You seam a bit mixed up with this, how can you consider making the roof rafters smaller with the high load from a green roof, the roof loading will be higher than normal. Im afraid I don’t like the design at all, green roof is pointless, gutter details are a disaster waiting to happen, leaf debris building up will lead to the gutter no working correctly and water getting into the structure. Nope, not for me I’m afraid.
But remember you said it was cheap ??
- 29 replies
- eco energy
- wc conversion
(and 2 more)
Flashing sits on top and goes up the wall 150mm, I think this height has something to do with rain bounce, any lower and rain can bounce above this height and get behind the flashing, I believe this is a very old regulation and might be a bit more relaxed now, check with building control. Inbetween the pans and the upstands of the sheets is a foam filler, it has sticky tape on one side, it prevents insects getting in and rain being blown up, but allows airflow. I have seen other makes that consisted of a perforated metal trim that you stuck down with sealant and the flashing went over the top.
Going through a block wall with a 100mm duct does not require a lintel unless you had a high load on the point above the duct. Imagine if the wall was built and you drilled a 100mm diameter hole in it, you wouldn’t then install a lintel. But anyway lintel or no lintel you are you are talking about £20 for a couple of lintels so not really any point in even adding that up, put it where you think it will be best used. At the most it will require a 100mm diameter hole in the floor with a 25-32 mm pipe sticking out of it, try to get it close to a wall so it can be clipped up neat. Its next to no room at all really.
Why would taking it to the plant room require lintels. You are talking about a watermain installed into a duct, if the duct is 100mm diameter you would just bridge over it with a block laid flat. I would take it to the point it will be used the most, plant room, the kitchen sink will just have a cold feed to it from the plant room.
Moving Trees and Large Shrubs...
Russell griffiths replied to Mulberry View's topic in General Self Build & DIY Discussion
So are you wanting to move them onto your new plot ? if so get pruning and move them with an excavator so you can take more root than if you where hand digging. -
I have a cold roof ventilated at the eaves and abutment wall, a warm roof will be 175mm approx higher than a cold roof as the insulation goes on the top, my ceiling height is 75mm lower than a warm roof as I have insulation under my roof rafters. So you need to draw draw it out and work out the dimensions you have to play with. cold roof ventilation detail at abutment.
I’m not understanding if it’s a cold roof then your insulation is fitted between the joists, so how does reducing the insulation thickness gain you headroom. Surely the ceiling height is dictated by the joist thickness, not the thickness of the insulation in between the joists. You wont find much to better pir for insulation value versus thickness.
Can somebody do some rough number crunching for me please. There has been a bit of talk lately about block walls with just external eps insulation, so wondered where it comes out U value wise. From the inside out. 12.5 plasterboard 25 mm service batten 150mm dense concrete blocks 130mm eps 100 25mm batten timber cladding. Thanks, oh clever ones.
Mains Drains vs Treatment Plant...
Russell griffiths replied to Mulberry View's topic in Waste & Sewerage
I was under the impression that ladies stuff should not go down the toilet regardless of mains-drains or a treatment plant. Same as condoms, cotton buds wipes etc. -
Can you recommend any.
Here’s one for you then @FM2015, what sort of methods are people using to airtight woodcrete blocks. There are a couple of questions knocking knocking about at the moment regarding this.
Why ripped off, have you any idea of the cost of moving an artic truck across the country. My windows had a £700 delivery cost, plus £700 additional for unloading and positioning on site. The first cost I had no choice the second one I avoided by doing it myself with a forklift. Pick the right product for the job not the one that has free delivery.
Why is everybody hung up on transport costs, surely it all adds up to total product cost the time you get the product to site. Product 1 is £1000 plus £200 transport product 2 is £200 plus £1000 transport. Same same.
Everybody seams so hung up on the u value of one element of there build, yet don’t seam to grasp the fact that it is a whole load of parts of a house that you need to put together well. I have seen timberframe houses with walls with very good numbers on paper, yet when built I could see out to the sky with only the lead flashing forming any sort of airtight element. It really is about choosing a good system and building it well, you can take a standard 100mm concrete block and build it to a good standard with good insulation, or you can take a highly insulated timberframe and build it badly with gaps and joins everywhere. You need to look at a system that is robust with good detailing and good methods of construction.
You use a telescopic vent to bring the air back up to your damp course level. Problems, the trench you have made around the building can collect with debris leading to water ingress through the vents. Poor air flow due to vent hidden under ground. Do you have to have beam and block its a poor floor construction insulation wise.
Airtightness for Durisol, Velox, Isotex builds
Russell griffiths replied to Grendel's topic in General Construction Issues
https://www.british-gypsum.com/~/media/Files/British-Gypsum/Brochures-and-Leaflets/Product-information/Gyproc-Soundcoat-Plus-Brochure.pdf -
Why have you got your airbricks underground, it’s not really a good idea and can lead to problems.
The ultimate Garden Studio / Gym / Shed build
Russell griffiths replied to BartW's topic in Garages & Workshops
You can, but it won’t be cheaper. -
Size Paranoia...
Russell griffiths replied to Mulberry View's topic in New House & Self Build Design
To get to our finished size we both walked around our current house with a pen and paper and a tape measure, we didn’t talk about our thoughts just walked about jotting down the sizes that we thought rooms needed to be. The boot room needed another 1.5m in the width, but we could trim 0.5 from the main bath, we then had a chin wag about it and added it all up, in total we came out at 180m of living with 40m of garage attached, none of our rooms are big, just nice and usable. I think yours is a bit tight. -
Go and have a drive around gravenhill in Oxford there are more external finishes on houses than I have seen anywhere else in the world.
Preventing my garden draining into my foundations
Russell griffiths replied to Andy H's topic in Foundations
Have you considered digging a bigger hole and having a low retaining wall instead of having to waterproof your building walls i did this on a garage that had a height restriction. -
You can search 3/8inch as well, some air con is imperial.
