ProDave
    427
Everything posted by ProDave
  1. Looking at your plot layout in your other thread. http://forum.buildhub.org.uk/ipb/uploads/monthly_2017_02/Concrete.jpg.19ae38850212e87cce0c54671b07f7df.jpg and Even if you can get around the back with the dumper, it would repeatedly be going over the same narrow strip of ground that would turn to soup in no time. And you will never reach the inner sections of the pour. As others say, get a concrete pump, or someone with a decent sized digger with a large bucket and long reach (long enough to reach the back of the house while sitting at the front 65m3 sounds a lot. Is it a particularly large house or are you doing a deep trench fill?
  2. I was given several bags of rockwool offcuts. Most of them were used in the garage ceiling to stuff in between the webs of the posijoists (and normal frametherm in between the joists) I had some left over so used it as the first layer in that bit of the floor for no other reason than using them up.
  3. Finally the correct fitting arrived and I got this finished. Floor going down, never to be seen again (I hope)
  4. I have looked at this for my house. I only need the "Fascia A" profile with no soffit, to over clad my wooden fascia. I don't see how installation of this differs in any way from any other sheet cladding system?
  5. All good stuff. I didn't know the glaciers were that far south (I don't suppose many people talk of you being in the south do they) Glacial boulders are everywhere here. Did they let you have a go driving it? In essence it;s just a slightly modified digger (take off the bucket, replace with a vibro rod)
  6. ProDave
    Micro Homes
    Mixed feelings on this one. Our static caravan is 28 square metres and into that fits a living room / kichen / dining room, 2 bedrooms, a WC and a shower room. That layout would not pass building regs for a "house" because it would not meet any of the "accessability" rules that force a certain amount of space in front of showers, toilets, kitchen "circulation" space, corridor widths, even space needed next to a bed. I found all these accessability rules very restricting on what you can do when designing our new house. Wider stairs and provision to fit a stair lift in the future, leaving space and provision to fit a downstairs shower etc. So to get a more compact house it's building regs that have to change, not planning law. I guess most people who would like to make smaller homes are builders wanting to make smaller apartments so they can get more into a block? If a self builder wanted to make a particularly small detached house, then he can do so already by building a "portable building" and be exempt from building regs (as it's classed as a "caravan" in law so exempt from BR)
  7. I am not sure what your first floor make up will be, but you your electrician may curse the fact there are no holes in any of those steel to feed cables through.
  8. My long extension lead is made of 2.5mm 5 core YY. It was a work of art getting two 2.5mm into the L and N terminals of the plug.
  9. The annual desludge is something most treatment plants (and septic tanks) need. It's a man in a tanker with a big suction hose to suck the contents out. Costs us about £150 every two years. The one I looked at on Friday wasn't belt drive but a very lose coupled gear system. It looked like the motor and gearbox unbolted as one unit, but it looked a long reach over a stinking pond. At the very least I would want to put a few scaffold boards over it so you could lay on those above it to work from.
  10. The best I have seen for the Tescon Venna was about £20 a roll from someone on ebay from Ireland, but the postage to the UK was expensive. so 5 rolls free of postage at that price sounds good. I am almost certainly going to buy the Protect Barriair membrane which is very similar to the non reinforced Intello, which Jewsons have quoted me £99 per roll which is still cheaper than that site.
  11. That looks like good prices. How much do you have to spend to get free shipping to the UK?
  12. I'm not sure I understand this "slot" in the back of the oven housing? Just about every oven I have ever seen is way to deep to allow the housing to have a back panel. Sure some are supplied with a back panel, but you almost always have to remove it to allow enough depth for the oven. You can probably allow the back panel to remain behind the microwaver shelf as they are not so deep. so all you needed was to get the cable exiting the wall somewhere behind the oven housing, and chose the final location of the socket or CCU once it's ready to put the oven in, then using a plasterboard fast fix box which personally I much prefer for this type of install.
  13. I can't see anyone complaining if they take a long time to add a new property to the list and so don't charge you council tax straight away.
  14. The main difference is simply the way they work. With an UVC you can set it to say 45 degrees, and it will produce hot water at very close to 45 degrees until it is all used up then it will very quickly go cold. So in practice, the stored water temperature only needs to be slightly higher than the water temperature you want. But with a thermal store you are not drawing the water that is in it, instead you pass cold water through a coli (or sometimes a plate heat exchanger) so as you run the hot tap, you are extracting energy fairly evenly from the WHOLE tank so the temerature in the tank starts to drop. So in order to get a decent amount of water at your chosen 45 degrees, the stored water temerature needs to be a LOT higher. That poses two issues, higher standing losses, and not so good to be heated by a heat pump which woks best at lower temperatures.
  15. I have been using the Tescon Vanna tape, the standard one on a 60mm wide roll. I need to buy some more so I too am interested in cheapest place to buy this stuff and similar alternatives. The only alternative I have experience of is the Sega tapes but they are even more expensive than the Tescon.
  16. My case is slghtly different. When the new house is finally finished then I don't think there will be a problem of being charged CT on the caravan. We have a planning condition stating it cannot be used for habitation after the house is complete and it will become a garden outbuilding so I would argue to the highest court in the land I am not paying council tax for something I am not allowed to live in. My concern is if we rent out our old house for a period and move into the caravan and start paying council tax on that. Then later move back into the old house and try again to sell it, I can see no way to stop paying CT on the static caravan until the new house is completed.
  17. the usual idea would have been two two 20A DP switches where your 13A sockets are to the LEFT of the oven unit, feeding two 13A sockets behind the actual oven space. Usually the oven space does not have a back panel on it, so the sockets would have just been set into the wall behind the oven. I don't see why you could not have converted the original layout to that and because of the rating of the oven and it's supplied cable, fit a CCU instead of a 13A socket behind the oven space. You have plasterboard walls and a service void so should have been able to fish a cable that short distance. Often space is limited behind an oven, and you never know until you get the oven where the socket will fit, so in practice I tend to leave a long length of cable and not actually fit the socket (or ccu) until I have the oven and can work out where it can go. A lot of the confusion was the fact you initially described the two radial circuits as "spurs"
  18. VP400 plus, though I don't know what the difference is.
  19. That's useful to know. I am agonising over an even trickier one. We are considering renting our house out and moving in to the static van on our building site. So far so good. But if we do that, then later we will stop renting it and try again to sell it. I can't see a way to "unband" the static caravan on our plot short of physically removing it (or taking the windows out!!!!)
  20. I'm pretty sure our SE specified RC30 for our strip foundations
  21. It's more fundamental than that. My car unlocks and turns the alarm off when I PRESS THE BUTTON on the key fob. It's the doing away with that one simple operation, and making the key and car sense each other without intervention, that has allowed this amplifier trick to work.
  22. That is a valid point. we were only offered a "12KVA supply", which is a bit low for a normal domestic house, but that was on the basis of there being 8 houses now sharing one 100KVA transformer, and I know if we pushed for a bigger supply, there would have been a cost implication to upgrade that transformer. The reality is we get exactly the same supply as anyone else,same size cable, 100A fuse, so we could draw 24KVA from it without problem, but if everyone did that at the same time there would be a problem.
  23. Beware if buying cheap. LOOK at the spec. I bought a cheap "8KVA" generator out of the back of a van (don't ask). It was petrol, and 3 phase. Now when you actually read the spec, that 8KVA was "peak" and it was only 6KVA continuous, but being 3 phase, it meant it would only power a 2KVA single phase load. It would do three such loads, but there was no way it would power say a 4KVA single phase load. I sold it on ebay or gumtree, I forget which a week later for a small profit. I would talk to the builder and see about hiring a propane or kerosene heater, the sort garages use is what I am thinking. Re house building power consumption, I am up to the grand total so far of 65KWh used to build my house. I typically get a quarterly bill of about £3
  24. Mrs PD never had the slightest interest in having a go on the digger. Quick hitch MAKES fat digger drivers. Mine, you had to line it up and put the pins in. You soon learned to work the levers from outside the digger for that.
  25. I sold my digger.
