Russell griffiths
    61
  1. They all require fancy tools, I may be about to buy a set that I would sell on afterwards, what makes have you looked at.
  2. Old jcb type backhoe thing will spend more time making a mess and getting stuck buy a 3 tonne tracked machine for yourself, and hire in an 8 tonne machine for a week to do the big cleanup and stump pulling.
  3. Simple don’t buy it in bulk bags, you don’t want a price per tonne, you want a price per truckload. Phone the quarry direct.
  4. You can stick a truck load down if you want to avoid them dragging mud out onto the road, but it will be sacrificial and get messed up and will need another load on top for correct levelling.
  5. I really try to support my local shops and merchants, but I’m afraid I have another store. To add to the list of places I just wont bother with. I went into the paint store, I have a trade account, was after a 2.5 litre tin of white primer, I can get said tin of paint for £15.99 in b+q with my trade point card, I can get it in Selco for £15.00. So why the bloody hell hell did I just pay £24 for it in the paint store. Sod em, I shall just sit here every night and order everything on line.
  6. £240 for 10 tonne loads delivered, that’s in an eye watering expensive part of the country, even though it comes out of a hole 10 minutes from my site. 12mm 20mm 40mm clean stone.
  7. You can buy air sealing liquid in a 5kg bucket, it is like a thick paint with fibres, 2 inch paintbrush and off you go slap it on everywhere. Easy peasy.
  8. I would say no, is there any chance of water sitting on top of the steel or is it completely covered.
  9. It is a nhbc requirement as peter said, I suppose for £20 of tape it’s worth doing.
  10. Evening all. If installing plastic pipes in a wall is it a requirement to fit a metal trace wire or foil tape, so you can detect their location with a stud detector.
  11. Yes. What are you thinking.
  12. Horizontal Cladding vertical batten treated cedar air gap top and bottom. Stainless fixings.
  13. @Nick1c what did you use as mesh, I have rolls of 100mm wide stainless mesh and it feels too flimsy. I would like a mesh I can fold and it holds its shape.
  14. Anybody got any recommendations for priming mdf , particularly edges that have been machined. Got lots of fitted furniture and doors so looking for something available in big tins not little 500ml for small projects. Price not important, I like good not cheap. Ta very much.
  15. Has anybody got any details or pics of cladding, I’m particularly looking for the starter track or the lowest part, how to include insect mesh and maintain an airflow behind the cladding. Would like any pics of how you have finished around windows. Cheers all.
  16. looking at this pic @Nickfromwales it was mentioned that those short copper pipes where to maintain the integrity of the fireproof layer from the plastic pipe melting in a fire in the plant room. Does this only only matter if the room above is a HABITABLE ROOM if the space above is a loft then is there any need to maintain the fire proof layer. i have had a similar situation with building control, I have a steel beam that is visible in my front room, it does not require fireproofing as it does not support a habitable area above, just a roof, as my place is a bungalow I have no habitable areas upstairs.
  17. Why would you need a warranty, what bit for?? or are you talking about if it caused a flood.
  18. The cheaper ones I found take a Euro cone fitting, so cheaper manifold but have to buy 4 euro cones per manifold. Those jtm ones are cheaper and I think they are made by reliance valves who know there stuff.
  19. Will be all plastic. @Nickfromwales
  20. I’ve looked on line all week, best price is the plumbers merchants at £42 for a 4 port, you can find them cheaper but not come with no fittings, so the time you add 4 fittings your back to £42.
  21. cold pipes running around the house. All pipes on the warm side of any insulation so no freezing issues, is there any pointing lagging cold pipes.
  22. Really it’s a bloody great valve turned by a flat head screwdriver, I spotted it instantly when I installed mine.
  23. @LA3222 have a look at illbruck site, you don’t want silicon you want the air seal liquid in the tinfoil tubes I think the code is 925, its a black/ blue paste the thickness of runny custard you squirt it in with the gun and then use a paintbrush to smooth out. Buy a box of 12 I bet you will find a million places to use it.
  24. Tape, liquid, doesn’t really matter as long as it’s sealed and air and water tight. ILLBRUCK air sealing stuff is probably the toughest stickiest thing I have ever found, I have gone through about 12 tubes now sealing every nook I can find.
  25. What makes you think you can buy an oil boiler cheaper than ASHP dont go by the inflated prices you have had from ASHP installers, the cost is ramped up because they know you will get a rebate.
