Temp
Everything posted by Temp
BBC R4 You and yours is currently discussing the shortage of building materials. Small builder reported delays of 30 weeks plus for bricks and roof tiles. Also price increases of 10-15% Will be on iPlayer later if not already. Last item in the program.
Interesting construction. What sort of blocks are the walls made of? Will there be external insulation? I noticed the floor joists are dovetailed into the beams. Cool.
OSB 3 Vs 4... https://www.egger.com/shop/en_LV/product-comparison http://www.osb-info.org/rightgrade.html OSB 4 is heavier duty and swells less in high humidity.
Perhaps too late but.... Between arranging a meeting and actually meeting our architect he had been to the site and done some pen and ink sketches of what he thought would suit the site. Architect fees for supervising the build phase can be expensive so decide if that's something you can really afford or need. Some Architects will propose a fee which is a percentage of the final build cost. Avoid this because it means they get paid more if cost over runs. If you decide to install a better kitchen than initially planned you can end up paying the Architect extra even if he's not involved in the kitchen design.
If they pay at the begining of a stage it's an advance mortgage. If they pay at the end of a stage then it's an arrears mortgage. Sounds like you have an arrears mortgage. Normally builders are paid in arrears so either should work. I you are using subcontractors and buying materials without a credit facility then an arrears mortgage could be a problem unless you have some cash. Best check the terms and conditions.
I would also look for one that has a relatively flat bottom. Some are quite curved which can make them dangerous to stand in.
Desperate advice for access road
Temp replied to Vijay's topic in Party Wall & Property Legal Issues
Sadly it's very common for planners not to take enforcement action. They don't have the manpower or money to take someone to court unless the breech is severe. I think it's extremely unlikely they would take the developer to court to make him make rip up the block paving just because he laid it early.- 70 replies
- access road
- legal
What do the "approved plans" say about the road construction. The pavingexpert website has construction details suitable for a public highway.. "This page details the procedure used to design a block or brick pavement for public highways, car parks, freight yards etc."... http://www.pavingexpert.com/blokroad.htm How do they compare? Presumably rubbish lorries (and oil tankers?) will also use this road? Perhaps tell other owners that if the road isn't built to the required standard you won't accept responsibility for any damage caused. Point out it will be impossible to prove if any particular damage is caused by rubbish lorries or delivery lorries to your plot. Will it remain a private road or will it be adopted? If it's going to be adopted then there are minimum standards of construction required. However many councils will wait a year after the road has been constructed, then they will inspect it and ask for any damage to be rectified before they will actually adopt it.- 70 replies
- access road
- legal
We didn't need to go to appeal because we found written evidence the LPA had told a previous owner of the plot the exact opposite of what they had been telling us.
What do you mean by "This contractor has registered his involvement"? Perhaps I'm wrong but I'm not aware of any registration process other than the normal VAT registration process that a business uses. In which case he should/must zero rate everything to you (eg materials and labor). Any VAT you pay whenyou buy stuff is reclaimed by you using form VAT431NB after completion but within three months. Download the form now and set up spreadsheets. Ask the contractor what he means.
Agricultural Contractor
Temp replied to willbish's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Just for info the relevant section isa vat notice 708 section 3.3.4 https://www.gov.uk/government/publications/vat-notice-708-buildings-and-construction/vat-notice-708-buildings-and-construction -
We did something similar but used lever operated valves.
VAT CERTIFICATE
Temp replied to lizzie's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
I think technically a certificate is only needed if you are building a charitable building or something like that but it can be used to convince a reluctant contractor to do what they are meant to and zero rate. At least that way the subcontractor has something to wave at HMRC if they question his VAT return. Interesting. Also found that discussed here.. https://www.justanswer.com/uk-tax/7pbn3-vat-i-m-building-new-house-once-complete-hope.html One view is that VAT is only charged if the "house" is sold after a change of use. So if the self builder sells it as a house after say 5 years and the new owner converts it to a hotel then he might have to pay/repay VAT when he sells it as a hotel. I never actually supplied the HMRC certificate to any trades. I just wrote them a letter stating that the work related to a new build and should be zero rated, and included relevant details like my address and the planning reference number. -
So you hope a remortgage would be at a lower interest rate than your existing mortgage? Where are you living at the moment? Are you living in the holiday let?
VAT Ground workers
Temp replied to Triassic's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
It's all in Vat Notice 708. This tells trades what they should/shouldn't charge you VAT on. If he provides materials and labor they should zero rat both to you even if he paid vat on the materials himself. He should reclaim that when he does his vat return. Might help convince him if you give him a letter stating this work is in connection with a new dwelling and put the address and planning reference on it. Any problem and we can find the relevant section in Vat 708 to quote to him. -
This could be of interest to someone planning to convert a building to holiday let's or similar... http://www.huntspost.co.uk/news/matched-funding-available-for-small-and-micro-rural-businesses-1-5463226 Might just be in that area but perhaps similar funding available in other areas?
CIL consultant??
Temp replied to albert's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
That's usually what happens if an owner extends their own house. I think that's an option if a builder buys a house, extends it, and resells it? I doubt it happens very often as all it does is delay payment of the cil and potentially complicate the sale. I suspect most builders just pay the cil or do smaller extensions to avoid it. It's also what happens if someone buys a house with pp for an extension that hasn't been started yet. They can decide if they want to build the extension or not. If they don't build the approved extension they don't pay the cil. If they do build it they can apply for the exemption before they start. -
CIL consultant??
If it's not exempt you will have to pay it. If it is exempt as a self build extension then it's essential you follow the procedure on the exemption form. It actually says on the form that if you don't do xyz before starting work then you become liable for the full CIL. Down load the exemption form, read and highlight the things you need to do before starting. It's not very complicated. -
That makes sense to me. There has to be one person or company with overall responsibility for the site. If you use a prime contractor to build your house then it's their job and they become responsible for all the other subcontractors, site visitors, and even the customer when he's on site. If you take on the job as prime contractor and hire subcontractors yourself then it's your responsibility. My guess is that other trades didn't know they should really be asking you for copies of your insurance even if they have their own.
Normally what matters is were they insured on the date of the acident. If they go bust soon after that shouldn't matter as the insurance co is still liable.
Brick Shed Coversion - Advice needed please
Temp replied to Pjbrandon's topic in Garages & Workshops
Play houses are on a different scale to normal buildings. They are sized for kids, windows are lower, doors smaller and have slides etc. Prices rang from £250-400. I suspect it might cost that to properly convert and damp proof your existing building. I think ship lap boarding is at least £12 per square meter. You didn't say how big it is but say it's 3 x 3 x 2.4 high then each wall is 7.2sqm. Four outside walls come to 28-29 sqm or £336. Double if you do the inside as well. -
How much space for storage & welfare on site? Minimum?
Temp replied to Dreadnaught's topic in Project & Site Management
If you had loads of space you would have a full size container and a small office/wc. The storage container is essential for first fix items like pipe, electric cable, windows and tools that might be on site before the building is secure. My builder told me he never uses an insulated or heated office because he said it encourages people to sit around drinking tea in winter.. I think the key thing is can you park a container and static van on the drive and still get a lorry with crane offload past it to the house? Heavy vehicles coming and going may churn up that side of the driveway, perhaps requiring hardcore to repair. So make sure you won't want that area to be a flower bed later. eg Put any temporary road where the final road is going so you don't have to rip up hardcore later. If the drains and other services are going down the driveway perhaps put those in early on then put the storage container/office on top?- 21 replies
- storage on site
- hard standing
Can planning permission mandate a specific supplier?
Temp replied to epsilonGreedy's topic in Planning Permission
Here is the excuse the builders gave.. https://www.theguardian.com/environment/2008/jul/03/ethicalliving.architecture
