Temp
Everything posted by Temp
Is it just wood you are painting or metal as well? I ask because Zinsser are known for special paints for metal or damp locations.
Self Build VAT Claim On Machinery Purchase
Temp replied to Kerron Allen's topic in General Self Build & DIY Discussion
One common gottcha is with trades that also supply materials... This has come up many times on the forum.. Normally labor should be zero rated to you, so no VAT to pay or reclaim on that. However if the tradesman also supplies materials (eg wire, plaster etc) then those materials should also be zero rated to you. This can cause problems if the tradesman has had to pay VAT on the materials when he purchased them. You can't reclaim the VAT because the invoices will be in his name. If he is VAT rated the correct procedure is for him to reduce his quarterly VAT return by the amount of the VAT but he may never have done this before and be reluctant to do so. For this reason you should make sure all quotes include VAT at 0% and make sure they understand before work starts. If you run into problems getting quotes zero rated come back here and we can refer you to the right section of VAT 708. Sometimes it helps to give the tradesman a "certificate" but you don't need to under the rules. If the tradesman isn't registered for VAT you have a problem. Neither of you can reclaim VAT on materials he's purchased. In which case if you really want to use him you will have to purchase the materials yourself to get a VAT receipt in your name and "free issue" the materials to the tradesman. As others have said the VAT situation is complicated. Some you reclaim, some you can't reclaim and some you should never pay in the first place. If you pay VAT in error to a tradesman you can't get the VAT back from HMRC. -
Another way to beat the system is to submit landscaping plans with your planning application. Then the VAT on any trees on those plans can be reclaimed. -
There is a way to claim for white goods but you have to find a "free" white goods deal or negotiate one. In reality the value of the white goods is hidden in the total order price. One possible problem with this approach is that free goods may not have the same protection under consumer law. If there is a fault you might be entitled to a replacement but not your money back because they were free. -
If it's pressure treated wood not everything will stick to it - so I would use a exterior wood preserver. If its not pressure treated then something like Sadolins Extra (Extra not Classic).
We have had a FreeSat dish for 11 years. It's been totally painless. Never had to go near it.
But you could just as easily detect the cable in the duct.
Seems plastic conduit is ok outdoors according to.. https://www.theiet.org/forums/forum/messageview.cfm?catid=205&threadid=15130
Actually it looks like NYY-J cable costs more than SWA.. https://www.tlc-direct.co.uk/Products/NY1dot5slash3.html https://www.tlc-direct.co.uk/Products/SW1dot5slash3.html
Perhaps a qualified electrician could comment on the possibility of using NYY-J Cable underground in something like 25mm black HDPE pipe to protect it. Would that be much easier to joint in the cavity behind the lights? NYY-J cable (similar to Hituf cable)... https://www.tlc-direct.co.uk/Products/NY1dot5slash3.html?ad_position=1t2&source=adwords&ad_id=209463183764&placement=&kw=nyyj cable&network=g&matchtype=e&ad_type=&product_id=&product_partition_id=&test=finalurl_v2&gclid=CjwKCAjw_tTXBRBsEiwArqXyMjgFDqoS4uAo8jbcK67p5R3vACdBCReLQorwfJHv2MZyNeoeUKDOtRoCZR4QAvD_BwE
Certificate of title - section 50
Temp replied to Construction Channel's topic in Party Wall & Property Legal Issues
http://www.essexhighways.org/applications/for-contractors/section-50-street-works-licences.aspx and the link OneOff posted says..- 10 replies
- section 50
- certificate of title
Can't say I like the all tarmac front garden either.
Looking good. Not sure if this is relevant to you and you may know already but... We had some doors made for an outbuilding. The panels were T&G boarded. When they were assembled the boards were fitted tight together. Some time later the wood swelled and the whole doors bowed/looked pregnant. I ended up having to run a circular saw between each plank to cut the tongues and provide room for expansion. This solved the problem at the expense of some extra "ventilation". The moral of the story is not to fully hammer the boards together but leave about 3mm at the bottom of the groove and at the shoulders like this. Use temporary spacers to get the gaps uniform...
+1 to a master socket with separate phone and broadband sockets. No need for filters anywhere else. With one of these you must plug the modem into the master socket but that's also recommended if you want the best broadband possible. Tell BT where you want the master socket and modem to go. We use DECT cordless phones with the primary base station plugged into the phone socket on the master. That way we have almost no "phone" wire in the house. Just two short wires, one from the master socket to the modem and one to the DECT base, all three in same cupboard.
+1 on the foundations. They should have dug trial pits to see what was there. Any movement/expansion joints?
- 12 replies
- walls
- garden wall
(and 3 more)
A quick look here suggests the penalty is £120 or £80 if paid within 28 days of the penalty being issued but it seems likely that you would be hit with more than one.. http://www.legislation.gov.uk/uksi/2007/1952/schedule/2/made
I'm have to go out so in a rush.. See.. https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/614845/street-works-qualifications-guidance-for-operatives-and-supervisors.pdf "The registration body will then record the certificate on the street works register" Perhaps the register is online?
I would get the phone line installed using BT then switch to whoever you choose afterwards when it's working. In theory all ISP should have the same relationship with Openreach that BT do but I'm not convinced.
We have been with PlusNet for 10+ years. They aren't perfect but I've always found their customer support quite good. My main gripe (also with other ISP) is the lax security some apply to email account passwords. If your email account is hacked the bad guys can request new passwords from other companies that reset passwords by emailing you a link. See also.. From 2015.. https://www.theregister.co.uk/2015/11/25/plusnet_still_delivering_passwords_plaintext/ From 2017.. https://community.plus.net/t5/My-Account-Billing/Password-security/td-p/1419734
I would allow at least enough room to get a narrow scaffolding tower up past the verges. Narrow scaffolding is around 0.85m but you need some extra space to move it around so I'd say at least 1m from the verge (which is more than 1m from the wall). Any rainwater down pipes or boiler flues on that wall? PS: Narrow towers that tall should have outrigger legs but that would add a lot more space. PPS: A Wheelie Bin is about 60cm wide so perhaps allow at least 75cm to get one down there easily.
If you get caught by that find out if the company has a "Commercial Entity Agreement". If it does that section 75 of the consumer credit act might still save you.. https://www.telegraph.co.uk/personal-banking/credit-cards/section-75-credit-card-warning-online-payments-lose-protection/
VAT receipts
Temp replied to Badger's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Yes till receipts under £30 were ok when I did mine. Places like BnQ hand wrote a separate VAT receipt when I asked for one. -
Importing from China may incur import duty and VAT but might be able to reclaim the VAT? https://www.johngood.co.uk/2017/08/03/importing-from-china/
Capital Gains Tax
Temp replied to Calvinmiddle's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
I would explain the info you put on the form in a covering letter. Remember that your calculation may also be shared with the tax authorities in your new country of residence and they may not have an exemption for PPR. -
Understanding building regs about stoves (Scotland)
Temp replied to ProDave's topic in Stoves, Fires & Fireplaces
More.. I understand your confusion with figure 3.43 but my understanding is that only applies to stoves that can heat the hearth over 100c. It looks like the regs were written at a time when everything needed a constructional hearth so all the sketches applied. Then some time later when stoves became popular they added paragraph b).
