Everything posted by ProDave
I am still not quite understanding what last minute changes the electrician had to make due to the change of oven spec. If it had been wired from the start with a dedicated radial for each oven, and one changed from 13A to 16A then all that needed changing was to replace the unswitched 13A socket behind the oven to a CCU to hard wire the 16A one, and perhaps change a 13A switched FCU on the wall to a 20A DP switch. There is more to this than I am understanding......
Think of where you might need some in the future? e.g foundations for a ramp to the front door? always handy to have a prepared space to pour any spare.
If you like it then you should have put a roof on it
ProDave commented on Crofter's blog entry in Wee Hoose on the Croft
I can see the headline. "Skye man decapitated by roofing sheet that came unhooked" You deserve a beer (I think I need a beer after reading that) A roof ladder would be safer than a rope and a sling. Reminds me of my "put a ladder down a well and climb down" episode and how I was told off afterwards about how dangerous that was (not to mention the extension lead and electric drill I took with me) -
When I talk about "services" I mean electrical wiring and plumbing? You have no "service void" for cables. As the CLT is your finished surface, you have to VERY early on decide where EVERY switch and socket is going and cut the holes. Then where do you run the cables? not in the insulated wall otherwise derating will apply and a lot of over sized cables. You could (this is what the house I saw did) run them out in conduit to (almost) the outside skin of the house to avoid derating (questionable as the bit to get through the wall probably still needs derating) Then what if you change your mind, want an extra socket, want something moved? an almost "unmodifiable" installation. That needs some serious thinking about (unless you really want the whole house wired in surface galv conduit) Don't under estimate the weight. The house I saw was a modular off site build and they were scratching their heads to find a hiab truck that could lift the sections. It was much heavier than any other construction method they had used before.
In present house we fitted the hall and the landing with their own UFH zones. Total waste of time and pipe. There is so little external wall to lose heat, and so much internal wall to gain heat from other rooms, that these never turn on.
Copied from the other thread, I was just thinking about the discharge pipe for my UVC which has to be installed before my floor goes down. So this is my planned run: It will emerge in the airing cupboard space at floor level, so plenty of room for the 400mm above and below the tundish. From the airing cupboard floor it will drop down inside an internal wall 2.5 metres, bend (in bender) run horizontally (with a slight fall) 1 metre, bend (in bender) 2 metre horizontally (again with a slight fall) which will take it out through the front wall. Bend (solder or compression) to turn it downwards where it will discharge into a French Drain. So if each bend counts as 1/2 a metre that makes a total of "8 metres" so it will be okay. And yes that will all be 28mm copper. I will need to question where and how it actually drains. The easiest would be to take it through under where the front door is, BUT that will get enclosed by the ramp up to the door, so I suspect BC won't like that as you won't be able to see the discharge point. So I guess I have to discharge it a bit to one side so it's visible? Also, will it be okay just discharging onto a lot of stones that make up a French Drain? If not I can put a gulley there and tell BC it goes to a soakaway (which it will as the back of the gulley will discharge to the French drain but underground)
Hi and welcome. I to am interested in the CLT frame (I think that CLT sub forum is needed PDQ) Is the CLT because you want the wood to be the finished internal wall surface? I saw one build like that, then clad in wood fibre board for insulation. To say the installation of the services was "challenging" would be an understatement.
The bit I want to know is HOW did you fix the last sheet on each side, with no nice roof to stand on, and no scaffold up the gable end? 45 degree steel roof panels are to steep and slippery to stand on? I fixed my "last sheet" standing on the scaffold. Also how are you going to fit the ridge piece? I sat astride the roof, shuffling along as I screwed it in. That would be a bit hairy without the satisfaction of some scaffold to catch you if you slipped off, and without scaffold to get on and off at the ends. Fair game for doing it all on your own. -
The new Amd 3 rules also cover "switchgear" enclosures. I am sure your box with timers would be classed as such. But of course you installed them before 1st December 2015 didn't you? Re UFH upstairs. fit a dummy thermostat on the wall, have your completion certificate done in summer, and nobody will ever know there is no upstairs UFH
IF there is no mains drainage available, then what you (or the seller) needs to do is perform a "percolation test". It's well documented in the building regs handbook. Basically you dig a 1 metre deep hole. In the bottom of that you dig a 300mm by 300mm hole 300mm deep. You fill that with water and time how long it takes for that water to drain away. That's a bit simplified but that's the general principle. From that, and the number of occupants that the house is designed for (a different figure to how many will actually be living in it), you calculate the area of leach field required. That can end up quite a large area. and there are restrictions how close the leach field can be to the boundary, buildings, the road, a watercourse etc which further limits available space. Then you need to see if that leaves enough space to actually build a house. If the ground is not suitable, e.g. if the water table is very high, then there are alternative above ground solutions such as a filter mound, or the Puraflow system that has tanks filled with peat above ground. We ran into this problem with our plot. we bought it and went through planning on the basis we could fit a filter mound system in. In the intervening time, building regs changed, and the distance from a road to the filter mound changed meaning we no longer had room for it. Eventually SEPA gave us permission to discharge to the burn, something they only do up here if there are no other options, and we had reached that point of having no other options that building control would accept.
Electric shower vs. instant water heater
ProDave replied to Crofter's topic in Bathrooms, Ensuites & Wetrooms
The reason I asked is I thought discharging (potentially) boiling water into PVC waste pipe was not allowed? There is an nhbc document around that details how you can use a waterless hepco trap and a particular type of plastic pipe (not pvc, I forget which) to discharge into a stack, but it must be a direct run to the stack in that particular type of pipe that can withstand boiling water. I am currently thinking about the plumbing for our UVC and to be honest the run to do that would be far too long, so I am now looking at dropping a copper pipe down inside the internal walls and out through the blockwork under the ground floor level.- 84 replies
- shower
- water heater
(and 3 more)
I changed a Hyco under sink electric water heater recently. that didn't have an expansion vessel nor a visible tundish. Likewise I wired a Quuker boiling water tap, one that sat upright under the sink unit, and again I saw no tundish. So if your had a prv and tindish, where did you drain it to?- 84 replies
- shower
- water heater
(and 3 more)
Yes that's meant for a static van with mains water. Have a serious look at the touring van storage water heaters that will work just from a 12V pump. For example https://www.truma.com/uk/en/water-systems/gas-electric-boiler.php Similar cost new the the Morco, but much better suited to your hut.
In our touring 'van the "limit" is about 25 litres of water for a shower. The trick is to turn the little storage water heater up to maximum (almost scalding hot) then dilute with plenty of cold, then you can have an acceptable shower before the hot water runs out (the limit being when the cold water tank runs dry) The Morco heater I am pretty sure is what we have in the static 'van and it's powerful enough to heat water instantly for a shower. They do use a lot of gas while running so tend to like the larger gas bottles. Here's the sort of caravan heater I am talking about http://www.ebay.co.uk/itm/caravan-water-heater-/172511488144?hash=item282a7c6890:g:KU8AAOSwnHZYknjQ
I fear you may have bought the "wrong" caravan heater. That's probably meant for a static 'van with mains water connection. You would be better off with a touring caravan unit. They tend to be storage heaters rather than instant heaters. All then need is a cold water container and a small 12V pump. Pump cold water in and it pushes the hot water out of the top. And the little 12V caravan pumps can manage to pump water from these to give a just about acceptable shower. Chances ar you could get one cheap or even free from a rotted out old touring 'van.
I can't say I have watched anything on channel 5 for a long time, it all seems "dumbed down" tv to me. I have fitted two sub £1K kitchens in our rental properties. howdens cheapest flat pack range but the results were surprisingly good (with the doors shut)
I think forks would have been a bit poor on my little digger that tended to be a bit jerky in some movements. But our builders had forks for their big machine, and also a long boom extension to use it as a crane with quite respectable reach, and that all seemed very smooth on a nice modern machine. Thinking about it, that was one delivery that needed unloading provision, the big beams for the roof. Big ridge beam lifted straight off the lorry and up onto the roof.
Find out if they are on pallets and is it an open truck? If so a digger with slings will lift them (headroom hay be an issue e.g for a curtain sider)
Just about every farmer has access to a telehandler. do you know any farmers? You can get forks for a digger. Not perfect but may be handy.
This is a review of procedure, costs, should someone other than council BC be allowed to do it etc. It's not about any proposed changes to the building regs. I think my comments would be the costs are too high, and can we have a "building notice" system (rather than full plans approval that we have) for simple jobs, like England and Wales have.
We used Protect VP400 on the advice of the builder. That's on top of my wood fibre sarking so needed to be non tenting, and they chose a good one as they knew it might be a while before the tiles went on.
We were lucky with the windows. Originally we were told it was Rationel's own wagon delivering them, and that had no offload facilities (hence the builders being ready to fetch the telehandler) but as it happened they split the load in Cumbernauld and ours came up by a local haulier on a truck with a hiab.
What materials are you talking about? I can't think of anything I have had delivered that had any particular issue. Timber, blocks, tiles, insulation, even the doors and windows all came on lorries equipped to unload, with either a hiab, or in the case of the insulation on pallets, one of those trucks that carried a fork lift truck around on the back. (we were warned with the windows to provide unloading facilities, and had the builder on hand to provide a teleporter if needed but the truck turned up with a hiab so not needed) And I never needed to use my digger as a crane for any of it.
