ADLIan
Everything posted by ADLIan
Is this new build house or extension? For new build expect U=0.15 or better. For extensions BR require 0.18 or better +1 to most of the above, especially multi foil! I would not bother with Frametherm 32 (extra cost for minimal improvement on U-val especially timbers at 400mm c/c) - go for 35 version. Fully fill the rafter space with this, breather membrane, counterbatten, batten & slate with 50mm PUR under rafter. Note this is not a warm roof. It gives a warm roof space but to be a warm roof construction the majority of the insulation must be above the rafters.
Historic retrofilled foam cavity insulation - U value?
ADLIan replied to PeteTheSwede's topic in Building Materials
U-vals are always for the whole wall (or other element). Old cfc blown pur had lambda of approx 0.020 W/ mK but expect this to degrade considerably in this application to nearer 0.03 W/mK. -
Expect U=0.43 at best, perhaps 0.45. -
Normal quilt loft insulation cut to fit between timber. Leave last few feet rolled up and push/unroll into place with help of a broom. Add further layers same way if needed.
Plenty of pur/pir alternatives but kingspan has a virtual monopoly on phenolic foam so expect to pay top dollar for it.
Modern mineral wool cavity batts are quite dense and rigid so the normal plastic retaining collars that slip over the wall ties will work OK. Why not just fully fill with 300mm (2x150mm) with no residual cavity? Where is the building located? Partial fill normally only needed in very exposed locations (SW England, west Wales & west Scotland) or high rise (18m or more in height) but rainwater penetration is very unlikely across 300mm full fill.
The thermal conductivity will be whatever the manufacturer states and is backed up by CE marking, the DoP and perhaps BBA certification. (Note post Grenfell Celotex were guilty of over stating both thermal and fire performance of certain products and I believe had BBA certificates suspended). The compressive strength may vary depending on application and if load bearing or not. You would need to check with the manufacturer for exact values of certain physical properties but they may not be forthcoming with very detailed (commercially sensitive?) information.
On a very simple level product used in flat roofing has to cope with temps varying from say -10 C to perhaps 80+C and the foam/facings have to be formulated to cope with this. Flooring, cavity wall and 'general purpose' PIR products will never be subject to this temp variation. (Individual manufacturers may be able to offer more detailed info on the make up their products). Bottom line is the products are optimised for the application they are made for - hence swapping products/applications or using second grade product may lead to problems.
PUR and PIR may have slightly different chemical compositions depending upon application. Flat roof products for example face much more difficult conditions 'in use' compared to say a flooring application. The facings may also be different. What you see as a 'foil' face may have many different layers from a simple single layer to 11 layers or more depending upon application. Specific products based on the above variations may also be BBA approved for a particular application. An alternative view is it's all marketing and sales hype and the products are actually the same!
@ProDave SAP energy rating is based on energy costs and these are normally increased (inflation?) in new versions of SAP so your SAP/EPC will probably remain the same. The big difference is reducing the carbon intensity of electricity (fewer coal fired power stations) so should make Building Reg compliance of all electric houses easier.
Check with the PUR manufacturers. Generally foil faced boards are mechanically fixed whilst those for bonding have a coated glass tissue facing (normally cream/off white in colour). Remember you will also need a VCL on the deck prior to the the insulation boards and you cannot bond to polythene so fully bonded PUR normally goes onto a fully bonded bituminous felt VCL.
Can I get a grant for loft conversion insulation?
ADLIan replied to john k's topic in Lofts, Dormers & Loft Conversions
The grant aided schemes are normally for upgrading existing lofts and are often means tested. Loft conversions come under the Building Regs along with the requirement for insulation at the roof line or flat roof. I assume the thinking is if you can afford a loft conversion then you can afford the insulation to go with it. -
I see this a lot as a planning condition. Typically Planners will require a 'scheme' to be 10% better than Regs based on CO2 emissions and/or fabric energy efficiency and also may dictate it's got to be done by the use of renewables. Distinct lack of consistency even within one planning authority! Self builders and smaller developers have to jump through the hoops but, as ever, the large, national house builders appear to avoid this type of condition, I believe the reason(?) is 'it doesn't make the development economically viable'. Ian
- 12 replies
- passive house
- building regulations
- (and 2 more)
What is the function of a cavity tray at ground DPC?
ADLIan replied to epsilonGreedy's topic in Foundations
Rockwool data I have shows cavity batts below DPC starting just above the lean mix cavity fill - I believe this is common to just about all manufacturers and BBA certs -
Beg to differ. You will find just about all built in cavity insulation products are BBA certified for use below DPC -
I need to order some footing blocks, what types?
A ground floor U-value of 0.3 W/m2K would give an automatic fail under the English Regs - must be 0.25 W/m2K or less, area weighted average. 100mm PUR probably gives better than U=0.2 in a typical floor, perhaps closer to U=0.16. This can easily be offset elsewhere in the construction. Note the DER/TER requirement can still be easily met depending upon fuel, heating system - air source heat pump, addition of solar PV etc helping reduce CO2 emissions. High individual U-values will impact on the DFEE/TFEE however and will be more difficult to resolve. -
Who has used, is using, PHPP?
ADLIan replied to Dreadnaught's topic in New House & Self Build Design
The nail plate is shown with a conductivity of 17 W/mK - this is the value for stainless steel. For typical nail plate, in galv steel, this should should be 50-60 W/mK. But, as above, probably has little impact on U-value, probably only in 3rd decimal place and probably less than 0.01 W/m2K. Not sure its worth worrying to much about these slight variances in U-values when effect of linear thermal bridges may be your biggest enemy! -
Should also take the opportunity to add/upgrade the insulation. Probably falls under Appr Doc L1B requiring this upgrade.
The properties to be tested should be chosen by the BCO not the developer/builder - yet to see that happen!
Another example of lack of enforcement of the Regs! The Building Regs are very specific on the air tightness testing regime, see Section 3.17 of Appr Doc L1A, requiring testing of 3 of each house type or 50% of each house type, whichever is the less. The SAP assessor should pick this up too as a copy of the test certificate needs to be provided for each tested unit and the convention is to add a penalty of +2 to the measured value for the untested dwelling type (Section 2.9).
Plan C, leave aircrete walls naked for a winter?
ADLIan replied to epsilonGreedy's topic in Brick & Block
Many breather membranes used in TF and roofing are degraded by UV light. Check with manufacturer the maximum exposure, some as little as 3 months, others up to 6 months.
