Everything posted by ProDave
Make sure the join lines up with something, e.g. the exact centre of a window bar. If we had had to have a join in the upstand it would have been exactly in the centre of and behind the tap, which is NOT at the mid position of the upstand.
Is that laminate flooring? If so I would be inclined to cut the laminate flooring and just install floor tiles straight onto the timber floor of the shed, there will be no or minimum step from the laminate to the tiles and so it will feel like the hearth is not intruding into the floor space.
Is this a sill or an upstand We had a granite upstand 2.6M by 15cm tall and 20mm thick. It took the stone company 2 goes to cut it, the first one snapped. They warned us if the second one snapped they would have to do it in 2 pieces. So I think you would be lucky to get 4M in one length. I was glad we had ours supply and fit, if it broke getting installed it would be their problem.
To be honest, if it's due for demolition, I would just do it, nobody is going to check or care. Alternatively, what do you plan to have in your new build? If you are going to have an unvented hot water cylinder, buy that now, and put it into the old house (you could even feed it from the header tank as a vented cylinder for now) .
As long as the electrician is doing "loop at switch" wiring, which is pretty normal these days, then all you need to decide right now is how many light circuits in each room, and then in your vaulted ceiling room just leave a long length of the switched light feed cable(s) ready to be positioned before the ceiling covering goes on, once you have decided what you want. Decision time is just before plasterboard or other ceiling covering goes on.
Pros and cons of upstands on worktops
ProDave replied to Adsibob's topic in Kitchen Units & Worktops
Squirt a 50% bleach 50% water mix in the gap, leave for a while, then rinse out with fresh water. It will be as clean as new. -
If rainwater started to pool on the solid cover, it would soon run along one way or the other to a slotted part of the drain and drain away. Who will be doing these surface water drain tests? I have never heard of that before.
P.S for anyone reading this thread, this was my completed wall complete with cylinders, and building control had no issues at the completion inspection:
Lift out the slotted drain cover under the cylinders and 2M either side and replace with something solid, even treated timber, sealed as you insert it, should do. e.g. I would start by looking at decking planks and see how close they are to the required width and could they be planed or sawn to the correct width to drop in?
I personally hate "plastered on the hard" brick walls and chasing cables into them. When I moved to Scotland, where the majority of houses are timber framed, my job became very much easier. I would suggest you consider lining your brick walls with 25 by 50mm battens vertically and fix plasterboard to that thus creating a service void for cables. You could even add an extra 25mm of insulation into this service void as long as you leave a strip clear for the cables. Your electrician who has probably never seen this and is used to bashing grooves in brick walls for cables will be enlightened and will want to move to Scotland for an easier more pleasant life.
Make sure ALL the outlets you need, power, aerial, telephone, network etc are on the wall behind where a wall hung tv will be. Think about set top boxes and surround sound etc, where will those go and how will you route cables to them? All the portable stuff most is wifi now so just provision for enough sockets to plug everything in. My favourite recommendation is run socket cables horizontally from socket to socket around the room. As long as there is 1 socket on each wall you have a safe zone all the way round so you can easily add extra sockets later if you find you need more.
That is too much like a piece of string. Kitchens vary enormously in size. Just about any budget kitchen retailer will offer you a set of kitchen units for under £1000 but it will not be the kitchen you want.
Is this connecting to mains sewage? the usual solution is just a holding chamber and a pump, sometimes 2 pumps for redundancy.
Heatrea sadia.....heating off but rads hot
ProDave replied to Dee's topic in Boilers & Hot Water Tanks
Context please. Is this a new system that has never worked properly, or it has previously worked perfectly but started to misbehave? The 2 switches on the tank are probably immersion heaters. If you are heating the hot water from the boiler these should both be off. Post a picture of the tank and the switches to confirm that. Also post any pictures of anything else related like motorised valves? -
Well done and that's a pretty impressive build cost.
Required window U value, just the glass?
ProDave replied to epsilonGreedy's topic in Windows & Glazing
Whole window Uw value will go into the SAP calculations and that will pass or fail building regs. Manufacturer should publish Uw values. -
My guess the G/Y earth was a later update. for me it's the screwits that date it.
Directional Vents (Diffusers)
ProDave replied to Barnacles's topic in Mechanical Ventilation with Heat Recovery (MVHR)
If you are feeling a draught from a standard ceiling vent, I might suggest that your system is not set up properly and you are running at too high flow rate. -
Is it this one? That is using a stone hearth, and metal sheets spaced off the wall for heat protection of the wall. That is something like you need to do. And twin wall flue all the way from the stove through the rood.
That would make my blood boil and be showing him the door. My parting comment would give me a best and final quote by post valid for at least 14 days and I will let you know.
That is OLD wiring probably 1960's. Conduit will be the earth, neutrals direct to lights looped light to light. Live direct to switches looped switch to switch and switched L from switch to light. The twisted connections are "Screwits" No idea what the extra cable added does. Honest opinion, your lights need rewiring, who know what the rest of the wiring is like.
I suspect the issue with concrete products is the energy needed to make concrete and rising energy costs.
You would only know that with a proper detailed heat loss room by room. This is the second house we have built, both with 200mm spaced UFH. The first one, 18 years ago was an "ordinary" timber framed house with 150mm insulation in the walls, 200mm under the floor and 300mm in the loft and there was no issue with cold rooms. Closer spacing does not create problems so no problem going closer just to be sure.
Heat pump vs gas, UFH vs rads?
ProDave replied to Greatescape's topic in Air Source Heat Pumps (ASHP)
It remains to be seen what is going happen to energy prices. While many are indeed predicting electricity at 30p per kWh, a 50% increase on what I thought was already a stupid high price, the same people are predicting gas may go up 100% We have no control over this, but you DO have control over the house you build and it is becoming more and more important to get at least close to passive house standards when you have the chance at a major renovation or rebuild.- 12 replies
- air source heat pump
- gas
(and 8 more)
Torque requirements for power and lighting switches?
ProDave replied to Ben100's topic in Power Circuits
If you relied on a torque measurement, then a lot of the recent MK sockets I have had the misfortune to install the wires would fall out, because the screw is such a lousy fit in it's thread that it is all you can do to turn it at all. (you might gather I never fit MK by choice these days)
