Nickfromwales
    346
  1. Use the mop. you'll never go back
  2. Yup, but Chinese slate needs a scrubbing brush for the grain on the last pass, then a final mop. Seal the slate first of course
  3. Nice tile. Do NOT put a grey grout in....PLEASE! @joe90 A top tip for grouting, after sponging to get the first wipe out of the way, switch to a cheap mop to remove the remainder. A caretakers mop, rather than a fibre mop, is the best as it doesn't drop into the grout lines. Cleans this stuff up ( especially the charcoal / black ) in minutes, whereas with a sponge and bucket you'll be there for hours.
  4. Cracking idea. Maybe just a 32mm or 40mm PVC waste pipe would suffice. @JSHarris, what size pipe did you run for 'operation stench' ?
  5. Snickers for me with pads in pockets. The ones that strap around I found cut off the blood supply to my lower legs / feet and gave me pins and needles. Avoid trousers where the knee pad is pushed up from the bottom of the knee pocket, with the Snickers ones dropping in from above.
  6. Theres very little to dislike about that site, looks amazing. Agreed, worth the wait.
  7. I think another member made a good suggestion. When it arrives lay it flat, outside, and level it by whatever means. Then run water over it to see if its all free running to the drain and doesn't pool at the corners / other.
  8. Could you elaborate on that a bit please J? Do you mean 2 ducts joined into a reducer, say 2x 75mm ( cant remember the common size, maybe 65 / 63mm? ) into 1x 150mm for a single point double capacity terminal? Im looking at a proposal putting 2x single extracts into a reasonably sized utility ( beefing up to remove a bit more heated air generated from all the white goods that will reside there ), plus the plant room would be in that room too, eg a door into the utility. So the thought is that one may struggle, so put two in, at opposite ends. Outside the utility entrance door there will be a cloakroom WC, so an extract in there too. The utility and cloak doors are linked to a tiny sealed lobby, the seal formed by a third door to the kitchen, so next thought is to increase the single inlet in that lobby to a larger single inlet to match the 3x local extracts, doubling up 2x 75mm ducts into one 150mm. Any issues with a 150mm inlet servicing those 3x 75mm extracts in close proximity? Also; Is there any scope to put in some kitchen inlets at low level, even though a typical kitchen 'room' should only have extracts? It'll be an open-plan room, with fresh inlets over the dining / living space just off the kitchen, so a myriad of difficulties to overcome in order to get the right air shifting in the right directions in the right amounts
  9. Nope
  10. It'll be a bloody big list if its a new build 10 years seems a bit crazy, you must REALLY want to build this house. Now, time for a good old blog eh?
  11. She's let herself go a bit since mind you, so beware......
  12. Ahhh, the old outfit in an aerosol can. "Make it so, number 2" . Tres bien.
  13. Just down the road from me. Used to live there. Less than a mile from my house there's a load of underwater canals which were apparently used for mining that have caused mid-terrace houses to just drop and fall to ruins whilst the ones to the left and right are still up and intact. I doubt if their mortgage companies are too respondent to lending on the equity
  14. He's doing WHAT
  15. My boys were at home whilst I was in Asda Yup, just when you think its safe to give the last of your hard earned to the supermarket thieves.........Godzilla decides to stamp his feet in my back garden. Phone call from the house....."Dad, the whole house just shook, im scared!"....Me..."Dont talk daft boy, we dont get earthquakes" Turns out they were right and I was wrong!!!!!
  16. Liquid DPM ?
  17. Multitool makes it disappear
  18. Just to do the shower tray fall section ?
  19. Benefit or necessity? Check with the manufacturers first to see if their panels need that for warranty etc.
  20. Abuse it wisely by buying the right bits !
  21. Night terrors for weeks now, cheers
  22. Im very suspicious of where this is going
  23. PS @joe90 no tilers currently available to travel sorry. My arms not up to it either at the moment
  24. Yup. Just leave a 4-5mm gap for a coloured silicone and job done.
