Everything posted by HerbJ
You may be alright. I guess it will depend on how weathertight the outside layer of your frame is likley to be? Certainly, OSB was installed on the inside prior to window installation but not on the underside of the roof, which did not have OSB internally, but only VPC layer before the insulation was blown. see photo above of the roof before VPC installed - you can sse the underside of the OSB sarking. I attach a photo of the roof truuses with VPC installed before cellulose installation. Hope this helps
Yes, blown cellulose which was installed on 30 November/1 December 2015 (when this photo was taken). First delivery of imberframe started on 24 September 2015 but we had problems with cranes and erection did not start until 3 or 4 days later. The roof installation was at the beginning of end of October and PV panels installed on 3 November 2015, to allows completion ot tiling. The windows were delivered on 9 November 2015 and installation started same day
i was building my MBC timberframe house at the same time as @Bitpipe. We used the same roofing contractor and window supplier. The most important element before windows are installed is to get the roof and guttering competed and get control of rainwater. So, I ( and I believe @bitpipe) focussed all my early efforts on the roof, facias and guttering being completed, with temporary downpipes before the window and door installation. I actually started tiling the roof on one side of the house, while MBC were still finishing installing sarking on the other side! The internal work on VCL and insulation was all completed in a dry and weathertight house.
Try the Greenbuilding Store for information. They have a lot of case studies that may be useful. https://www.greenbuildingstore.co.uk/category/case-studies/
We talked to them about our house design in mid- 2014 but they seemed a bit stuck in their "Surrey/Berkshire Georgian" style and we weren't convinced they could do anything different. My friends have used them to get PP in Ascot and currently working with them to revise that PP - "Berkshire Georgian" but that it was they wanted!
Ascot Design?
I think you may be asking the wrong question to the wrong person.... The question is really about design of foundations close to trees, specifically an insulated passive slab foundation in your case? The question should be addressed to a experienced structural engineer. The foundationd design will be specific to the site and its parametes - soil conditions, proximity to tress etc. My passive slab foundation was installed by MBC and designed by Tanner Structural Designs Limited, who were a little concerned about its proximity to two big oak tress and other smaller tress and hedges. They specified a much deeper excavation and filling with MOT Type3 stone nearer the big trees than typical for a site without my specific tree issue.
What a journey! Great milestone achieved after so may steps along the way, including a few backward steps..... Well done and congratulations
Heating, Hot water, ASHP, and Sunamp Design Needed
HerbJ replied to Triassic's topic in Other Heating Systems
These may be helpful in addition to @SteamyTea recollections, which I are good. I think (I downloaded them without any references!!!) the attached are Jeremy's orIginal UFH design and his later mods for the SUNAMP. Heating and cooling system.pdf Hot water layout - Sunamp PV.pdf -
I forgot to mention that my roof doesn't have OSB on both sides to contain the cellulose. As you can see from the photos, (and detailed in the MBC Attic Trussed roof detail) there is a 22mm OSB sarking on the external face and the internal face of the airtight membrane held in place with the service battens. I think the photo attached shows the airtight membrane in place before the cellulose was blown in. There are a good few of us on Buildhub with MBC Timberframe houses and this construction detail
Yes and that is how my roof was built and insulated. I've attached a few photos, which may be helpful
I would recommend engaging a qualified electrical engineer/electrician that can review this installation with all the actual detailed data. Given the range of cable sizes and potential costs, it is worth spending a little money to reach the optimum size, underwritten by a qualified electrical engineer/electrician. As usual, everybody is trying to help and giving an honest opinion but none of these opinions may be relied on because they do not have the actual data to work with.
Self consumption: making sense of meter readings.
HerbJ replied to ToughButterCup's topic in Photovoltaics (PV)
I have an Enerphase monitoring system - Enerphase Envoy - that provides this data, together with performance data on each of my PV panels/microinverters and the battery pack (if installed). It measures export energy and power directly from the inverter systems and measures imported power via CT on the incoming main supply at the suppliers meter. Similar functionality is now available as part of more recent models of most PV diverter control systems. My installed PV diverter, which is anold model Solarimmersion, does not have this functionality. I also have a Export Meter, which is a requirement of my FIT contract. I read my meters once a month. I submit meter reading to my Energy Supplier one a month to ensure that my invoices and DD payments are accurate. I submit export meter readings to my FIT company every 3 months on a published schedule, to ensure that my FIT payments are paid promptly every quarter - -
This has been covered several times in the pats 2 or 3 years. I attach an old post which shows a very nice detail employed by @Scotrock. It also shows an alternative detail that used on my house.
Anthracite RAL 7016 aluminium outside and larch inside
Thanks, we completed in late 2016 and moved in early January 2017. There are lots of photos of the house and particulalry the garden on the BH website. SWMBO chose the colour of the doors and Ecowin were very excited that someone had finally moved away from RAL7016 for a front door.
Ecowin/Gaulhofer supplied the Front Doors and all the windows. The garage door is Hormann and the red was a standard Hormann colour, RUBY RED RAL3003. We specified this colour for the front door to match
Directly imported Design, manufacture and installation of Timberframe, including insulation for passive foundation, Ireland Bathroom sanitary fittings, shower bases, shower and taps fittings, bathroom furniture,accessories, Germany Kitchen and utility basins and taps, Germany Various electrical fittings and KNX fittings and cables, Germany Staircase design and manufacture, including glass supply, Ireland fakro rooflight, Poland Furniture, Germany Kitchen Extract fan, Italy Indirectly via UK Agents and suppliers ( tried very hard to import direct but most manufacturers have agreements with UK Agents. and sometimes it's actually easier and the same price to use UK Agents/Importers..) External windows and doors, Austria Internal Doors, Spain Kitchen cabinets, Germany Pantry furniture, France Kitchen Appliances, Germany Garage Doors, Germany Slate roof tiles, Canada Porcelain Floor tiles, Italy Bathroom Wall and floor tiles, Spain MVHR Unit, Germany Paving, India
It may be that the surveyor didn't properly check his work product before issuing to you and your greater knowledge of your plot identified some errors. Feed that back and ask him to correct these errors to your satisfaction. Our survey had similar errors, which were obvious and really important to us for Planning Submission. They concerned ridge heights on the two neighbouring properties - the original submitted drawings did not appear to be correct, from just looking at the houses. Anyway, we requested that he checked and he did ( admitting that he thought he was getting some issues with his instruments when he was surveying the property) - we were correct and the ridge heights were corrected and a revised drawing issued.. The other key learning for us was ensuring the architect properly used the survey information for the site layout, so that all subsequent drawings and plans could be overlayed and all used the same data. This came to light when the engineer responsible for designing all our BC drawings, including drainage, rainwater, and also our retaining walls, identified that the architects layouts did not use the surveyed data. We then had confidence in using surveyor to accurately layout the groundworks (including all the underground drainage, landscaping and retaining walls, and the insulated foundation installed by MBC
As far as I am aware, MBC only design, supply and install the insulated/passive slab. They do not take responsibility on the ground work - that is al the preparation for the installation of the insulated/passive slab. So extract from my quotation from MBC "Supply and fit Engineer signed off Passive Slab foundation system, with a 0.105W/m2.K U-value and Zero Cold Bridges (The client strips the site, installs the first 150mm of stone and the site roadway). MBC supplies and fits 50mm stone for levelling, the concrete, the steel, and the drainage pipes are brought 1 metre from the finished foundation for others to connect to." There may be structural engineering requirements for extensive ground works, depending on the specific site and soil conditions. Some sites may only require 150mm of stone, on which the insulated foundation is normally installed but most require a much more stringent requirements - because of adjacent existing trees my foundation required a 850mm of stone at the front of the foundation decreasing to 600mm at the rear of the foundation. Other sites have required piling.
I have used can strongly recommend Wet & Forget for algae on myrender, . It was brilliant for cleaning algae around the MVHR Exhaust vent, which I know was the subkject of a post on here a few months ago. But it doesn't really deal with dirt from raIn splashes off terracing, coping stones and borders etc
Useful, thanks Slightly off topic, what is the best method of cleaning render? Clealry, power washing is a NO and it cannot be brushed too vigorously either! Can you offer any tips?
