Mr Punter
Boundary wall repair dispute advice needed
Mr Punter replied to HappyDays80's topic in General Structural Issues
There is no real issue with the wall. If you want to neaten up the corner where the pier abuts you could scrape off the smeared mortar and apply a wide bead of low modulus sealant like an expansion gap. You need to finish it neatly though. https://www.sealantsonline.co.uk/Products/Expansion-joint-mastic-sealants -
It is a good question and one where it is hard to find a definitive answer. Promat state: "Where beams are wholly within the cavity of a timber floor protected by a Promat SUPALUX® ceiling then test evidence shows that the cavity air temperature of the floor is such that the beam will be adequately protected to the same fire resistance by the ceiling that protects the floor. Where the beam is wholly or partly below the line of the Promat SUPALUX® ceiling, the A/V should be based upon the portion of the steel beam that is below ceiling level."
In a new, properly insulated house it can take much longer to heat up and cool down. I have had heating fail in the winter and not notice for a day.
Yes I think you are right. I spoke to another distributor who said they have a fair amount of leeway with pricing and were happy to quote against others. They also do windows by other manufacturers who are not part of the DOVISA UK / VKR / VELUX group.
Are they just supported at the base on those brackets? I assume you are doing EWI and cladding / render?
I will shortly be doing just that, when the window schedule is finalised. Was your quote from Mole Valley Windows?
Result. By the time we get to Xmas day you can spend the whole time in your Speedos!
@Jason L Fine if you cover what you have built with some wide DPC weighed down with some blocks.
We had a newly completed property flood a couple of years ago from a loose pipe on the first floor. Overnight the water poured through the ceilings. In the morning when I got to site it was like a rainforest down there. The ceilings remained intact so we swept out the water, cranked up the heating, got 2 x industrial heaters and 2 x industrial dehumidifiers. The place was bone dry in 2 weeks. We must have got it up over 30 centigrade.
As it stands that plot would be over half a million round here.
I have found that pendants can work well with a sloped ceiling. You can adjust the cord length to suit. Some have special cords, ceiling roses etc. You need to plan carefully where to fit them. Have a look at John Lewis for ideas.
I am keen on lights that do not puncture the ceiling other than the wire. I love the idea of LEDs that last 100 million years but in my experience they often fail within 2 years and they are not repairable and often not replaceable.
Calculating heating and thermal transferrance per room
Mr Punter replied to Jeremy's topic in Central Heating (Radiators)
Again, is there any point for this exercise, as they will need to have a heating system sized sufficiently to heat when there is no solar gain? -
If the rooms are both heated there probably won't be much in it. -
Because the ASHP work best with low temperature you may want to look at underfloor heating on the ground floor, with lots of insulation. Agree to over-sizing the upstairs rads. Yes, the heat losses are the fabric losses plus ventilation losses. -
Good to catch up on what Rollo is up to @ToughButterCup!
They will be OK to quote with the planning drawings. Best in PDF or DWG format. Whoever you chose may point you to someone for Building Regs.
Getting a WC and bath waste into the same branch pipe
Mr Punter replied to lineweight's topic in Waste & Sewerage
I am pretty sketchy with plumbing so hopefully an all-knowing type will comment with a proper solution. I will be interested to see. With the top one you may need an AAV on top of the soil manifold. Is it possible to take the bath / basin pipe out through the wall and connect it to the SVP? The bath / basin run from looks quite long. -
In my experience, people get objection fatigue, so if you are refused or apply for a modified scheme, the numbers of objections tend to dwindle. On a recent site there were 3 applications within 6 months, all approved. The first was from the previous owner and got 8 objections, then one from us got 12 objections, a second from us got 1 objection.
If the house is sealed up, run a dehumidifier and a couple of oil filled electric radiators to get everything up to 18 degrees. It should heat up in a day or so and retain the heat just fine. You should not then have any further condensation issues.
Could it be dripping down from the walk on glass?
Have you and your neighbours spoken to your councillor(s)? They often have the power to "call up" applications to be heard by the planning committee.
