Mr Punter
    27
  1. If it is just a single storey garage, could you replace it with a car port?
  2. Great job. If you were to price this to do for someone else, how much would you charge per metre?
  3. Where we are , "they" is apparently the correct term to cause least offence.
  4. What stuff have you automated and how do you operate it? Does the rest of the house look like somewhere a Bond villain could live?
  5. Yes, you can drill your hole. To play safe, install a couple of vertical 38 x 89 studs in the wall under and ask the TF engineer to confirm this is acceptable. Be careful when you drill as the drill can jam without warning. Incidentally, with the two horizontal 89mm timbers, one is the top part of the timber framed panel and the other is a top plate to join all the panels together. They are not really regarded as structural beams. It is this large build up of horizontal timber that causes shrinkage in timber framed buildings, but it is the standard way of doing things.
  6. I would coat the whole of the flank walls with Stormdry. Off topic, where were your stooled window cills from? From the photos they look well made.
  7. Or you could just take a bit off the bottom of the doors that don't fit and with the front door you could leave the 1m area near the door for a mat well and just fit a low profile mat with a profile up to your floor.
  8. Hi @Ronan 1 and welcome. There are a fair few from N. Ireland on here. What build method are you going for?
  9. @MJNewton of this forum had similar issues and was persistent enough to get them resolved.
  10. It is worth finding out if it is really rising damp first. Often internal plaster can get damp at low level due to warmer internal air coming into contact with cold external walls, especially at low level, under windows and in corners. What are the walls built from?
  11. From their website it does look like it has been spec'd on some credible projects. Down to price v. alternatives for required performance I guess.
  12. Townhouse half the size of your place!
  13. We have nothing so fancy. With 6 WCs, 6 sinks, a bath and 2 showers spread over 5 floors it would make the plumbers head explode.
  14. Or tap to brush teeth?
  15. Flush the bog while SWMBO is in the shower? I have not had reliability issues with the thermostatic ones, although I have had an idiot plumber mix the hot and cold feeds on one. If anyone does this, Grohe do one for just such eventualities.
  16. I have a Whirlpool microwave that does three beeps when it has finished. It continues with the 3 beeps every 20 seconds and carries on forever until the door has been opened. Drives me mad, as what is the worst thing that could happen? Something cools down?
  17. I think it would be normal to have a stepped cavity tray installed above the stepped lead flashing, but not an option retrospectively. Can you consider coating that damp wall with Stormdry Masonry cream? I have used it in the past and it works really well at repelling water and leaves the brickwork breathable. It soaks in and apparently lasts over 25 years. I am using it on a forthcoming build where there is an exposed brick section that will be difficult to access in future.
  18. Type C drained cavity waterproofing to floor and walls with sump and pump. Metal I studs inside walls. Insulation and chipboard floor.
  19. Maybe this was condensation originally running down into the stove and now maybe the join on the pipe got moved slightly and it is finding an exit point there.
  20. I know it is 1 hour. I thought that having it in the floor zone with the 2 x plasterboard would be acceptable. Architect wants intumescent paint.
  21. 3 flats - 1 per floor.
  22. Thanks both. I have a project at present where the architect has specified intumescent paint to beams in a ceiling with 2 x 15mm plasterboard. We need 60 mins but architect insisted.
  23. Thanks @Ian. I do feel that fire safety is an important topic and it would be better if this was not left up to the opinion of BC but was something that could be relied upon to comply. I can understand opinion on site matters with things like foundation trenches, because ground can be variable, but a steel beam is something that could be assessed at plan check.
  24. So on the basis that the steel beam is structural, is it OK to just have have it in the floor zone with plasterboard on the underside to give the 30 mins or 60 mins protection required? I sometimes get asked to spray with intumescent coating or encase the whole in plasterboard. It is hard to find consistent advice. The intumescent coating only works if you leave space around the beam, which in domestic floor zones can be impossible, but BC don't seem concerned with that aspect. The product manufactures understandably tend to just promote and test systems that include lots of their product.
  25. There seems to be a big emphasis on fire protection for steel. I can understand it in multi storey, but for domestic I would think that once the floors reach >500C the place is finished anyway.
