's topic in Tools & Equipment
So what, who needs a 12 bed mansion very hard to re sell, build what you want, -
Why not keep it on site, do one house but half stone half render around an icf shell then sell off a couple of self build plots and supply the stone to do their bottom half. That house looks huge, surely you will have more than you need. -
Why not just sell it on as is to a stone dealer, less money but no agro a bird in the hand and all that you will have enough to do, get them to demolish and remove from site. -
Can you tell me what swung your decision to Isotex, and what other products you looked at. Cheers russ.
All wood Swiss house with no insulation
Russell griffiths replied to Temp's topic in New House & Self Build Design
Er, yes. -
I wouldn’t think so surely the survey was for demolition purposes, not what you intend to build, I would keep quite and get your new plans in remember you dont want any new bats so keep the place spotless and fill in any holes, alternatively get it knocked down quick if you are happy you have planning in place.
Trying to find if anybody local ish, has any spare blocks im in Cirencester Gloucestershire and looking for 4 blocks if anybody has them. Bit of a long shot cheers russ.
Boxing out ICF overhang
Russell griffiths replied to magnethead's topic in Insulated Concrete Formwork (ICF)
Glue and fix first layer using 150mm fixings, countersunk into eps by 50mm glue second layer and fix using 220mm fixings countersink accordingly. Is that a pattern on the concrete or mesh, I thought it was mesh but it could be the fuzzy pic and my poor eyes. -
Self powered or hydraulic from a tractor. -
I like the idea of two layers of 150mm eps all glued and screwed on. Then render underneath. On a different topic, are you happy with that reinforcement showing through the concrete. -
They wouldn’t have ya.
