Mr Punter
Posted too late in the thread...
Please help me find the right greyish white facing brick
Mr Punter replied to Adsibob's topic in Brick & Block
I am using a brick called Forum Smoked Branco, which is a light grey. About £1 each. Have not started but agreed with planning. -
Bad Airtightness Test Result
Mr Punter replied to AliG's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I would give it all a spray of water to moisten slightly, get the foam gun nozzle right to the back and squirt in. Don't apply so much that it drips or falls out. You may need to do a few passes after the first has partly cured to make it fill properly. -
Hello, is still financing structure possible?
Mr Punter replied to AdamB's topic in Introduce Yourself
The difficulties are your income and lack of capital. However you finance this, if you aim to retain the property it seems you will need a mortgage / loans of £650k with an income of £85k which is 7.7 times income. I doubt many lenders would go more than 5.5 X. With only £100k of your own funds and no experience I can't see the construction being possible to fund either. -
Will a can of expanding foam not fill that? Bear in mind that if you use it you will struggle to get to any of it later. Also it can push stuff about as it expands. -
If it is not fixed the contractor or supplier can just remove it if they are owed money. Once fixed, they can't (legally).
I have not seen that as a planning condition before. It may be worth looking at the council website to see applications from a year or so ago that have the same condition and copy what they submitted? Intellectual property theft is the sincerest form of flattery.
What do you need this for? I ask for risk assessments and method statements from our subbies, for health and safety compliance.
If you cannot afford the VIPs, 40mm PIR will give you an extra 50%, so like having 60mm EPS. 50mm PIR would be like 75mm EPS.
If you have the money you could change your EPS for Kingspan Optim-R which is a vacuum panel insulation board. The 40mm thickness will be equivalent to 195mm of your current EPS.
Resubmission after dismissed Appeal - Help!
Mr Punter replied to Mrsmedhurst's topic in Planning Permission
Yes. Submit the same scheme but include the offer to pay the environmental scheme money. It sounds like you are pushing at an open door. -
Cheap adhesive from a mastic gun just to hold the insulation in place. Tape the joins. Pre drill the battens so your chosen plug will fit through. Drill through all. Fix the whole lot with long screws into plastic plugs.
The market looks overvalued at the moment, but unless we see a rise in interest rates it may stay that way.
I have used natural slate tiles. We did adhesive and mesh on the insulation, then the tiles. Butted up with no grout.
Running out of hot water
Mr Punter replied to canalsiderenovation's topic in Air Source Heat Pumps (ASHP)
It is most likely that the washing machine is only connected to the cold water, so it should not deplete your hot water tank. -
Ensuring vaulted ceiling won't get hidden condensation
Mr Punter replied to Jilly's topic in Ventilation
Celotex / Kingspan / Xtratherm style foil faced boards, joins taped with self adhesive aluminium foil tape as a vapour control layer. https://www.toolstation.com/aluminium-foil-tape/p81953- 35 replies
- 4
- vaulted ceiling
- ventilation
(and 2 more)
+1 to the 50mm taped PIR under the rafters. It really cuts down on condensation risk.- 35 replies
- vaulted ceiling
- ventilation
(and 2 more)
Yes, that is a bit strange. They are both DOVISTA. I got a quote from Velfac in November. With Rationel they referred me to a distributor.
Normal plaster or sand and cement???
Mr Punter replied to Grendel's topic in General Construction Issues
I like sand cement and lime.
