Mr Punter
    27
  1. No. The ex building will not affect your PD rights.
  2. Nice and lightweight then at about 700 tonnes! Probably over 1000 when finished.
  3. Get rid of the joists.
  4. There is no point in having any void. It will just make the floor cold and it cannot be properly vented as you are mid terrace and the rear section is concrete. The floor make up depends on what finish you want and if you want underfloor heating, but it should always include min 100mm insulation.
  5. The weight is the same for the Egger. I prefer the finish on the Egger as it is permanent instead of plastic covering.
  6. I thought you had Egger Protect? Anyway, if you are bothered, apply some PVA to the edges.
  7. 50mm overall is just OK +-50mm (difference of 100mm) is not. I note that lots of subbies like to say +- whatever, as it sounds better.
  8. The OSB will be enough to prevent racking. No sure of the nailing centres but 200mm centres and 50mm nails would probably do it. Maybe download a spec from a timber frame firm.
  9. The regs got rid of those in 3 storey domestic years ago, as they were often the Perko slammers which were a H & S risk with small fingers and they were frequently removed or propped open, negating any fire resisting role.
  10. I have used it for soffits on a timber frame. They have a test for a 90 minute ceiling with 2 layers. For external, 1 layer is probably enough as there will not be the same heat load. Ask them.
  11. I have used Resistant Board. Much cheaper than Superlux. It has a fibre mesh reinforcing as well. It has all the certs. They are pretty helpful as well. https://www.resistant.co.uk/
  12. I was not sure if you were after a painted finish? Be careful as some of the door blanks are really heavy - make sure the sliding door kit is up to it - you may find lighter weight blanks available.
  13. There are loads of places that can supply these. Just googled https://www.howdens.com/joinery/doors/howdens-solid-core-blank-plywood-flush-fire-door-obj-sku-family-25306489?productFamilyId=DXF0048&skuId=DXF0048 https://www.lawsons.co.uk/product/2440x1220x44mm-exterior-door-blank-fd30/j05500010 https://www.emerysltd.co.uk/fd30-hardwood-door-blank-c2x27285914
  14. I think that metal studs are going to work much better. They do a 50mm I stud which is good for an independent wall. If you can add resilient bars the sound proofing would be even better and with these each side it would take another 30mm or so. The acoustic matting is good but heavy and expensive.
  15. I would ask the council for an example completed one for a system based on domestic smoke detectors. This will establish what they are looking for so the report you submit will be acceptable. If they cannot produce one then it may not exist.
  16. Just curious as to why you think you need this? I thought mains interlinked detectors - domestic style - were the thing for HMOs and I am not aware of any certificate.
  17. Nice. I will now be able to feel good at the thought of you soaping yourself steam free.
  18. Here is one Vent Axia did for a project for me. All the showers have extracts over.
  19. I would want the unit to run flat out if I was having a shower. I would have thought that having it nearer the source would eliminate it more effectively, like having a kitchen extractor above the hob. Also, the vent pipes in the house would have a fair through flow of air and I would think that the internal surface of the ducting should be well above dew point. I wonder if there is any proper science behind this? @Jeremy Harris surely cannot be wrong!
  20. Did they give a reason? I would be interested to know.
  21. Shower room vents are best directly over the shower area.
  22. I would think that if all the materials are clearly visible you could just supply photographs. Be aware that asbestos is often hidden away in soffits, stair nosings, floor coverings, pipe insulation, gutters and downpipes, boilers etc so unless it is clearly just brick and steel you should have it surveyed. Should be cheap to get done.
  23. The photo was just copied from a website https://www.marazzitile.co.uk/collections/treverkheart/ but I have not used them On our roof terrace we have some 20mm thick porcelain on adjustable feet but not wood effect. Allows the water to drain away.
  24. You will need a decent tile cutter. Also, it may look better if you perhaps have a 150mm perimeter tile upstand.
  25. I have used some supposedly overpaintable stuff and the paint grins through. Have had to use a coat of Cover Stain to stop it.
