Mr Punter
Sliding door/ windows fitting below steel
Mr Punter replied to trialuser's topic in Windows & Glazing
The 50mm PIR should be OK. There more insulation around the steel the better. ROckwool can sometimes work OK if you need to fit into gaps. It is quite common to clad / flash the reveals then Compriband outside, foam inside and seal the inside polythene vcl to the frame before plasterboarding. -
Nope
We are now firmly into First World over privileged smug middle class territory.
4 years. I have tinkered when they go wrong but they are very complicated.
I had one of these. It was not the most reliable and servicing was expensive. I have also had a Jura, De Longhi and am currently on a Melitta with milk frother. The Melitta is the best so far.
160 slabs at about 55kg each. Hopefully not too many cuts to do.
I would go with what they spec. You don't fancy a polished concrete or terrazzo type thing?
OSB i-Beam size requirements?
Mr Punter replied to GloriainX's topic in New House & Self Build Design
For that size of 2 storey building you should get it properly designed and specified. They should also be able to make it as cost effective as possible. -
I don't think you have much of a case as you have left it so long but you may manage to get them to send someone to touch in the pointing for an hour or so just as a goodwill thing.
You can have it tested quite cheaply. Worth doing.
Deffo damp. What was on the spec for remedial damp proofing/ tanking / waterproofing?
This looks like different bricks were used when they go 7 courses from the top of the door. Different mortar mix too. Did you by off plan or was the house complete when you saw it?
The site bricklayers we have had can be fairly rough, but they have a service person that acid treats and jetwashes the job and fills in missing mortar pointing.
@Bitpipe who did your structural warranty? I have found that lots of providers do not like waterproof concrete alone and go on to ask for drained cavity, which sort of defeats the object.
If you are keen to increase the bearing you could use some metal shims or some runny structural grout.
Not a self build? Are you VAT registered? I am about to start 3 new build flats to rent. We have a company that owns the land and will own the future flats and they will get our development company owned by us who are VAT and CIS registered to design and build for a contract. Dev company can reclaim VAT and does not need to charge it on as it is new build. I suggest you get your own advice as a mistake could be expensive.
Saniflo Sanicompact macerator toilet installation with no soil pipe
Mr Punter replied to howplum's topic in General Plumbing
Did you get a quote to connect to the sewer? I would be very surprised if it runs to thousands. -
Tall ceilings = tall windows and doors?
Mr Punter replied to Conor's topic in New House & Self Build Design
Stick with what you have. Internal doors 2400h look impressive if they are a decent width. Door blanks are cheap and good quality. -
OP needs whole house cover. The mist systems are good for small areas / kitchens in student HMOs but cost prohibitive for whole house.
- 18 replies
- fire safety
- water
It is advisory, not mandatory. They mainly check that the sprinkler heads have not been sealed with paint and mastic and they do a flow test at the intake. If you have a pumped systems it is probably worth doing but not for a main pressure system in a private dwelling.
- 18 replies
- fire safety
- water
Cost is about £2,500-£3,000 for 4 bed house. They don't activate by accident. They are fit and forget. There is an isolator normally near the entrance, so they can be switched off after the fire is safely extinguished. Because they activate quickly and only close to the fire it can be brought under control very quickly. If you have to wait 20 minutes for the fire brigade you may have to say goodbye to the house.
- 18 replies
- fire safety
- water
Why do you think this will be the case?
Deffo forget the Saniflo. I would rather crap in a bucket and leave it in the middle of the bedroom. If your proposed WC is near an outside wall and the drain is in the vicinity is is well worth taking a 110mm pipe out to a new stack pipe connecting into the (combined?) below ground drainage system.
