Temp
    43
Everything posted by Temp
  1. If it's not exempt you will have to pay it. If it is exempt as a self build extension then it's essential you follow the procedure on the exemption form. It actually says on the form that if you don't do xyz before starting work then you become liable for the full CIL. Down load the exemption form, read and highlight the things you need to do before starting. It's not very complicated.
  2. That makes sense to me. There has to be one person or company with overall responsibility for the site. If you use a prime contractor to build your house then it's their job and they become responsible for all the other subcontractors, site visitors, and even the customer when he's on site. If you take on the job as prime contractor and hire subcontractors yourself then it's your responsibility. My guess is that other trades didn't know they should really be asking you for copies of your insurance even if they have their own.
  3. Normally what matters is were they insured on the date of the acident. If they go bust soon after that shouldn't matter as the insurance co is still liable.
  4. Play houses are on a different scale to normal buildings. They are sized for kids, windows are lower, doors smaller and have slides etc. Prices rang from £250-400. I suspect it might cost that to properly convert and damp proof your existing building. I think ship lap boarding is at least £12 per square meter. You didn't say how big it is but say it's 3 x 3 x 2.4 high then each wall is 7.2sqm. Four outside walls come to 28-29 sqm or £336. Double if you do the inside as well.
  5. If you had loads of space you would have a full size container and a small office/wc. The storage container is essential for first fix items like pipe, electric cable, windows and tools that might be on site before the building is secure. My builder told me he never uses an insulated or heated office because he said it encourages people to sit around drinking tea in winter.. I think the key thing is can you park a container and static van on the drive and still get a lorry with crane offload past it to the house? Heavy vehicles coming and going may churn up that side of the driveway, perhaps requiring hardcore to repair. So make sure you won't want that area to be a flower bed later. eg Put any temporary road where the final road is going so you don't have to rip up hardcore later. If the drains and other services are going down the driveway perhaps put those in early on then put the storage container/office on top?
  6. Here is the excuse the builders gave.. https://www.theguardian.com/environment/2008/jul/03/ethicalliving.architecture
  7. The building was the summit building on Snowdon.. Previous thread from the ebuild forum.. http://www.ebuild.co.uk/topic/16443-planning-conditions-getting-one-amended/ The link I posted in #16 doesn't work but there are extracts in #18 reproduced below..
  8. Last time this came up I posted a link to a story about a visitor centre on a mountain somewhere. There was a fuss because the builder hadn't used local slate and the council said they weren't able to mandate use of local slate because of EU competition law. I've not been able to google it when I tried just now but will have another go.
  9. I assume you have put wire in the conduit? Fit back boxes now and coil the excess wire up in them. A good plasterer will manage to avoid filling the back boxes leaving them visible. At worse you might need a hand held tap to clean out the face plate screw holes. I once had a summer job with an electrician fitting face plates in an office block. On one floor we had a face plate left over. Turned out the plasterer had gone right over the back box so well it was invisible. The electrician found it with a metal detector but to send the plasterer a message he also dug holes all over the place so the plasterer would have to come back.
  10. Don't miss the jumping/back flip in the second half.. Edit: Oops sorry I meant to post this in the off topic section.
  11. I'm using hikvision camera which seem to be good quality without being silly money. However I use a NAS server in the loft for storage. Would your broadband _upload_ speed be good enough to stream to off site storage?
  12. I think they would be horribly slow. Much quicker just to give them a few taps with the block.
  13. My top tip for tiling is to learn how to use a rubber faced tile beating block (aka Blat) to level the tiles. It's a technique my father showed me but I've not been able to find a youtube video. You apply adhesive using a notched trowel so you can adjust the amount the tile stands off the wall in the normal way. Then you rest one end of the block on one tile then lift and gently tap or press the other end against the tile you want to level. This makes the two tiles the same level. Repeat over an area of tiles and they all become remarkably flat. I've seen people use a spirit level (as a block) to level floor tiles in a similar way. Google found a picture of the block I have but the web page says it's not in their current catalogue. https://www.rubi.com/en/tile-beating-block-rd326
  14. NHBC have a lot on floors and joists in their site work guides.. http://nhbccampaigns.co.uk/landingpages/techzone/previous_versions/2011/Part6/section4/sitework.htm Builders merchants are full of bent bits of metal for this sort of thing. I think you normally use a L shape strap hooked over the wall and nailed to the joist in addition to the hanger. One of these straps every 2m. Something like that. PS: If it's different for Posijoists I would ask them.
  15. I think that's true for hangers fitted to a timber wall plate. The pictures of masonry hangers show no nail holes on the bits facing the wall. http://www.strongtie.co.uk/products/detail/heavy-masonry-hanger-for-solid-joists/341#tab-installation
  16. Not normally but I see Incipiens Mox said..
  17. I wrote my own "Tree Protection Method Statement" but that was rather easier. Google can find templates for asbestos removal method statements but I've no idea if they are any more than section headings or have far too much content... https://www.haspod.com/documents/method-statements/asbestos-removal-template?gclid=CjwKCAjwhcjVBRBHEiwAoDe5x3fRgKgIoXVFKWV2_BgHu84hFZ2j9vaizwIjACKZStGPYZ1uM9MLoBoCjnQQAvD_BwE https://www.hsdirect.co.uk/product-information/method-statements/asbestos-removal-method-statement.html You can also find examples that other people have written for specific projects. This might be useful ... DIY Asbestos sample and test kit for £37.. https://asbestossamplesdirect.com/
  18. I think the key word here might be "Alternatively". As I read it they are recommending further sampling or "Alternatively" send all the spoil to a licensed waste centre. That would probably be expensive so ideally you want to do what Declan proposed which is to dig some out, sample it and if no asbestos found send that lot for regular disposal. The question is can you write your own method statement that documents the process or will the BCO insist you get an expert to write it. I think it will need to include things like warnings to site workers for example.
  19. even if same batch code I would check samples from a few boxes anyway. Would be a pain to find out half way through that you should have mixed the boxes.
  20. I always thought 3D printed objects were fragile but someone told me recently that they are now 3D printing parts for direct use on F1 cars.
  21. +1 to DECT phones. Get a set of 4 or 6 and scatter them around the house.
  22. Can they mole under the road and you do the rest? https://www.mumsnet.com/Talk/property/2914930-Cost-of-impact-moling-under-house-to-install-new-water-pipe "..had it done for a new water supply pipe from the road under the driveway into the house, distance of about 10m, cost was £800." See also.. https://www.ofwat.gov.uk/households/supply-and-standards/getting-a-connection/#_How_much_should
  23. We lived in Belgium for awhile and a lot of the light switches over there have that sort of arrangement. Looks like a European thing.
  24. 4) Tell them you will send the stair details when you have them. Sorry if you know this but guarding is not just about toughened glass it's about stopping you falling if the glass breaks. 5) Have they just made a mistake or does it have a window? If possible echo their words... "I can confirm bedroom 3 will have an escape windows with a clear opening width of ?? which is in excess of that required by Part B"
  25. I know it's a pain but I don't think you have answered their questions with the detail they expect... 1) Your response to refers them to other drawings and hyperlinks which probably has the info but heck I would just tell them how many "minutes of fire resistance" the design provides as well a providing the references. 2) You are effectively saying "it will meet or exceed Building Regs". Where as they appear to want projected flow rates so they can check it will meet building Regs. 3) They want you to show how you will meet Part R. https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/517789/BR__PDF_AD__R__2016.pdf I think you need to tell them that the duct and cable between the "service providers access point" and the "occupiers network termination point" will be Cat ?? Cable supporting upto ?? Mb/s which is "well in excess of the 30 Mbps required of Approved Document R requirement R1". Part R also says developers should refers to PAS 2016 which has info on duct dimensions more in a moment.
