Everything posted by HerbJ
MVHR air flow rates
HerbJ replied to lizzie's topic in Mechanical Ventilation with Heat Recovery (MVHR)
So, it seems that your original installer did commission the system using a flow meter but did not record the commissioning tests and flow values for the various settings. Is it not possible to call him and try to understand what what settings he used - BR rates = Setting? Boost Flow Rate = Setting? etc? Perhaps he did record all the settings but failed to leave you a copy? How many settings do you have? It seems strange that Setting 2 is the "absent setting" and Setting 3 "living" What is Setting 1 ( if there is such a setting)? Do you have a "Boost" setting? -
I just checked my Commissioning Report and I have misstated some of the settings iI detailed earlier in this post. So, for clarity: Setting 1 - the reduced/low setting , is set at 53% of the BR flow rates. This is the setting that we set for normal day to day operation with juts two of us in the house. Setting 2 - is set at the BR flow rates - we use this if we are drying clothes in the utility room or have a house full of family/friends Setting 3 - the boost flow rate , is at 140% of the BR flow rates and used when using the bathrooms & cloakroom or when doing some serious cooking in the kitchen, with lots of steam/fumes from pots & pans. This is the only setting wen there is any ventilation noise and then only from an extract grill in the family bathrooms.
Hi @lizzie When our MVHR system is boosted by turning on a light switch in a bathroom ( or manually selecting the boost setting), the whole house airflow is boosted. This is fairly standard for whole house MVHR systems and it would add a lot of complexity/cost to only boost ventilation to individual rooms.
We have an enthalpy heat exchanger, which was installed as part of the original installation 2/3 years ago - we have PAUL Novus MVHR. We installed the enthalpy HE because we have a relatively large house (340m2), there are only two of us normally living here. and it was recommended that a enthalpy HE would prevent the air getting too dry in this situation. It has worked well for us We do not have humidistats installed but control boost settings in bathrooms and downstairs cloakroom are initiated automatically when the lights are switched on in those rooms - the controller allows adjustment of the boost run time after the lights are turned off in those rooms (currently set at 15 minutes). If we require greater ventilation when cooking or drying clothes in the utility room, we simply use the boost setting on the remote controller, which is located outside the kitchen.utility room. As I respond to you, the house is sat at 23 C and 38% humidity on the low settings. Our system was set up with the BR values set as the 100% setting and the boost setting at 130% of BR values. We also have a reduced/low settings of 70% BR values, which is what the system usually operates at. We have remote controller for our MVHR in the hall and it is very easy to change all these values from this controller. The removal of the standard HE and installation of the new enthalpy HE should only be a 10 minute job, providing your MVHR unit is easily accessible. (our is in a plant room and we could change the HE it in 5 minutes...). There should be no need for any further adjustment of the system. We also have an F7 Filter on the inlet and G4 filter on the return. Again, we do not change any settings when using an F7 filter.
+1 to this. We also have Gaulhofer windows and incorporated the requirement to meet SBD and BR into my purchaase specification and contract. Insist that the supplier confirms their ability to meet the relevant standards and regulations and make it part of the contract
Yvonne, my better half, was responsible for all interior design and colour selection. She bought a RAL Colour Wheel very early in the design process and carried it with her everywhere. She bought it on ebay - https://www.ebay.co.uk/itm/Original-Ral-K7-Color-Fan-Deck-Swatches-Classic-213-Colour-Tones-Newest-Version-/192590016704 She used it all the time for every decision involving colour or colour matching. She also had a bag of samples, containing a decent sample of everything we had selected for finishes - tiles, wooden flooring, paint sample sheets, curtains, sofa covering, etc etc. Again, that was dragged around show rooms. She never relied on colours on the computer - she always sent off for actual colour samples for everything she was interested in selecting. She still using the Colour Wheel for fabrics for cushions and window seats. We moved in two years ago...
- 19 replies
- bifold
- chartwell green
(and 3 more)
No, you cannot build in the air space above a piece of land you do not own - that is trespass. Anchor Brewhouse Developments Ltd and Others v Berkley House (Docklands Developments) Ltd , the oversailing boom of a tower crane was held to be a trespass over the land over which it overhung. But not sure about the ownership of the two pieces of land? If the two pieces of adjacent land are in separate ownership, the new build could be stopped because of the trespass of any overhanging element of the new build on the adjacent land with the benefit of the covenant. They would not have to enforce the covenant, to take action for the trespass. This would be the easiest way to deal with the problem.... You can sell/lease the air space above a piece of land you own without giving up title to your land. Developers in New York have built massive residential and commercial developments above the railway lines/property in Manhattan - it makes sense where space is land is at a premium!
Not sure of it breaches the covenant but if this separate plot of land is owned by someone else, it would be trespass. See the famous old case Truckell v Stock [1957] 1 All ER 74, [1957] 1 WLR 161, 168 EG 668 . Lord Denning's judgement in the Court of Appeal in the Court of Appeal is very short and clear. I used this case to have a troublesome neighbour's gas flue removed, when we were having problems with our flat Management Company in Torquay.
We have the downstairs as one zone and this is set to 21 °C.it maintained within 0.5 °C 24 hours/day. We tried 22 °C for a few days but decided 21 °C was comfortable temperature, as when we are both the kitchen,/family room or lounge for a few hours the temperature rises quite quickly anyway. The 1st Floor bedrooms and bathrooms have individually UFH controlled zones.Normally, there are only two of us at home and we have the master bed and ensuite at 22 °C ( keeps my wife happy)and the rest of the settles at 19+ °C, without the UFH being activated. If we have visitors, we can adjust bedrooms to suit their comfort levels. We are currently away in Spain. I have set the downstairs at 18.5 °C and the upstairs is set at 17 °C but hasn't been necessary as the upstairs has settled above that though we don't have the MVHR on except for a daily 30 minute ventilation cycle.
- 23 replies
- heating
- thermostat
By comparison, our 0.48 ACH figure equatd to 0.652 m³/m²/h.
Yep , beats us too... We got 0.48 ACH. Not bad for 337m2 house with 3 floors
Great result - keep going
The tale of the sale of our old house
HerbJ replied to Jeremy Harris's topic in General Self Build & DIY Discussion
I hope the removal and completion goes well tomorrow. Enjoy the new house... Have a great holiday -
Estate Car to carry house doors inside, flat
HerbJ replied to Ferdinand's topic in General Self Build & DIY Discussion
+1 @Cambs I have used Hatchbags for my last 3 cars.- 77 replies
- estate car
- load capacity
(and 2 more)
I used a system using Fermacell for the overlay board for the 1st Floor UFH. I didn't need the amount of insulation you're contemplating and laid my system directly onto the OSB floor. i attach the data sheet for the system I used but I think that other similar systems are available. Flooring_Installation_Guide_11.09f.pdf ECO-10U Pt E.pdf
- 7 replies
- under floor heating
- overlay board
Quick check, please..... wallplate
HerbJ replied to ToughButterCup's topic in General Construction Issues
Do you have the same gap at the other end of the wall plate for that planned look? -
We used Knauf Aquapanel, with a Weber Render System which has a complete set of standard details that had to be complied with to get the benefit of the Warranty.
I was on an episode of "Frontiers of Construction" in 2000, which featured a mega-project, Sable Offshore Energy Project in Canada, which I was the General Manager of the Main Contractors Alliance Team. It was North American TV Series which has featured on various channels around the world. Different world, different budget, different challenges but make no mistake doing a self build by yourself is just as hard, just as challenging and a lot more rewarding
My stairs are on the oak & glass end of your spectrum but JEA Stairs do all sorts of stairs - the stairs in their manufacturing facility are beechwood ply = and would be well worth talking to for something special in more economic materials. They have a CNC machine so can manufacture to high standards.
Our stairs were designed and manufactured by a specialist stair manufacturer in Dublin - Jea Stairs, Colin Walsh. [email protected] - see www.jea.ie, The stairs were all assembled in the works, for acceptance, diassembled and shipped to the UK, with the glass balustrades delivered separately. They did a great job and Colin was very helpful. with practical advice and support. I attach a few photos
We paid a fee of £195.
@JSHarris is correct. The relevant legislation was withdrawn in September 2015. We had Conditions requiring compliance with CfSH Code 4 imposed on our Planning Approval granted in March 2015. We successfully applied to have these conditions removed in April 2015. This is the text we used: The RBWM (Royal Borough of Windsor& Maidenhead) Notice of Decision for Application 15/0xxx that granted full permission for the replacement dwelling at xxx was subject to two conditions (Conditions 9 & 10) that required the dwelling to achieve a Code for Sustainable Home rating of Code Level 4, at the Design Stage prior to the start of development and a Final Certificate, no later than 3 months after completion of the development, respectively. As you are probably aware, the Deregulation Act 2015 recently received Royal Assent and will become law in the Autumn (expected September 2015). The Code for Sustainable Homes (owned by the Government) has been scrapped. When the new bill is made law this Autumn the Climate Change Act 2008 will be amended, which will result in local authorities not being allowed to require a Code level for new planning applications. It is understood that local authorities have been strongly urged not to include any requirements for CfSH code levels in the interim period. We have obtained several quotations from suitably accredited consultants to undertake services to assist with discharging Conditions 9 and 10. We have also been in communication with these consultants to clarify requirements, cost and scope. Several of these consultants are now advising us that in their regular contact with other local authorities, they are increasingly being advised that these local authorties would not be imposing the Code on any schemes with immediate effect AND also strongly intimating that if on applications which were recently consented and had such CfSH conditions, an application to remove the CfSH Code condition (s) would probably be favourably received. Have RBWM reviewed their position on imposition of conditions to meet CfSH4 with regard to both future and recent consented Applications? Have RBWM issued any policy or working guidelines on the recent change of legislation impacting their adopted Neighbourhood Plan and/or Supplemnetary Planning Documents? Considering our approval is just for a single house for our own occupation, would RBWM favourably consider a submission to vary or delete Conditions 9 and 10, based on the recent change in legislation? Your early advice on this matter would be appreciated. The response from RBWM was rapid as follows: There are two ways of progressing this, you could still submit the details required to satisfy the condition as I understand that there are still come companies that will be able to hep you with this, alternatively you can apply to remove the condition from the application as there is now no ability to impose the condition. We applied to have the conditions removed and this was approved. It may be very beneficial to you make a similar submission requesting removal of your condition to your Planning Officer.
