Nickfromwales
    346
  1. https://underfloorparts.co.uk/product/ivar-dualmix-underfloor-heating-ufh-pump-mixing-kit-underfloor-heating-manifold-control/
  2. Your supposed to ask first. Grrrrrrrrrr. At this stage id only have bought the manifolds to connect up. Keep it clean and return it asap.
  3. Stone resin is the one to go for. As long as its not composite coating / foam centre then your good to go.
  4. He's right, so stop chopsing to him
  5. You may struggle with that blending valve then tbh, , as it'll not drop down as well as a TRV / capillary probe type mixer. The temp setting will say it'll drop down low, but youll have nowt for the return side to suck in to cool it. If you can change it whilst its new and clean then I would. Dont forget room for your buffer.
  6. I think judging by the fact theres a bare board over studs and no insulation, that its just so he can mock the ufh up and drop the screed in
  7. To hold off heating on 50mm centres and creating hotspots. Id have used insulation tbh, but that'll suffice. @Construction Channel, forgive my naff memory but what are you using to heat the place?
  8. If the architect has written a response that states that they couldn't be bothered to fully read your weekly emails as they were "too long" a judge would tear a slice off them. Hold back £2k and tell them it's going to court if they want it. Then when they walk away, £2k the lesser but £2k penalty the wiser, use that to go on holiday. ??
  9. That membrane is a joy isn't it Dont let that stick to itself after peeling off part of the protective film.......Not good. Excellent system overall though with it decoupling too. I didn't know about that until you mentioned it elsewhere tbh.
  10. Errrrr.....compass and a padsaw THEN get pissed
  11. I am tempted to Rename it....... "The Bog Supa-Blog"
  12. Lol. Ian !
  13. They all look pretty damn fine to us mere mortals, i assure you .
  14. If biodegradable then what about disposal to sewer / other & typical costs per say 8 year event if known ? Eg professional disposal with paper trail ? Most people with ST I've been called out to ( not working ) don't even know it's a sealed and pressurised system with a pressure gauge until I point it out. A quick top up and they're off to go, but some say they haven't bothered with it for ages as they thought it was going to cost for repairs. Another top day for the "fit and forget" posse. You pay they walk away . Bonkers.
  15. I have googled the life out of this and cannot find much to say that antifreeze needs to be changed periodically. Even heat pump manufacturers are playing that down.Do you have reference material / links? @JSHarris, any input please?
  16. You've posted quite a bit TBH so maybe just include some links to the bathroom related ( key ) threads / posts ? Will save double handling.
  17. Excellent! The place looks a million dollars. Bathroom looks great too, you'll have people fighting over that place soon. One last push, and then your done. Tres bien Rodney
  18. You can, but what's the likely average? Only punting it out there at the mo re ST. I'll add more later.
  19. Sunamp website
  20. I'd hold that thought for now . The storage temp is neither here nor there if you have a blending valve on the UFH manifold, and the only time you'll need the PCM 38 is if your heat source is low temp, eg solar thermal or heat pump. Hopefully I'll be Sunamp acccreited very soon, just waiting on a date. Then I'll know them inside out. What I've seen so far makes them a game-changer imo.
  21. Put a non return valve on the pressure tester and leave it on overnight. That'll capture the maximum static pressure which usually peaks out around 01:00 to 04:00. Once you have that information you can then properly decide on a solution. Cold mains accumulators sound like they'd sort your problem TBH. Sealed potable and simple.
  22. Id cut a pair of channels in the floor and insulate them with some 12mm wall armorflex. ? Negligible heat to floor slab then.
  23. I'm in talks with @AndyT at the moment and more information should be publicly available around the beginning of March. Will be worth the wait me thinks. ?
