Russell griffiths
    65
  1. I had to buy a whole pack of XPS 500 it was only £75 and did one 5m patio door and two single doors.
  2. Why not use a clear preserver first on all sides before fitting.
  3. How will you stop those feet sinking into a felt roof in hot weather definitely GRP.
  4. Good god NO just fill it back in and get on to the next job.
  5. If you think you will be building the internal stud walls then yes I would get one. On a different theme, if now your roof is going to take a bit longer make sure your trusses are stacked flat, they have a habit of going funny shapes. Can you not get a crew crew of two lads who do it all day long to chuck them up for you one weekend and let you finish off some fiddly bits. There is a Facebook site called timberframe jobs, it always has people advertising for crews.
  6. Will you be putting on the roof battens ? will you be building the internal stud walls ? apart from those two jobs I wouldn’t bother, I cannot see your roof being overly heavy in the nail dept, if the trusses are all pre fabricated then it will be a lot of truss clips and bracing i like tools so I have just brought the new dewalt one, just depends if you can justify £450-600.
  7. I ran 32mm mdpe water pipe in 80mm duct, it allowed for insulation around the pipe at the point it comes up through floor, you will pull 25mm in with your eyes closed. 110mm underslab, don’t run small 40-50mm under there.
  8. Seen it done to build a swimming pool sprayed it on, high pressure 30-40mm hose, small stones in the mix one man spraying, one holding the hose behind him as it kicks a bit, then they let it go off for half an hour and scrape it back flat.
  9. Why not put a drain in the plant room. It will cost pennies, and take an extra couple of hours that’s all, better to have it than to need it. I have just changed 20m of 32mm water pipe and pulled and pushed it through the duct, two man job but very straightforward, install all ducts with pull cords in them or get one of the tools BT for pulling cables through, since buying the cable pulling tool I no longer need to leave pull cords in as I can push the fibreglass rod 50m through a duct.
  10. That spec looks like a poor loft conversion in the 90,s, it will be cold. Unless some serious internal insulation is done as well as good air sealing.
  11. My other place was boarded with sheets that went from wall to wall no butt joins so a 4.7m long wall had a 4.8m sheet used, fitted across the wall so one tapered join at 1200 high. I used boards on my ceiling that where 1200x 6000 England is just not set up for this style of boarding. I think i had 3 butt joins in the whole house, you can buy a butt joining strip in America, it is a piece of OSB that you screw on a butt join, it is tapered so it bends the board inwards to allow jointing compound to fit in the recess.
  12. Not yet, I’m very new to this router thingy and just wanted two bits, when I get into door fitting and the second fix stuff I will do a bit more looking. What do you suggest?
  13. I just brought a couple of TREND router bits, very good but stupidly expensive.
  14. Yes, I see this misconception all the time, and it bugs me a bit, if you had a poor finish then it was down to not being done to a good standard and not following correct procedures, English style boarding is not good for taping, boards are too small, butt joins everywhere, poor cutting around obstacles. You dont build a $2000000 house in America and end up with a poor finish.
  15. I did a bit of reading up before I brought my dewalt, is it a type 3 gun or older, there are a few issues with the type 2 guns.
  16. I have the paslode first fix gun and a second fix also, I have just bought the dewalt first fix gun as it uses the same batteries as my other tools, I would buy a paslode and sell it afterwards or what other tools do you have as the dewalt was cheap as I only needed a bare unit. Remember the gas will play up in the cold on the older versions, so if buying paslode I would buy a new one. Wait it till you buy the stainless brads, you will love the price of them ??
  17. I used one of the fancy membranes with the polypropylene mesh on top i wouldn’t use a standard membrane.
  18. Any reason your posts are uc I would use a 90x90 box section as I believe it will be easier to insulate around and clad over.
  19. I taped and jointed my last house and I will be doing the same on this one, however I’m not sure how much money if any this will save you, you won’t need to have the walls wet plastered, but you will need a good team to tape a join it, you would need a good set of skills to do it yourself. I would price up both options. Do a list of costs for both the options and post it up so we can see if you’ve missed anything.
  20. I think you need to go back to the drawing board with this, what you have is not a warm roof at all any more, you will need to re design as a hybrid system, and get a new condensation risk done. You will also need to work out a ventilation strategy as well as a method to stop moisture from the room below entering the roof structure. Or you could end up with all sorts of mould issues.
  21. Any fire bricks will fit, just trim to size with a grinder, I did mine last year.
  22. I used the green coat plx but brought it pre folded, I got it from a co called metal solutions in Bolton easy to deal with, like the product glad I had agro with Tata as I wouldn’t have found these. Nicer product in my opinion. Been on a winter and summer, very little distortion.
  23. If you seriously intend to sell in 3-5 years I would go. Timberframe on insulated slab, insulation levels higher than building regs, brick or stone skin on the outer, anything unusual will be harder to sell, we are a nation of people who like the idea of all this fancy design stuff, but end up buying a red brick tile roof boring box churned out by mass house builders, they cannot build them quickly enough. Save the fancy stuff for the place you want to stay in.
  24. If your down there, you could come up here and design my pipe layout, no time like the present. What beer shal shall I get in ? what time shall I expect you ?
