Russell griffiths
    65
  1. Surely @dnb it’s not the quality of the batten that needs clarification, but the fixing down method onto the sips panels. You could use the highest spec batten you can buy but if the fixings pull out of the sips then that’s where problems start.
  2. I hope you had some clothes on while filming that @Onoff?
  3. Excellent chaps, another problem sorted.
  4. So are you saying as a quinetic one has no mains power supply I can basically stick it anywhere @Onoff
  5. Evening all. Can anybody point me at some current regs regarding a light switch for an en-suite bathroom. I can do a sketch if you don’t understand my rambling. I would like to put a switch on the bathroom wall just as you enter but I’m under the impression that used to not be allowed and that’s why we have those horrible pull cords, however if I move the switch just 100mm away it would then be outside the room which seams just ridiculous that that would be ok. Anybody understand and what I’m getting at. Anybody know the regs. @ProDave @Onoff
  6. Look at the bright side @£2000 a m you have just saved £30,000++ on your build cost.
  7. I used the Cromar vent 3 pro, don’t buy it from e bay there are a few adverts for seconds knocking about. Have you thought how you will put this on, without installing your battens you will find it hard to reach up onto the roof much more than a metre, imagine standing on the scaffolding with the facia at knee high you can only lean in so much before you end up in the room below, you normally roll a strip out and batten it then stand on these battens to fit the next row. Unless somebody has had come up with a cunning plan I don’t know of.
  8. 3 chisels of varying degrees of shitness the one on the right is nearly getting to the paint tin stirring implement stage.
  9. I just buy a new set for a project, use the good ones on good wood, as soon as you hit a nail it becomes downgraded to a semi shit chisel, then when you hit another nail it gets downgraded again as a tool for smashing and bashing. no time to be sharpening tools, leave that for when the house is finished and you have a workshop.
  10. @Dan F just use the same batten quality that you will use to hold the roof covering on.
  11. No need for treated your trusses won’t be.
  12. If you buy an expensive set it will really pee you off when you drop it and it hits the concrete tip first. I would buy mid range £25-35 set and abuse them, then when you are fitting door hinges get a couple of good ones, too early in the build for quality ones you will only wreck.
  13. No matter how shit my day has been @ToughButterCup little escapades always bring a grin to my face. Keep up the good work ol fella.
  14. I’m a long way off from doing this, do you want to do a bit of research on different types, as I’m sure you have nothing better to do ??. It will probably come in a 25kg drum so I will have a fair bit left over.
  15. I did grp on my kitchen a couple of years ago in January, it was a bloody pain but came out very good with lots of hard work. I have a small small porch to do on the new house and won’t be using grp again, I will be using one of the liquid single component systems that uses a mat just like grp but cures with contact with moisture so removes all of those problems. Have a search around theres a few vids on you tube of companies changing to it from grp.
  16. Not sure I would go to the cost of installing both, if you need a treatment plant then why the compost toilet, if you install the treatment plant it is reasonable cheap to run the pipework from the other toilet to it, you will need pipework for the sinks and showers etc so another 2m of pipe for the toilet will be pennies to put in.
  17. How about a upvc cladding, no maintenance ever.
  18. Get a scaffolding co to stick a scaffolding platform to get access to a point from which you want to work, then a tarpaulin roof over the rest of the structure. Will be the best money you spend,
  19. Forgetting the vat side of things, if you leave that building there how much will it hamper the new build, will it add more inconvenience to the demolition of the old house, how much extra agro will the builders incur working around it. Looking at your site I would think they would want a completely clear route down to the lower level, Just had another look, there’s more room than I remember at the right hand side, so you can forget my comments regarding access.
  20. That’s right, but that doesn’t mean giving up your day job and going on a plastering course.
  21. If you have the salary that you say then there is no gain whatever from doing any of the work, stick at what you do best and just sign the cheques, be a very good manager, and not a poor bricklayer.
  22. @ZacP have you had a structural engineer look at yours yet? From the brief look I had at your drawings I thought you had two walls that will be retaining the ground and forming the structure for the next floor to go on. If this is the case I would expect a lot of re- bar, and even an increase in block size to accommodate a larger concrete core for the strength.
  23. Why are you fitting insulation between the rafters ? have you got a room in the roof.
