Jenki
    7
Everything posted by Jenki
  1. that photo was similar to lots of my tiles, I was not worried about that. We had a good downpour yesterday / night, and I can report the roof looks so much better and cleaner, its still wet as I speak, so no photo, but if it dries today I'll take a photo. This is definitely one of those areas on a build where you worry, and obsess about the task in hand and minute detail, but another issue will soon be along to take your attention and the roof will normalise and be a non issue. I was interested in the Fortecrete tile, but they just don't supply them this far North. I emailed them and they just said no.😂
  2. that photo was similar to lots of my tiles, I was not worried about that. We had a good downpour yesterday / night, and I can report the roof looks so much better and cleaner, its still wet as I speak, so no photo, but if it dries today I'll take a photo. This is definitely one of those areas on a build where you worry, and obsess about the task in hand and minute detail, but another issue will soon be along to take your attention and the roof will normalise and be a non issue.
  3. Slightly different than a hopper, but this was our ICF build.
  4. Your second picture is like water marks, the third picture is more like scratching, I'm just tiling my roof with Marley Edgemere, and have lots of tiles like the third picture, I think I'd have discarded the tiles in the second pic. The scratches will disappear after rain / sun. It does wind me up, you get a pack of 240 tiles, and 20 are broke, chipped and all you get is yes that's wastage🤬 no it's £25 of sh*te I shouldn't have to pay for.
  5. Jenki
    Jablite
    No, for the reasons above. If you post more details of what your trying to achieve you may get some help. Is it ground floor/ first floor etc. If your trying to improve insulation on the ground floor and you have suspended timber joists, option might be to remove the joists and create a floating floor on top of EPS insulation. Not straightforward but would produce fantastic thermal results.
  6. They Are Class 2, so its confusing / conflicting
  7. QUOTE: " In design of modules, the anodized corrosion resistant aluminum alloy frame is applied for rigidity support. For safety consideration and to protect modules from lightning and electrostatic damage, the module frame must be grounded. The grounding device must be in full contact with inner side of the aluminum alloy and penetrate surface oxide film of the frame. Do not drill additional grounding holes on module frame. The grounding conductor or wire may be copper, copper alloy, or any other material acceptable for application as an electrical conductor per respective National Electrical Codes. The grounding conductor must then make a connection to ground with a suitable ground electrode. Holes marked with a grounding mark on the frame can only be used for grounding but not for mounting. Frameless double glass modules have no exposed conductor, and therefore according to regulations it did not need to be grounded. Grounding methods below are permissible 1 Grounding by grounding clamp There have grounding holes with the diameter of Ø4.2 mm at the edge location of module's back-side frame. And the grounding holes are identified with typical grounding symbol according to IEC61730-1 standard. Grounding between modules shall be confirmed by qualified electricians and grounding devices shall be manufactured by qualified electric manufacturer. The torque of copper core wire used for the grounding clamp is recommended to be 2.3 Nm. 12 AWG. And copper wires cannot be pressed during installation in case of damaging. 2 Grounding by unoccupied mounting holes Mounting holes on modules that are not occupied can be used for installing grounding components. ◆ Align grounding clamp to the frame mounting hole. Use grounding bolt to go through the grounding clamp and frame. ◆ Put the tooth side of the washer on the other side and fasten the nuts. ◆ Put grounding wires through the grounding clamp and grounding wire material and dimension shall meet requirements in local national and regional law and regulations. ◆ Fasten bolts of grounding wires and then installation is completed. " My reading of this is they (Longi) need earthing.
  8. Longi panel installation manual require ,grounding see section 7.
  9. As per @Canski. Building plastics online
  10. I've just ordered mine, I'm using the this capit board, but blocking between the rafters with 4x2. I got a quote from Eurocell, but found an online retailer that's was around £200 cheaper with delivery to me way up North. The boards arrived 2 days later, from Eurocell🤷
  11. In Scotland they just dropped off the ducting, using the FTTP duct and connected to the copper network on the other side of the track. The copper network is rubbish, so cancelled the contact and use 4G, but have installed the ducting, so box ticked and no cost.
  12. @Crofter why do you want MCS? DIY vs MCS is chalk and cheese, and if you can do it yourself, then I cant see any positives for the pittance you will get paid vs the front end inflated price robbery of MCS. the figures to me just don't work.
  13. Very happy with the product. And the help Will @ Pollysteel gave. Only issue(as you've read), was a slight movement of the corner block. I was never worried about bursts.
  14. Utility bars are good for removing skirting, if you are not bothered about the plaster. The last one I wouldn't. https://www.toolstation.com/roughneck-demolition-lifting-bar/p63005 The above is great for removing floor boards from joists. And for dismantling pallets. Stud walls a Fubar is a great all rounder. https://amzn.eu/d/gklUw5V
  15. when I've got the solution, I'll blog the install and stand back for the replies...
  16. @dpmiller so would you say this is the best way forward, belt and braces/ a nice to have / or essential?
  17. Resurrecting an old thread as it seems a good fit. I'm looking at ordering my trays now, its going to be 2 rows 5 columns of panels (10). and trying to work out the flashing required. 1: The instructions suggest top flashing is not usually required as the tiles overlap the gse tray. 2: Bottom flashing, I have the option of having the bottom of the panels at the gutter edge. if I were to do this the gse tray would overlap the felt support tray, so would flashing be needed here? any thoughts on this?
  18. living in a static on site over last winter, I can assure you 10 to 12 Deg is not, what I'm aiming for in the house. Granted we had much colder some weeks, but even now with summer giving it it's best shot in North Scotland, 10deg in the bedroom is too cold and damp.
  19. @Nickfromwales. Turned up today. Impressed.
  20. I've not seen the Tiger Claw so would assume much superior to this, but I'm only doing this once😂 https://www.amazon.co.uk/dp/B07K6MTSKT?ref_=cm_sw_r_apann_dp_ANBM4JX1D0QKZ60ZD3CT The Screwfix link is more a k rend float? I'm hoping this will be smoother,my K rend float would destroy polystyrene.
  21. Looking at one of these, haggling on price with City Plumbing and there 15% off using there APP. Anyone any experience with them? they do a Coastal protection option which has some appeal for me being 500m from the sea. They offer a control pack but at £500 I'm looking for alternatives. The house is 88sq M with UFH well insulated ICF. and a 200L heat pump tank. so happy with the size etc, Anybody know If I can just use a standard controller on this unit?. I would speak to Samsung, but I'm sure there will be a lot of pressure to use their kit even if not essential.
  22. as @Nickfromwales said. up here the concrete would not be coming from Inverness 2 hrs away, but that's the only pumps. My budget didn't allow for that kind of expense. so did what I had to do... and survived 😂 Would I have taken that risk for a customer doubtful. The difference is stark really £2K of concrete with free digger hire, and a few IOU some labour hours or £4K with a pump with similar risk exposure. as @saveasteading mentioned, if it all went really sideways I would have had a section of concrete drive instead,
  23. @FM2015 cant stretch to that TigerClaw rasp, but found a considerably cheaper knock off version that should get me through. - thanks for the info👍
  24. So after a few days off the job 1 day rest, and 2days taking care of some other bits and pieces, we've started cleaning up after the pour, and having a proper look at the problem SE ( moved) corner. The block has basically rotated, so on the south wall there is now a gap at the bottom and on the East wall the bottom block sticks out about 15mm Tapering to being back in line. It looks like I'll be able to rasp this flat on the E wall and use some foam on the S elevation. There is EWI going on this. So definitely a bullet dodged, and hopefully a easy fix.
  25. If I remember, you need to request access to create a blog. I think if you use the + button and select blog, it will need mod approval. Then off you go
