Nickfromwales
    346
  1. Just if any shower door seals etc. Just a generic 'heads up' to other readers if not applicable to yours
  2. One option; The over floor / over lay systems
  3. Go all out and start afresh Get a silicone removal tool, score the silicone first with a Stanley knife to get things moving, ( don't scratch the tiles ), and then get a silicone remover such as CT1 multisolve / other. A few applications will see the old silicone dissolve and go to mush, and with repeated applications the old shit will all be off and you'll have a blank canvass. Labour of love though im afraid. Start up high so the product works as it descends, and don't let it sit on any rubber seals ( mask off if unavoidable ).
  4. We would expect nothing else All depends if there's just gaps to fill back in, and the original stuff is in good repair TBH. Main thing is that it is DRY, as silicone will not take to anything wet. Best to dry it by blasting it with a hair drier for a good 5-10 mins, and then leave to cool right off. Dry the majority with kitchen roll first.
  5. Modern gas hobs will have an FFD ( flame failure device ) so the gas shuts off without the presence of a flame Idiot proof.
  6. The duff link was to one in a toothpaste tube Been a long day. This is the correct link...….."Joys of modern technology", my hairy welsh arse it is!!
  7. bugger ill change it in a mo. 2nd one is the winner
  8. @lizzie Would this help? Link Stop the press ( quite literally ) I thought id seen these. Back of the net
  9. What alternative would you have? Radiators? Don't discount a hybrid ASHP fortified with LPG. You can then also fit a gas hob / gas inset fire if easier / meagre electricity supply.
  10. Would any of the units be rental ?
  11. Don’t fit an instant, such as a Steibel as you’ll regret it. Incrementally something like this is far more bang for the buck. If you see a higher demand in the not too distant future then for a handful of tenners more you can go to his bigger brother. If you do a bit of storage you can heat on economy perhaps, rather than peak on demand consumption. Case dependant of course.
  12. I'd deffo go for a 22mm 'backbone' and drop to 15mm when you et to the last 2-3 outlets. What hot water device are you fitting? UVC?
  13. Will do. I'll be speaking to the installers ( I've subbed in ) later this week for a progress / scheduling report so will get some info asap. Its the Eco Angus Arligno 200 I went with, 40kW ( for the thicker walled steel ) and a much bigger fuel chamber for a lesser number of batch burns per TS recharge. £12k back over 7 years isn't to be sniffed at !
  14. @iSelfBuild We'll have to change your username to Sarah Beeny at this rate !
  15. @jamiehamy Sounds like a cracking idea to me. I've suggested this to a number of clients now We did another on a log gasification boiler instead of a WBS+BB as the latter didn't attract RHI, but the LGB does. Lots of great 'commercial' incentives about, but not many people jump to take advantage for whatever reason I suspect its because of the fear of the capital outlay, but there are loans about specifically to facilitate this IIRC.
  16. 25mm is a decent sized main for a domestic dwelling. You may be having extra bathrooms, but you'll likely not use them all simultaneously. If you think you will use them / have very high DHW demand then I doubt fitting a 32mm main to the existing mains ( street ) supply will make any notable difference TBH.
  17. Just buy some cheap pipe insulation and lag the pipes where the timber is the only support. The pipe then moves within the insulation and it cannot degrade then.
  18. Passive house ( aka well insulated build ). Sorry, a bit late and I'm cream krackered.
  19. Just for your sanity, popping a soil pipe through a PH wall will not bring the 4 horseman knocking
  20. The vent can be on any exterior elevation, can exit through the roof centrally on a stand alone SVP run etc but cannot vent at ground level near the property / adjacent to neighbours property / other point where the 'stench' would be a nuisance. The vent is to get the gasses out of the network, so can get quite stinky. As for the insulation, I'd buy some self adhesive neoprene insulation tape and wrap the outside of the pipe to the point it becomes exposed inside / outside, sealing and weatherproofing accordingly.
  21. Strange......you normally drink it
  22. If you are on network / mains for sewerage, then each property has to provide a minimum of 1 vent to atmosphere. Making that external SVP ( soil vent pipe ) your vent to atmosphere will encourage it to become a cold vent, but unless you have made provision for a vent elsewhere youll have to go for that regardless to satisfy the BCO. Any other rising SVP can then terminate in an AAV ( air admittance valve ), making things easier for the other internal waste connections. What you 'can' do is get BCO signoff and then take the vent cap off the external stack and replace it with another AAV, thus massively reducing the cold draught that would otherwise continue to be problematic. Can you exit the building, then turn left or right slightly and drop / rise off to one side of the point that the pipe exits the building? Basically, if your stuck with the vent to atmosphere, can you put a bit of distance between the exit point of the build fabric and the natural (rising / passing ) path of the venting air? What insulation has been used? I would recommend filling the gap around the pipe with expanding foam as it will help insulate the pipe.
  23. They'll join up fine with solvent weld. +1 to using a cleaner, and I also scratch the surfaces up first with 80 grit paper first so the shine is off them. Its also good if you can get a bit of a twist action rather than just push them home. Polypipe solvent cement 'gap filler' is the glue for this. link. Don't use normal solvent weld if your not familiar with making these off as its much thinner and the gaps are greater with this mix of pipe / fittings types ;).
  24. Fire rated is only applicable if there is a 'deemed habitable' room above. You're 100% off the hook there.
