Mr Punter
    27
  1. I don't think there would be an issue with fire as the section sizes look too big. As long as surface spread of flame is limited, via a simple coating, the rest would be fine. A bit like trying to start a fire using a big log v. kindling. It won't look so pretty after first fixing! I think cost is the biggest issue with CLT and it still needs protection from the elements so is just a structural inner leaf which still need insulation and rainscreen. Probably quite easy to find a fixing or 2 for cladding though!
  2. Should be but it is not a vapour barrier. If it exists it is a vapour control layer at best. Probably loft hatch, pipes, wires and ducts penetrating. VCL is probably not contiguous with the outer leaf. The roof needs low and high level ventilation. Soffit and ridge.
  3. Bear in mind it is abnormally cold outside and you have had a lot of building work that may have introduced a lot of water - bricklaying, plastering, decorating, screeding, concrete etc.
  4. I have done similar with sleepers but just had 6m steels with 2.7m left in the ground. It was only for working area. Where there was a neighbouring structure (garage) we augered 6.0m hit and miss holes, put in a small amount of reinforcing the full depth and concreted before we excavated.
  5. It is warm moist air getting in from the house. Probably no vapourcheck at ceiling level and maybe holes for lights etc. Is the top of the wall cavity closed off? Often have plasterboard on dabs letting air in from below.
  6. Can anybody hazard an estimate of the difference in cost for this if you have to pay labour & materials v a standard setup? Also, what are the main benefits? I can imagine what a lash this would look like with the average site plumber!
  7. Sometimes I have get decent prices from merchants but you just need to be on their backs all the time or they charge a stupid amount for the same thing you have already had.
  8. If there are a fair few tiles that need replacing I would renew the lot as the new ones will not match and the old ones are probably past their useful life. With Velux if they are OK and a current size you could leave. If not, replace. Easy for me to say as it is your money.
  9. I guess if it is fully fitted with trim panels and scribed end infills it is not double what you would pay. If you got it for £5k I think OK. Years ago I did kitchens. I would only go to see qualified leads and would never leave a plan or a price I would talk through what they wanted and their budget and if not realistic I would leave it at that. Showroom staff would give a price indication first.
  10. Some of your costs will be fixed no matter how many storeys, such as site preparation, planning fees, utility connections, drainage, and landscaping. The 1.5 storey should be a little bit cheaper as there is less ground floor, foundation and roof per metre.
  11. I think the Dewalt ones are pretty good. https://www.screwfix.com/p/dewalt-acrylic-head-aerated-concrete-anchor-14-x-70mm-40-pack/233ht
  12. I wonder if it can be put down to one-off madness? A house we did the customer noticed a small water mark on the ceiling after about 3 months. I got the roofers back. They unzipped the standing seam panels. No sign of damp. Insulation dry. Panels were zipped back on and 7 years later there have been no recurrences. I suspect it could have been some moisture in the structure that got in during construction and condensed out later.
  13. Celotex CF5000 is no longer available post Grenfell. How about stonework, a 75mm cavity, filled with 75mm Dritherm, inner 7.3N Celcon blockwork, 50mm PIR joins taped, 25mm vertical battens for service void, 15mm plasterboard. Where you have heavy loads, fix 25mm x 150mm timbers. If your SAP person counts the 25mm as a low e gap, you should get a u value of 0.18 W/m².K.
  14. Is it pumped from somewhere? Overflow from a soakaway or a well? All will be revealed when the builder returns...
  15. It looks like a temporary setup. You need to make sure the permanent replacement is correctly specified and installed.
  16. Yes you definitely need the setting tool with those anchors. Just tightening them and they will often spin and knacker the plasterboard.
  17. We just used an end cap tile on the ridges to slightly overhang the verge.
  18. Would he need a CO alarm to comply with building regs? He is not letting out.
  19. Nice. I did not know there was a new version. Mine was from 2013! It make sense to have all the resi in 1 volume. Has much else changed?
  20. I think some of you need to change your diet. It is only after I have eaten something that really disagrees with me that I would ever need an extractor in the WC. When it does happen, the extractor does not help. Only time can heal the harm.
  21. I would prefer plasterboard. While your boy is skimming it he could go over the ceiling.
  22. You have made the bedroom into an inner room with the only escape route through the living room. I am not sure if the window meet the regs. You no longer have a protected hallway, so there is only you front door between the the living room and the communal area. They will want the lobby protected with FD30 doors and the archway reinstated as a door. Having done works needing building regs, they can ask you to up the spec with mains heat and smoke alarms as they are the current regs. @DevilDamo surely it is ADB volume 2 that this needs to comply with? It is a flat, not a dwellinghouse.
  23. And the grout looks really smart.
  24. A friend of mine who does access control is red/green colour blind. I bet he would struggle to wire joth's cabinet. I find phone apps a real PITA. I have SONOS and by the time the app wakes up, wants updating, tries to scam me into new hardware etc I have raged and fallen asleep. I like the idea of home automation but it does seem to be a lot to do with lighting, which I have never found an issue. The cabinet is proper porn though.
