Everything posted by Marvin
Identify all the services to be used in your home. Consider heating and cooling requirements. Consider AIM: (Airtightness, Insulation and Mechanical ventilation with heat recovery), and if your going to go APE: (ASHP, Photovoltaics and Electric Vehicle charging). Do a thermal loss and gain calculation based on the shape, size and thermal resistance of the building. Consider solar gain in your design. A well insulated building can easily overheat if this is not taken into consideration. Our renovated bungalow can overheat if the outside temperature rises over 10C. Peak energy requirement at calculated temperature extremes indicates that we will need as much cooling on hot days 30sC as heating on cold days -8C. Good luck. M
- 16 replies
- self build
- sips
(and 2 more)
A long time ago, as best as I remember, the foreman's comments went: "Well, when we finish this job we will go down to the hospital and carry on where we left off until we're made a better offer alright? Then it's off to that job. The hospital pays less but it means that we don't have to sack you and replace you when the next job starts. Then the phrase was about bread n butter, and jam. The former the basic jobs that kept you going and the latter the ones that pay better money, and then about pulling my finger out and getting on with it.
How does your garden grow?
Marvin replied to recoveringbuilder's topic in Landscaping, Decking & Patios
Err pass -
Along with the late, great, Bob Monkhouse. -
We can see the gardener's amongst us. Box has small shallow weak roots. My guess would be fork and spade work.
Another 'Cool Energy' heatpumps thread
Marvin replied to HughF's topic in Air Source Heat Pumps (ASHP)
My heating pump is on a programmable thermostat. The ASHP heats the buffer to the set temperature. -
Hi Does a garage ceiling below a habitable space require a vapour barrier? Fire requirements all known. Thanks M
Working on reducing mains power by best use of PV (without batteries).
Marvin commented on Marvin's blog entry in ASHP, MVHR, PV and EV combo
So @Conor your ASHP up and running now?- 15 comments
- pv
- tumble dryer
- (and 7 more)
Show off! 😂- 15 comments
- pv
- tumble dryer
- (and 7 more)
More on possible rainfuel? https://www.eurekalert.org/news-releases/589427
Nice!- 15 comments
- pv
- tumble dryer
- (and 7 more)
Air in the cold supply causing the mixer to stop because of the over heated hot water: anti scalding device shutting the valve? Turn to fully cold. What comes out? and or what temp says
What sort of system were you thinking of?- 15 comments
- pv
- tumble dryer
- (and 7 more)
Hi @ProDave Thanks for all the info! All good stuff: Yes we have the Solic 200 PV diverter as noted at the bottom of my post. Yes like and use all the options with the tumble dryer which again reduce the kWH's. Yes middle of the day dishwasher and washing etc. We also charge anything we can when the sun is up and the car is not charging: Phones, Computers, mobile phones, rechargeable batteries for all sorts including power tools, mobility scooter, rechargeable lights and so on. Hot water is mostly heated by the PV diverter. We have 5.12kW PV and on the Isle of Wight we have about 1900 hours sunlight a year, Scotland about 1200 hours! I am considering how to deal with the ASHP back up timing. Maybe set for 2pm. This is a complicated calculation. But I will not bother until I have replaced immersion heater to a 3kW one. At the moment we're not too worried about how much we're exporting, more how much we're buying. I know which will be worth more to us! But will get to it eventually. M- 15 comments
- pv
- tumble dryer
- (and 7 more)
1. Not on my North facing roof. 2. Not during the night, and rainfall totals vary widely across Scotland— the western highlands of Scotland is one of the wettest places in Europe with annual rainfall up to 4,577 mm (180.2 in).
Thank you @SteamyTeafor this information, which I have only just caught up with and will now read in detail.
Having now had a 5.12kW system running for about 6 months, usage seems to be forming a pattern. It appears we are buying an average of about 11kW a day so 28p times 11 times 365 days means a bill of about £1,200 including vat and daily charge etc (This includes charging the EV but see below). We are trying to improve this without becoming anal about it. When you consider that our PV system realistically reaches, about 5kW max (due to orientation and roof angle) and about 1kW on a good winter's day, you begin to realise that the more you can reduce high energy peaks and spread the load over the day the less you will have to buy. Most of the time we need to think of equipment that uses electricity at a low rate of power per hour over a longer period to use most of the PV power. To replace our old tumble dryer we purchased one with a heat pump. We knew that it would take longer to dry clothes and that they still use less electricity to do the job, however it was hard to find info on peak wattage. We were please to see that the peak wattage was about 1000W during drying and overall less kWh's used, so low and slow compared with our old dryer. We have a 4 ring induction hob, which to be honest is a good thing and a bad thing, as far as I am concerned. I love being able to wipe the surface clean easily which keeps it looking good, however, when it comes to power usage I don't like it. It is very hard to test because I would need a 45amp amperage tester, but based on timed meter readings the sounds the induction hob makes and the reaction to the contents of a pan of water, I am pretty sure that it works like this: When you turn a ring onto full power, the small ring uses about 1-1.5kW continually. When you turn the ring down to half power it still uses 1-1.5kW but for only half the time: You can hear it ring clicking on and off and observe the water boil / not boil. so the peak power is always the 1-1.5kW. so not good. Also easy to scorch a little of something in the bottom of a pan.... Interestingly slow cookers seem to work the same way as the induction hob, but at a different level, and turn on and off for periods of time to achieve the different levels indicated on the controls (i.e. warm, low or high). After testing 5 new ones the results seem to show they run at about 300W peak power and turn on and off on the low setting, and so more cooking has been done recently using the slow cookers. If your into bread makers they also run at a low wattage and power usage and we use one. My mother had a low wattage kettle which required you to decide if you want to have a cupper in about 10 minutes time. I was not designed to do this and must have been faulty, however we are not going to use it! The item that I got wrong was the Immersion heater. I thought of low and slow but this is wrong. What happens is that as other house equipment turns off and on in the gaps suddenly there is 1 - 3kW pf power. However I changed the immersion for a low wattage one and so a lot goes to the grid during these times which could be used to heat the hot water. I kept the original 3kW one and will swap the before the end of the summer. The immersion heater temperature setting will be set higher in the winter than the summer and the 200L HWT will be used as a thermal store in the winter. I have noticed the heat leakage from the HWT to the buffer so wish to avoid this during the summer when the ASHP is cooling the bungalow. The charging of the electric vehicle is achieved in 2 ways. Using a CT relay switch, during the summer, the car will be charged when the PV produces over 3kW and in winter when the PV produces over 1.5kW. The other option is to charge whatever the PV is producing. I admit that the EV is only doing about 4000 miles a year and is plugged in when at home (most of the time). As it belongs to SWMBO I'm not allowed to transport the mixer in it! If you drive 10,000 miles a year, spending 5 days a week at work and out at weekends, PV will not help much with charging the car (unless you spend THOUSANDS (at present) on a 80kW battery system). Note the EV is not charged at home but elsewhere about 5 times a year. Going forward we are looking into a possible Ridgeblade system/ type system to produce power from wind as we live near the coast. We have installed a weather station on a shed but aim to move to the top of the ridge to obtain more accurate wind direction so hopefully we can calculate if we have enough in the right direction to think of installing something. Rainfuel. We are still searching into power production from the electrical charge in rain water. Search for technical information has produced very little result and I fear needing to eventually conduct large scale trials. To do this I will need to do small scale trials and before that I need to consider as many alternative set up options related to a building installation and as many alternative ways to introduce the rain water to the contacts. Good luck with your project. Marvin Situation that this information relates to: 100m2 Bungalow, 2 people, 200 litre HWT, 13amp EV charger, Solic 200 immersion controller, Energy source only electricity, with AIM and APE elements. That is Airtightness, Insulation, Mechanical Ventilation with Heat Recovery, and Air Source Heat Pump, Photovoltaics and Electric Vehicle.
- 15 comments
- pv
- tumble dryer
- (and 7 more)
Fashion changes all the time. I often think about this sitting on my advacado loo next to my chocolate coloured bath with gold taps. Whilst warming my head on the wall mounted bar heater watching my polystyrene ceiling tiles melt. Still, at least my bell bottoms are still in fashion.
Hi @jayc89 Do you have a solid floor, or a suspended floor with air bricks?
I would be surprised if the concrete to concrete interface was a problem. The depth is usually to do with the stability of the ground. I presume the deeper block work was a design choice, however I'm sure someone will correct me. Hopefully the blockwork below ground is either solid or the cavity is filled - possibly with concrete. M
Welcome. One of the things I've learnt is you never know what's behind the paint! M.
I've just noticed that this tread was started 3 years ago. I assume you are on day rates. Heaven help you, if your on a price! (Must admit there looking the dogs .........)
It maybe that for a typical residential property an ASHP needs to be able to run more efficiently without a buffer tank and the way forward may be a double compressor. Certinally my ASHP would have room in its current volume as the gubbins only takes up about half the height of the area to the side of the fan. The government report (ask @SteamyTea) identified the problem for a typical home of finding room for a buffer tank. But really, far far lower energy usage results are achieved through AIM: Airtightness, Insulation and some form of MVHR, before going on to APE: ASHP, PE and EV. The only thing we're waiting for is a cost effective way to store electricity and then we won't care about the nuances of an ASHP COP.
Yes the wind is calmer at 5.30 in the morning....
Yes. But 2000? Plus wastage. Cutting them is only half the fun, stacking and cleaning and sorting and so on takes time. I once did 3 radial steps and cut each face of a brick to make 400 wedges using a water bench....
