Everything posted by Jenki
Cooling UFH slab, using Rainwater harvest tank.
Jenki replied to Jenki's topic in Underfloor Heating
Thanks Nick I was intending of using a thermal store - for both DHW and UFH, no buffer? Main reason is I can do it myself as its not pressurised, ASHP monobloc so again fit myself. So is reverse ASHP an option. with a dedicated loop, i.e bypass the thermal store with valves ? Can all ASHP run in reverse?- 5 replies
- thermal store
- ufh
Although planning a building on the East coast in the highlands, I do have a concern for over heating. Heating to be thermal store - ASHP - PV and ( possible Solar thermal)- all DIY, possibly a small wind turbine connected to DC immersion - it is windy all the time....... Anyway I got to thinking about cooling, and read some people use the ASHP and buffer tank to cool the UFH. I plan to have 6000L rainwater tank ( it also rains a bit), this tank will be underground and relatively cold, so I thought a couple of three port valves and a dedicated loop of pipe running through the tank would provide all the cooling needed and a possible heat dump for the solar. Any thoughts , problems you see.
- 5 replies
- thermal store
- ufh
Thanks ?
Creating "frameless" look by overcladding frames?
Jenki replied to markocosic's topic in Windows & Glazing
I think as long as the trims for your cladding, (header can give you a drip edge), (cill gives you run off and drip edge), and reveals can combine with these neatly, then would look great. I am planning cladding my build, and this is the area that's keeping me awake. Its essential that the detailing for weatherproofing this area is robust, and if any water can get past this cladding isn't going to do any damage to the timber frame. I'm still trying to get this detail to work in my head. I've not found any drawings that fit my scenario yet. -
I agree, battens are too short, they should be longer so the tiles are nailed down, on a verge this should be every row, (not sure that it's a BS requirement) but I don't know any "roofer" that wouldn't, they should be clipped as well, If you had barge boards you could use a dry verge system to hold the tiles in place from wind. But in your situation tiles nailed every row and clipped would be my strategy.
How is this progressing? I'm new to RPi, but like the idea of having multiple sensors, some installed in the slab, some air mounted etc to monitor and essentially control heating / ventilation.
The Spacing to me seems to vary massively, kitchen extremely close, living hardly any? IMO Very bad. Also, I struggle with any in slab / in screed systems not incorporating the spaces under kitchen units. This is a thermal mass so will heat up anyway, or in my view draw the heat away for the areas you are heating. I personally use the whole area and pipe space accordingly. -- BUT I must be wrong as every designer do it.... Can anybody help me to understand why? Electric over floor heating I'm okay with
As you say the cost of Radon DPM is negligible, just wasn't sure I needed to start quoting references etc for the building warrant, never built in Scotland so the Building Warrant is new to me.
Thanks for the heads up on the report ?, I looked at this site and it gave me a 3 - 5% risk, so ordered the report, unfortunately it confirms the Radon Risk "Guidance for new buildings and extensions to existing properties What is the requirement under Building Regulations for radon protection in new buildings and extensions at the property location? - Stage 1" Anybody know what Stage 1 is? They recommend looking at BRE211 - This is £45 There is also a download "radon protection for new dwellings (gg74 Revised)" for £16 anybody got a copy of these or extracts knocking around? Thanks in advance.
Where in the Highlands are you? we hoping to buy land high up on the East coast, 12Miles South of Wick. When speaking to a local who has built 300 plus houses, he said the cost of materials is scandalous at the moment, his current project in inverness the client is bringing the materials to site via vans at the weekend from Manchester as its cheaper.. I'm thinking similar and using a 7.5T. to assist with the move aswell.
HI, I have had an estimate quote back for connection to our plot, there is OH HV cables (11KV) running along the boundary of the field, and at the road a Transformer supply 3 other properties. My enquiry asked for a quote for 15KVA or 20KVA, just so I could get an idea of costs before committing to purchase. The quote came back stating that the existing transformer would be upgraded to 50KVA, associated reconnection of other properties and then laying and connecting to an enclosure (groundworks and enclosure by me). The quote came back at £3500+V for 15KVA and £5000+V for 20KVA, all cables the same. When asked where the difference comes from its basically I either pay for 15KVA /50KVA( 30%) or 20KVA/50KVA (40%) for the transformer with the rest stumped up by the network. So am I missing something or should I just opt for the 15KVA? it will still have 100A cut out? TIA
Hi, I've been reading through a lot of posts on Stick built vs kit etc, and leaning towards stick built, however I read that structural warranty is difficult if the frame is built on site. I'm thinking of getting the frame designed (possibly Cullen Timber Design), then panelised drawings and working from them. straight forward rectangular box, gables and roof. I would be interested not in the stick built vs TF company, but thoughts from builders who went the stick build route on their structural warranty views, did they get one, which ones etc. any info on this would be great. thanks in advance.
- 1 reply
- stick built
- timberframe
ASHP / Thermal Store / hot water and UFH to external pods
Jenki replied to Jenki's topic in Other Heating Systems
Budget is the issue?. The main expense is the ASHP and Tank. But I'm buying them anyway. So if I can use them it's got to be cheaper than individual units etc. Is my thought. -
I'm in the planning stages of a small croft house 86SqM, and initially 2 self contained glamping pods, possibly more in the future. The site is in the Highlands near the East coast. I have an Idea and would appreciate any thoughts. I'm thinking of installing an ASHP in the main house, and a vented thermal store with solar coil. (Vented so I can plumb myself) and UFH with passive type slab All straight forward, but then I'm thinking of trying the heat UFH of the pods and supply the hot water as well. Outline plan pods will be 30 and 40 meters away. Can be changed. Lay pipes 22mm hot X2 and flow and return with insulation about 1m maybe deeper in the ground. T into 1 pod then onto the 2nd. Firstly due to lengths I'm thinking of recirculating the Hot water (hense 2xHot) so a concern is that this just drains the heat from the tank, If the temp drop of the returning hot is too great. Any ideas suggestions / thoughts / criticisms more than welcome. Regards Pete
