Mr Punter
Integrating an MVHR to our build
Mr Punter replied to djcdan's topic in Mechanical Ventilation with Heat Recovery (MVHR)
For that reason I have a hood with a bfo remote external fan with 150mm ducting. Good for stir fries. -
Tight space squeeze too ambitious?
Mr Punter replied to tanneja's topic in Mechanical Ventilation with Heat Recovery (MVHR)
You could probably get one with a timer so it finishes when you want it to. I don't know if they have a setting where they just tumble intermittently at the end - a bit like a concrete lorry - to stop the stuff creasing? The heat pump ones are really efficient, but they take even longer. The ones with larger drums crease less. Putting the exhaust into the MVHR may overheat other rooms, but ask the supplier what they think. -
With a vented dryer you are throwing energy straight out of the wall. You could get rid of the MVHR and just leave the windows open! Why the rush for quick drying? -
I have seen the Nest alarms criticised widely. And note they almost self destruct after 10 years! SONOS is not much better. Anyone got a smart fridge? 3D TV? People just seem to want to spend more time looking at an app on their phones.
Bad Airtightness Test Result
Mr Punter replied to AliG's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Just use a multi tool and cut out a rectangle. As long as you keep the bit you cut out you can screw a couple of bits of batten across the hole and fix the piece back in. -
Have you thought about the orientation? It looks like you have a large north facing balcony / terrace, but I have had a few lockdown drinkies so may have misread this.
The people that do the metal on commercial projects can do shed loads in a day. We had a guy on site was not the brightest and not suited for what we were doing but his boss regularly paid him £500 a day on price for doing metal frame ceilings and walls elsewhere.
Boosting Wifi
Mr Punter replied to canalsiderenovation's topic in Networks, AV, Security & Automation
The Ubiquiti APs are powered via the ethernet cable and supplied with a POE injector, which you can either plug in near the access point or near the router. -
Do make sure it is not dependant on one app. The system should last the lifetime of the building. The app may go belly up anytime.
When I did one of these it was a Vent Axia Sentinel Kinetic Plus and I got their approved supplier to do a design. It worked OK. It was not a radial system based around manifolds and used 125mm rigid duct with tees / branches. On a small 3 storey there were only 2 main ducts vertically - for the supply and extract. Make sure there is space around the unit to remove the filters for cleaning. It can be better to have the extract vents within the shower areas. The supply vents were sited away from the door into the room, so the air travels across and under the door gap, leaving no dead areas. Avoid clashes with SVPs. -
Self-Build with UK outside the EU
Mr Punter replied to Ferdinand's topic in General Self Build & DIY Discussion
I would be very happy if this happened. As it is, the postal charges from China for these small items seem lower that those sent within the UK. -
Engineering Flooring in Bathroom and En suite
Mr Punter replied to Drew1000's topic in Wood & Laminate Flooring
How about some ply screwed down at 150mm ctrs in the bathrooms to match the height of the engineered and LVT glued down to this? -
Most / all lenders and insurers are happy with timber frame with outer leaf in brick or rendered blockwork and pitched tiled roof.
If you cast the slab unreinforced onto insulation and build up to the edges it will probably break. The insulation under slab designs here have quite complex insulation and concrete specs plus reinforcing. I would go with 100-150mm concrete cast on the type 1, 2 or courses single skin brick perimeter or 7.3n blocks if you prefer. 112mm dpc. Treated timber sole plate held down via straps. Timber framed walls. The bottom of the sole plate must be at least 150mm above finished ground level, 225mm preferred. DPM in middle, lapped to DPC. EPS floor insulation (or whatever is cheapest) in middle. Polythene sheet, 22mm T & G chipboard flooring. You could screed but probably overkill and not easy to DIY.
cottage door
I would go with the larger ones. Easier for fitting and operating blinds, external shutters, auto opening etc.
Oooops.... is there any way to recover from....
Mr Punter replied to ToughButterCup's topic in Kitchen Units & Worktops
Yes but the sink lip should go over the laminate with a seal around. You can't (shouldn't) undermount a sink in chipboard tops. -
If it is a laminate top and an normal inset sink the interface between sink and laminate should be watertight as part of the sink design. What sink? -
Query on if this is right - Loft Insulation
Mr Punter replied to canalsiderenovation's topic in Heat Insulation
You need the low level as well. It could be the over fascia type or soffit. You should be able to feel cold air coming in. Make sure the air path is not blocked by the insulation. Having almost no wind does not help. Try hanging out some wet washing in the current weather and you can see that evaporation does not happen quickly. -
Architectural practices can tend to be one trick ponies.
I quite like the Neoclassical / Palladian type architecture but I can can never quite work out what makes some designs that work and some that fall short. One of the many reasons I could not be an architect!
Gus’ Structural Engineering and DIY Part 02
Mr Punter commented on Gus Potter's blog entry in Gus Potter
There were not many notes on the drawing, so the contractor should have read the one that said props no more than 25mm out of plumb! How is the cross bracing normally done? Scaffold poles?
