Everything posted by HerbJ
Roof tiles that go well with black integrated PV
HerbJ replied to Wagas's topic in Photovoltaics (PV)
Handling transition into garage on raft foundation
HerbJ replied to jack's topic in Garages & Workshops
As you can see from my photos, my slab is flat and the transition to the ACO drainage channel and drive is also flat/level. It is SUDS drive which gently slopes way from the garage and house. I have a 4877mm x 2125mm HORMANN electrical operated garage door, which incorporates a substantial rubber seal on the bottom of the door , which compresses slightly as the door closes.. We have never experienced any water ingress, even from driving rain, and no leaves or dirt blow in when the door is closed. -
i have misleading info in my post above - I couldn't find the actual data when I respond and made a guess without checking ( we only had a paper copy of the original quote and I couldn't find it before I posted - apologies. So in the interests of providing good data, SWMBO has has now located the paper copy and the actual facts are: 1) Landscape Designers would seem to work like architects and their normal basis of fees is based on % of final landscape cost. I attach a redacted copy of Appointment for Landscape Design Agreement, which sets out the expected % Fees, Their % fees vary from 17.5% to 10%, depending on the total costs off the work value. 2) We only used their service for stages A and B but on a hourly rate basis, as we had no intention of using their services for Detailed Design and other subsequent stages. Our cost was £3500 (including VAT). SWMBO still insists that this was money very well spent! 3) Landscape Designers do not undertake actual construction services but would offer project management and contract services to supervise/manage the actual works. ( analogous to architects mode of engagement). 4) For completeness, I summarise the actual landscaping costs ( 2015/2016) , including ground clearance, regrading, retaining walls (both concrete block and wood sleepers), all foundations ( including garden shed, paths, terracing and drive), supply and lay terracing (210 m2), supply and lay SUDS drive (Marshall stone 110 m2) topsoil for planters, copings for walls, all service ducting for cables and water to various points in garden, ACO drains in terrace etc . Rear and side garden and terraces/paths/retaining walls - £45,311(% VAT rated) Drive - £16,450 (% VAT rated) 5) On this basis of these construction cost, the Landscape Fees would have been £4737 +VAT (as a minimum) though I suspect they would not have carried it out a efficiently as my contractor, as we utilised all the heavy machinery already mobilised to site for the main ground works and foundation preparation. So, I have probably been unduly critical of landscape designer fees...... 6) SWMBO did all the planting design and planting, providing many of the plants from cuttings taken from this garden before ground clearance and previous garden. Much of this was completed before the house was completed, as the retaining walls provided a garden separated from construction traffic and builders damage. Of course, we also retained and protected all of the mature hedges, trees and plants during the ground clearance, which provided a great basis for the landscape design/plan. _Appointment for Garden Landscape Design Agreement_a.pdf
@PeterW absolutely correct about pricing and how it ramps up if you require all the services, especially in Surrey and Berkshire, where we built.. For our concept design, the total cost was £3,500 (including VAT which could not be claimed back as it was design service). I will admit to being horrified at this but SWMBO was adamant that it would add value to our overall scheme - she was right, as usual.... The proposed costs estimate for the next phases, including detailed design and then supervision of construction (hard landscaping) and planting would have been £ 6 to 10,000 , depending on the cost of the landscaping works - see my post below The photos I attached were last year. The garden is now looking great, especially with the lock down and all the work that SWMBO has been putting into the garden recently
We used a landscape/garden designer for our garden. Our site sloped up from front to back and side to side. We could not envisage a way forward but the landscape designer developed a clear design that we incorporated in the PP and in construction plans. It was expensive but well worth it, as it provided a clear plan for groundworks and landscaping, which allowed us to utilise the heavy construction equipment as part of our ground works contract. Broadly, they gave us a landscaape concept design, incorporating existing trees and shrubs and using the topographic survey daata. . SWMBO did the planting plans and did all the plant (with a little manual help from me) I attach the concept design, some early ground clearance photos and a couple of recent photos. The company we used was PC Landscapes based in Farnham. pclandscapes_Concept_Design_a.pdf
We cut out the EPS upstand in the garage door opening, pulled back the DPM and cast a level concrete infill. The DPM was just laid under and around the cast concrete infill. Looks like the same/similar approach as @Weebles Looks a bit rough in the first photo but it was leveled with epoxy and a commercial resin floor finish was applied to the garage floor - see photos taken just now. The slight colour difference on the garage floor is just sun and weather outside the garage door ffre -
MBC foundation question. Do I need that much Type 1?
HerbJ replied to rufusmacdoofus's topic in Foundations
I had 16 loads, each 20 tonnes, of railway ballast -
Yes, that what we used. The depth of our this material was deeper for our design 850mm for the front third, then 600mm for the middle third then 450mm for the rear third. our SE specced this because of two oak trees on the front boundary. Somewhere, I have the number of truck loads of railway ballast delivered to site, but I can't ;lay my hands on it. The ballast was installed pretty much as proposed by @PeterW Some photos -
Front garden excavation for drive
HerbJ replied to Margaret dailey's topic in Landscaping, Decking & Patios
Forgive me if this seems rather blunt and harsh but it needs to be said. You must stop and listen to the advice you are being given above and seek professional assistance starting with an experienced structural engineer. The consequence of continuing without a complete understanding of your house foundations and the slope are likely to be catastrophic. As as described by @ProDave below- it may lead to failure of the current house foundations and the collapse of the front of both your and your neighbour's houses, leading to a far larger cost than the original retaining wall. Your building insurance company may not respond to such damage if it caused by your own negligence in NOT take seeking professional advice. Lots of nice people on BH are trying to give you some guidance on how to proceed to plan the work and get some idea of cost and what is possible but none of this advice can be relied on to undertake the work - none of them have seen the job site, nobody has carried out any site Investigation works and they are certainly not structural engineers, qualified to undertake a full design of the works to ensure structural integrity of the retaining wall and ensure structural integrity of the existing house You CANNOT AFFORD THE CONSEQUENCES OF NOT taking professional advice!!! -
There was another thread, to which contributed. I used a local glazing company for supply and install - see full thread below
Which one of his guys did he hand on the business to? I had been trying to get hold of him about something minor but no response - your post explains why....
MVHR in large volume New Build
HerbJ replied to Triassic's topic in Mechanical Ventilation with Heat Recovery (MVHR)
It's a propriety system supplied with the MVHR system by PAUL. In fact, there is no control panel on the MVHR Unit. The touch screen control panel is directly connected to the MVHR by Cat6 cable and there is a special connector at the unit. From memory, there are only 3 cores of the CAT6 cable used. There is no connection to the internet for my model, but I believe that this may now be an option. https://www.paulheatrecovery.co.uk/product/paul-tft-touch-screen/ -
The MVHR is automatically boosted when the light is turned on ( via a auxiliary relay,, and runs for 15 minutes after the light is turned off, in each of the downstairs WC, the bathrooms ( family and ensuites). Our MVHR system has a remote control panel ( which allows us to control all the MVHR settings), which is installed in the hall, close to the kitchen and utility room. So for us, it is a simple matter to manually switch the MVHR to boost when required when coking or drying clothes in the utility room. -
Wetroom - Forget it Pal. Damn and blast it
HerbJ replied to ToughButterCup's topic in Bathrooms, Ensuites & Wetrooms
You'll be fine cutting into the EPS for the shower waste. That's exactly what I provided for on my passive slab for a wet room. i did post on this subject on e-build a few years ago but don't have a copy of that post to share. So, i have provided details again I made provision for a wet room in the Ground Floor WC, though at the present, the shower former has not installed and it tiled over. I checked all this with the SE (Hedley Tanner) and the cutout in the foundation slab was formed with EPS before the slab was poured - see attachments. The plan was to install an ACO shower former and the shower drain at some time in the future, when required. We just have to remove the existing tiles and temporary EPS, rearrange the existing posh cloakroom into a wet room and lay a new tile floor with the former and drain . The waste drain will be installed in the top level of the EPS - really no different to the various conduits installed in the EPS for the kitchen island electrics. 1528-01 Foundation Plan- REV A.pdf Eastcroft Aco Wetroom gully 2.pdf -
Yes, it was attached to my post in the Topic started by @ProDave above that I referenced on Tuesday. To help you, I have attached again. 38167 HRV Volumetric Design 2015-4.pdf -
Yes, that is correct. Stairwells and corridors, etc (rooms not normally habitable are not discounted as such, but benefit (and provide the conduit)from the airflow going from living spaces (supply air) to wetrooms - kitchens, utility rooms, bathroom and toilets. That's why it's important to balance supply and extract volumes. Also , why all doors should have the ability to allow airflow bypass/transfer pat all the doors when closed, . I believe stairwells, corridors etc are characterised as" overflow" spaces" in DIN standards and on my MVHR volumetric data sheets as "Vthrough". That being said, it is not unacceptable to put a supply/extract duct in a hall. For instance, I am aware that @Jeremy Harris installed an extract grill in the his hall, outside the kitchen door to assist with minimise kitchen smells being drawn though this overflow space and into the rest of his house. I haven't found this an issue or need with my MVHR design! -
On reflection, it may have been useful to have an extract in the Dressing Room, but it is a small room after all the fittings were installed and the extract volume would have been very low. A through vent is a good idea . We also fitted an extract in the Plant Room, as an afterthought during the installation, as it was very easy. It is not in the original Design calcs but it is on the Commissioning Test Sheets. -
Yes, I was advised this as well. I have an enthalpy exchanger for the that reason - only 2 occupants usually in a 5 bed house ( 340m2) -
See this Topic in which I give details of the way that my high volume MVHR system design was resolved. My system volume calculations, detailed by my MVHR designer, are included for reference. Looking at your volumes, I think my volumes are much higher and I have a single 450m3 MVHR which normally runs at less than 40% capacity. I hope it helps....... -
Heads Up! Ordering from Germany.
HerbJ replied to ToughButterCup's topic in General Construction Issues
Agree- we bought fittings from all over Europe - Ireland, Germany Poland, Italy, Austria - and did exactly as outlined by others above. No problem claiming the applicable VAT on our HMRC Claim -
I believe this is correct but ONLY if it is invoiced as part of the total package and not separately. We had a staircase designed, manufactured and delivered. It was expensive, with a long design/manufacture schedule to suit our build and we reasonably agreed to stage payments. Unfortunately, Stage 2 Payment was invoiced as Design Service. it was only 10% of the total cost but HMRC rejected the invoice from our claim, because of the Invoice description. So, include the design services within the total package cost and if you are agreeing Stage Payments, make them Stage 1, Stage 2 etc and do not be specific on the Invoices,that is Stage 2 ( or whatever)for Design Services. The Stage Payment milestone achievement criteria can be described in a a separate document ( for, example the contract...)
Setting up / balancing my MVHR
HerbJ replied to ProDave's topic in Mechanical Ventilation with Heat Recovery (MVHR)
That's correct. Sizing MVHR is not an exact science and it seems prudent and sensible to look at various methods/standards to achieve a reasonable and practical design approach - that is what the more experienced suppliers/designers do. Ah, I can see understand your thought process - I believe the md of Paul Scotland is German and he is very experienced, bringing a sensible and pragmatic approach to MVHR design, so looking at the design from both UK BR requirements and DIN standards. It's not something you may get get from many of the UK suppliers!
