Nickfromwales
    345
  1. Why don't you get them to connect it any old way with a bit of slack, eg say the connection is going in the attic bedroom. Let the massive thunderbulbs connect it and bugger off. Then yank it back out and fish it in through the duct / wherever. Simples. They are a bunch of awkward useless idiots, more so on the admin / logistical side than the guys on the ground, and were responsible for 99% of the problems we had when installing new business telephone systems. That included leaving solicitors and doctors surgeries without incoming calls / no connection ( when converting from analogue to ISDN etc ) at all for 24hours or more etc and really not caring about it. They're a bloody nightmare. Let them come, do their usual crap, and leave. Then you redo it your way. .
  2. Intumescent collars on the duct at the plenum / ceiling junction? Simple and effective as a terminal means of control. If the mvhr fan gets shut down then doesn't there still exist a path between plenum and atmosphere? If so, would heat / convection circulation then naturally draw through the ductwork, regardless of whether it's extract or inlet?
  3. I'd seriously consider smaller ensuites to 1&2, and have the soil and vent pipe outboard unless it can be first fixed sympathetically to the new split design. I'd also look at two windows, one and one, and making each one say 300mm wide x 800mm high so both rooms get natural light and an opening window for fresh air circulation. Having any bathroom without a window isn't preferable IMHO. Go for smaller cube or rectangular showers and if there's room left at the end of each one them, then that's the best place for the towel rads so you don't burn your arse when brushing your teeth. Some very good advice from @Ferdinand there. , particularly like the idea of first fixing the study for conversion later down the line. Deffo go all ensuite now, as converting the study later will get you ready for retail sale comfortably. You could even use that as a sales tool " you choose the suite and the tiles, and we'll fit it ready for you to move in ". Leave some strategically places hot / cold / central heating pipes in the ceiling void of the ground floor 'mother of all mower sheds' for attachment to later in life, likewise with a gas / large electric cable for the cooker ( if it ever becomes self contained eg you take to long building it and YOU end up living with the mower ).
  4. Buy the monument one and see how long you keep your one afterwards The black rubber ends come off the Tommy bar so you have to glue them on. I went for a few turns of insulation tape tbh, so I can take the bar off if needed by simply removing the tape. .
  5. Im a big believer in engineering a solution to suite the remit Peter, so yes your right, it can be done that way. The reason I haven't chirped up is that it's not easy to do and requires a joint / multiple joints to achieve. It's also not preferable to have an AAV ( automatic air vent / release ) in any position other than one of free and easy access so it can be inspected / replaced etc.
  6. I have this one It's got much slimmer profile heads and takes up far less room per rotation. I can do taps by feel alone with this one, and the one above I launched after owning it for a day or so. The difference is night and day
  7. There are some make / manufacturer 'name drops' in those images, but these are all just random 'net grabs FYI.
  8. There are, I'm sure, many different types A typical installation for ceiling penetrations ( duct / light ) etc.
  9. This shows the buckle / hasp a bit better
  10. The ones I fit are identical, mostly required on HMO / student rental refurbishments. They are steel belted and have a robust buckle / hasp arrangement so re the comment about them being surrounded by bricks / similar I'm not entirely sure that's the case. These are capable of expanding during a fire, and provide that force by means of expanding against said collar. Expanding entirely to close an opening is only possible when the pipe itself deteriorates ( eg the heated / melting plastic of a soil pipe softens and aids the total closure / compression ) but I'd certainly not use the term 'crushes' tbh as it's possible for someone to wrongly assume that it has the strength to do so to any random pipe. One of metal construction for eg will not crush as it will have immense strength when force is applied equally to it's outer diameter Only nit-picking that statement as this is a particularly important subject I've fitted these collars under the watchful eye of BCO's and I can tell you that they're accepted even when fitted to two layers of fire rated plasterboard, with no other mechanical fixing, and no brick / block work / similar solid construction. These will work in a TF house as well as in any brick built house, AS LONG AS THEY'VE BEEN FITTED CORRECTLY. Heres a random internet photo to demonstrate such an instance. The only requirement that the BCO wanted, on the couple of holes where these were fitted into solid walls, was to insert these into the void and cement them in. Then for the mechanical fixings ( screws / other ) afterwards
  11. If it's the same tap connectors that came off, they should 'fly' ( ) back on. Are they SpeedFit tap connectors? Eg plastic not metal, or are they flexis?
  12. Manifold can be above the loop, but not below it. Eg, you can have your 1st floor manifold drop downstairs for a single or multiple loops without a single issue. I did a big job ( 100m2 ) Ufh downstairs and manifolds under the 2nd storey stairwell upstairs. Works perfectly with 8 loops going down. Air is the biggest problem so the vent on the manifold needs to be the high point. .
  13. 3 100% valid if my kids are anything to go by Its like a scene out of ghostbusters..... "never cross the streams" ☔️
  14. Private browsing and having zero to do with 'unsocial media' are your friends. ?
  15. No real need tbh, unless it's in particularly dodgy place.
  16. That's me snookered then. Take me now lord.
  17. In Ian's words, "long on promise, short on detail". I'm not qualified to comment on the insulation, but that advert has inspired my new plumbing brochure
  18. Clearly, the celebration here is that you found a good plumber. Im lost for words as to how this has been responded to, and can only hope that Byron will come back to me after his holiday and offer some resolve. I will most definitely be providing closure from this matter, through accounts of my own exchanges, by means of posting here accordingly with the outcome. Ill hold off recommending a screed company
  19. It's something that gets overlooked when cutting holes in buildings / walls / ceilings tbh, so feel free
  20. If you want to extend the chrome stub Chrome 35mm compression socket I use those plastic reducers but I fit the bent one in the wall so you can't see it. A few options here
  21. That pic shows the tee. Is there a piece that you have that screws into that which leaves you a stub of pipe?
