Jenki
    7
Everything posted by Jenki
  1. Are you sure it's leaking and not condensation? It's been very humid( in Scotland) I doubt it's different in England. It can be surprising how much condensation you can get.. Also how windy has it been, the pitch looks shallow, (but that could be photos,) are the horizontal laps big enough and are they tapped? We're building in a windy location so will be using felt with tape to prevent water being driven in. Take a Big breath, it's better finding faults now, and fixing them l, than lying in bed and finding it still leaks.. this is a positive although it might not feel like it.
  2. How will you prove you have necessary skills? Similar to part P, if you do the DIY route expect an additional charge to get someone in to prove it's safe. BC will not take that risk. The plumbing and theory of G3 is straightforward, but there are pitfalls and ambiguity, a lot based around D1 and D2 discharge pipes.
  3. From my G3 course, Bottom paragraph in bold. This was a BPEC course.
  4. Let's see what the diamond polishing does😜. But that will probably have to wait, going to start on the walls while the weather is still good, so some OSB on top to protects it from the scaffolding. ( I'm putting it on the inside to help with bracing the walls)
  5. This is inside the ICF, so no shuttering to remove, I did use some timber battens to protect the ICF from a vibrating screed. These are obviously staying where they are.... off to water the edges of my slab 😁
  6. It goes on whilst the concrete is still wet ish. And you can't cover with plastic as it can cause the sealer to bloom, it does suggest in extreme temps to re coat after 3 hours, so I did that at around 21.00 last night.
  7. Day 31 of the build. (this is taken from the day we started shuttering the foundations) The weather up North has been spectacular for about 3 weeks, so we (Mandy and I) pushed to prepare and pour the slab before the weather changed, as I'm sure we will get a few weeks of low pressure, wet changeable weather after this spell. Following on from the foundation ICF walls, I'd already loaded around 20ton of 40mm to dust in a pile the slab area. Sat on the sand blinded radon barrier. Job one was to sort the drainage. I'd posted previously about my plan, and some constructive comments suggested changing my planned route, but with the extra length of run to the drain invert level I would have had to increase the floor height even more. So stuck with my original sketch. We ran string lines to mark the main areas, namely WC, SVP in the plant room, shower, WC and Bath, a need ran the drainage to the locations, as the utility backs onto the plant room I didn't add a drain in here as I'll run through the stud and use the SVP. Once the drainage was in place and is tested. We spread out the hardcore and compacted it. I used 10mm crush and run to bed the drainage and cover the pipes, I also ran ducting at this level, bringing in water, power, treatment plant feed plus some future ducts. To get the hardcore level / flat I used 3m lengths of galvanised conduit set on mortar pads all level to each other and used a 4M ally beam to screed the slab. I compacted the first layer then used another screed pass to fill in any deviations and used this as the level for insulation. I used a combination of 200 mm EPS 70 (50mm sheets and 100mm sheets all layed to stagger the joints, and used foam to seal to the ICF. The top layer was 100mm EPS150 this gives a firm hold for the UFH staples, and a firmer feel to the insulation layer. We plan to use a large shower tray and have this level with the floor, so I made this area sunken with two layers of EPS150 and a layer of 50mm PIR. As we were installing the insulation I installed 2 * 100mm ducts for the ASHP in the second layer of insulation these were only 800mm long, and a duct for cables. I also added flex ducts in the insulation for Hot & Cold services to the kitchen, utility, WC,Shower,bath, all these were cut using a hot knife. Lastly I cut some pipe for floor sensors in the kitchen, lounge, bedrooms and bathroom. The underfloor heating consists of three loops around 95M length, planned using Loop cad. The manifold was plumbed , filled and a pressure gauge to ensure no leaks. We have good water pressure so could pressurise to 6 Bar. ( With the heat ☀️ this rose to 9 bar one day). The above picture also shows K Steel screed rails. I used these to break the slab into smaller bays, and mainly will be under stud walls. The slab will for the foreseeable future be our finished floor, so I wanted to introduce expansion joints and force any cracking to these locations🤞. I also used Tibmix metallic dry shake topper on the concrete, the dry shake should help suppress the fibres and also increase the surface hardness. The pour happend on Friday 16th June, the first 5cube arriving at 8.30. we did the kitchen bay first which needed the 7t 360 to move / place the concrete, then, poured the WC / plant room and utility bay. This was an error, I wanted to pour the lounge next so both bays could be finished at the same time, but under the pressure of the pour took advice to do the awkward section next. This resulted in only a 3rd of the lounge bay having concrete, so this was spread out lower so the next load could fill the bay. By the time the second load arrived, the kitchen and utility bay was ready for power floating. The pan worked well and I had some time to start edging the slab, the rebar didn't allow the power float to get to the edge of the slab. By 13.00 all bays were in and leveled, but not floated, but the sun was very hot, and the kitchen bays was getting hard rapidly, I managed to float this but was struggling to to get a perfect finish. To dry shake makes the surface hard and this was apparent, the lounge and bedroom bays floated better, and to the main the dry shake suppressed a lot of the fibres but there are still some visible. The kitchen bay was rock hard by the time I managed to float again, and although it is fairly flat you can see, but not feel, the path of the power float. I used Setseal 6 as an acrylic sealer, which seals the surface and aids the curing process. By the time we finished the floor was rock hard, I mean hard, the idea being that the slab will slowly cure now but will not be affected by rain etc. Time will tell. Due to the temp, and the float not getting to the edge, I will have to carry out some remedial work on the edges of the slab, as by the time I go to troweling these it was too late. Today the slab looks great, it's flat and level, but the perimeter 2 inch will need some polishing, as will a section in the plant room. I'm confident I can get this fixed. Time will tell. The following picture doesn't do the slab surface any justice. It looks rough, but it's glass smooth. So 10.5 cube of fibre reinforced concrete. Power Floated, and this was non stop until 17.30. My chest and fore arms are wrecked from trying to tame the power float. I'm a little disappointed in the edge finish, but looking at it another way, it's way better than if it would have started raining, or the wind that we have today. I'm sure a few hours with a wet diamond polisher will rectify the edges. Maybe another hand would have been good. 🤔. Onwards to the ICF walls... .
  8. Hi. I got my vac pump from vevor, but you do need an adapter from the hose to the valve. The video I linked on you tube tells you the size you need 👍
  9. For the cylinder. You need a 2 port if the max thermal cut out stat is tripped. A quirk, but if you have a 3 port you still need a two port to act as a dead stop. All unlikely with a heat pump, but thats the regulations.
  10. Nice cylinder 😜, I've not un-packed mine yet as there's no house😁, Just for your info, you will need to install a two port valve as well to comply with unvented cylinder regs. You can't just have a 3 port valve.
  11. Great result, the place is huge, so good effort 👍
  12. Due to my location North Scotland highlands. this might not work for most. But I've installed my UFH, and the above are now surplus to my requirements. You could always book a stay in our cabins and collect 🤣 I've also got 90M of 16mm pert al pert pipe as well. Thinking £150 for both.
  13. Thanks for the detailed reply. I like the idea of two rain gardens (North& South also) and emptying to a pond. This is going to be my base design, overflow from the pond to a wetland and swale👍
  14. Curious, @Nickfromwales, if you were to supply a shower valve from a plant room manifold with plastic pipe, would you use stubby copper to the compression on the valve, and then add an additional push fit joint? So two hidden joints instead of one? Honest question.
  15. Sorry for the lateness. But I prefer the 1st photo🙈 Compression on plastic if you don't overtighten and use a metal insert is fine IMHO. Would prefer a visible compression to a hidden push fit joint.
  16. Well its seems necessity is the mother of invention, sat down for a few hours, previewed a few of the tutorials, the one regarding importing a pdf was the key for me, I was away then. I seem to have a workable layout now. 🙂 Off to find my floor tacker, and staples. anyone looking at this thread in the future RTFM. (or the video tutorials, they are good. )
  17. I can feel a freehand layout, based on past experience coming on.🤔
  18. Anybody got any quick tips to get my layout working. I downloaded a trial few weeks back and made a start but was struggling to make any progress. The weather has been ace, and if I can get a layout sorted, and ufh installed might be able to pour my spab by next weekend.
  19. You can get folding half doors, that hinge on the screen.
  20. Fiver it does.... Ever tried to wipe with wet toilet roll🤔
  21. Looks like it's on stillages, most farms will have a telle handler, or tractor with forks. Just pick each up and off you go. If your buying from a farmer I'm sure they will help load
  22. I installed a 12p Tricel Nova, the instructions were very specific, "the unit must be lifted of the lorry via 2 shackles connected to the eyebolts and sling of not less the x M long... So I bought shackles and slings ready for the big day. Unfortunately the unit arrived on a curtain sider on pallets so lifted it off with forks on the backhoe. All the preparation in the world only counts when you have full control of the process.
  23. Personally would steer clear of plastic bags etc, as per @JohnMo photo above, coupler and a proper blank these could be set at finished height or a few mm below, then there is 100% zero chance of concrete entering the pipe. the power float will be over the top / skim the blanks and they will be easily visible. the coupler then allows you to connect whatever you need to, and if you do want wiggle room, follow the advice above, re timber boxing or PIR. +1 to this - - You do not want the chance of concrete entering the pipe by a bit of ply moving when tons of concrete are sloshing about.
  24. Could you look at a liquid screed at 50mm and boost the insulation🤔
  25. Is this under building control?. In Scotland none of those at that thickness would pass current building regulations, not sure what England's regs are now.
