Mr Punter
    27
  1. Yes. See https://planningregister.crawley.gov.uk/Planning/Display/CR/2018/0865/PA3 They just did the second floor. It is on the market https://www.rightmove.co.uk/property-for-sale/property-67028349.html Quite odd that they made the flats fairly large. I think they were influenced by the LA planning guidance, but they could have ignored it and had some smaller bedsits.
  2. I quite like the colour of lime in the mortar. I understood it has some 'self healing' properties too. It does make the mortar more expensive and it is nasty to inhale though.
  3. Yes, you can just convert part of the offices. I have seen a scheme like this completed.
  4. The issue here is twofold - skills and money. Was the plan originally to do most of the work yourself? In terms of cost, what is currently on site is probably only 35% of the total cost, so you need to make sure you have funds of the other 65% to complete this before going further. Did the builder draw more money than they were due? Can you get him back, or is that a lost cause?
  5. A bull floated finish should be fine if he is any good. Do not let it dry out too quickly. Cover with plastic sheet.
  6. Those crash decks are really annoying, especially when you have small rooms / corridors to do. I am sure it could be managed another way but the bean bags are not much better. Did you go for beam and block for structural reasons? I have done timber frame over a basement and did a timber floor, just to cut down on a contractor.
  7. Very very impressive. House and plot look great. A shame Ayrshire is north of Watford!
  8. Kitchen unit quality from the low to mid price manufacturers seems fairly uniform. Perhaps just go for a door and handle you like the look of. They all seem to have fairly standard spec for chipboard carcasses, hinges, drawers and legs. You will need to pay a bit more for decent Blum hinges and drawers. Really it is just a row of chipboard boxes chucked on the wall. No magic with any of them. Worktops, lighting, splashbacks, appliances and flooring make at least as much impact as the choice of cupboard brand. Make sure it is fitted neatly.
  9. I just prefer the pump stations with decent sized outlet pipework. They are quieter and far more reliable. Because this is not the only WC, you don't need to mess around with 2 pumps / service contract etc. No plumber will want to see to your broken Saniflo.
  10. If you can, sink a mini pump station in, that would be best. They have a high level alarm. The outgoing pipework is pressurised and often 2" diameter. It connects into the 110mm pipework. Get one that pumps solids, not a macerator. Avoid Saniflo like the plague.
  11. An insulated concrete floor may work much better than timber. You don't need any airflow underneath and there is no risk of rot.
  12. Hi @Mike W and welcome. I am fairly near you and have had a few properties in B & H. Is yours a Victorian terrace with painted render? What are the plans to improve energy performance?
  13. Contact your insurance company, tell them what work you are having done and ask them to confirm if you are still insured. Often if you are not living at the property you may need a special policy but again, ask them to clarify.
  14. I think your original plan was fine, but you can ditch the heating upstairs. Maybe an electric towel radiator or 2. I am not sure why you need cooling at all. If you have solar gain issues, try to design these out. If there is a problem room, you could install a split a/c unit. They are cheap and pretty efficient.
  15. Yes, lag all the hot pipes. You may also want to undo some of the clips so you can get thicker insulation around. Lag the cold pipes too if you are really bored.
  16. Yes and according to my tilers the tiles need to be really flat. Try pairing them back-to-back and front-to-front to test this. If they are a bit out they will be better if you reduce to, say 1/4 bond stagger. I have heard good reports of tile levelling systems which you may want to look at.
  17. Carry on with your own household insurance and make sure the builder has a contractors all risks cover or similar.
  18. I quite like external wall insulation as it wraps the whole house in a tea cosy. You can take it down below ground if it is EPS. Neither of your quotes sound like external, just internal plasterboard / PIR laminate. Make sure you are comparing like for like.
  19. I have used Weber LAC base coat with a fabric mesh. Base coat rubbed up to a sand grain finish and then masonry paint. Worked a treat and still good 10 years on.
  20. You need to be within 600mm for it to work properly. You also need to keep the nozzle a uniform distance from the what you are painting. The sprayers need lots of prep and cleanup. Any lumps in the paint are a no-no. If the surface is good, the finish is excellent, but you cannot touch in any mess-ups without it showing.
  21. Did you get a price to build your proposed house. Given values in your area it may be a better option to do as large a 2 storey rear extension as you can - a bit like at no. 14.
  22. With 400mm v 600mm centres the actual percentage timber will not be much more. Loads of timber is in double studs at openings, corners, top and bottom rails, sole plates, top plates and locating plates. It will make more of a difference on a long wall with no openings but this is not typical in a house.
  23. I have not seen this anywhere before and have been an NHBC registered builder. The internal partitions will shrink at the same rate as external. Also, some internal walls are structural so you could not install the roof. Could you provide a link as this seems to be nonsense?
  24. Nice project. Can you post up the building regs drawings and spec? I would be really interested in how it all works.
  25. If they take full responsibility it is probably worth paying for, otherwise you can get into a blame game, where it is not established if issues are down to the manufacturer or the installer. Getting an all inclusive price for survey, design, manufacture, preparing openings, delivery, offloading and distribution around site, installation, sealing and sills would be valuable for the de-risking. Better if backed with a decent guarantee.
