Oz07
Everything posted by Oz07
I've just had eon on the blower threatening to send debt collections for an amount owed. They will actually owe me money as they have the wrong readings but are disputing who has to raise the 'complaint' new supplier or themselves. I though Ofgem had only just allowed energy companies to chase debt and not aggressively. Will they have to secure a judgement against me before sending debt collectors or can they engage these companies without a judgement?
look into small claims court easy enough you will have to give 28 days notice by sending a letter before action. If no reply in that time then submit your claim online
Always feel more rattley to me when built to equivilant timber sections. You can also stagger a timber stud with 4x2 sole and top plate 3x2 studs. Also the amount of patrices or ply metal stud work Seems to need and lack of flexibility to nog out puts me off. It does have it's advantages too just have to compare your key criteria
Man and Machine hire estimates WOW!
Oz07 replied to Internet Know How's topic in Costing & Estimating
Apple's with Apple's? Sticking a guy in a machine and saying dig there is very different from a company doing a package to produce a desired result. -
Windows....which company did you choose and why?
Oz07 replied to Tom's Barn's topic in Windows & Glazing
What is the timber being used? What will be future maintenance requirements? -
And the best cure for this is ....
Oz07 replied to ToughButterCup's topic in General Self Build & DIY Discussion
Look what this idiot did the other day. Not my job I'm just there subbing. I mean the fact he uses chalk annoys me as opposed to laser, then the fact he can't see it's not running parallel with the wall. Worst bit is it wasn't even the apprentice. Client visited the 9ther day, apparently used to be in f1, is now into automation and he has an eye for detail. He going to be in for a world of pain when he moves in here. Asked me to quote to board his garage loft think I'll swerve that one thanks... -
Wait till it's finished and you have a glass bottle on a hard surface then you'll know.
Have you had any heat input into your house yet @joe90? Wood burner etc ? I've been using heating a couple of hours each night and it doesn't feel as warm in the morning as my last place I built to similar spec. This one has mvhr I can only assume it's not as efficient at retaining heat as advertised or is running too fast. Tbf the thermostat hasn't shown below 16/17 but I've set it to click off at 19 for the heating.
I reckon cost. The advantage of those screeds is their strength to thickness. I reckon once you get to 80mm your in self compacting concrete territory. For what it's worth how sure is everyone the bounce is in the screed to insulation movement? I would guess it's the actual suspended concrete floor beams which have a bit of bounce.
Concrete around 900 on your figures at 75mm depth (minimum), labour and pump budget 600 so 1500 plus VAT there's not much in it. I prefer the concrete as can get down before watertight and a nice finish floor to work from. Although it depends where in the world you are @Russell griffiths struggled to get reasonable prices locally. I believe @PeterStarck 's second bit at the cherry was self compacting although his contractor might have paid for it?!
Concrete pump will add about 300 depending on where you are and how much. You will also have to pay someone to lay they rake, tamp and spray it off not the most difficult but still worth paying someone who works with it regularly. If you allowed a day at 200/250. There are companies that pump and lay (and will quote your supply) also keeping it all in house.
@Moonshine what make a you think that new build was a screed. I suspect it was a self compacting concrete like I use on mine. It's pretty bomb proof, no serious laitence but not the cheapest getting on for about 150 a m3 nowadays
Mdf won't warp if fitted properly. Suspect Dave means proper timber
Was it worth those barriers!? Looking good apart from that
Think people have done it with soil pipe and vent caps or some other fitting before
I don't think deducting the original blokes invoice will wind up the OP, more likely the other way round. I doubt he will have the front to challenge OP. For one he has let him down for two the work wasn't right
What can be done before water tight stage?
Oz07 replied to Conor's topic in General Construction Issues
Wouldn't be the first job been first fixed without Windows. Even timber partitions. You put sole plate on dpc any way. Couldn't you nail up some transparent polythene over the holes -
A reminder of the risks of diggers…
Oz07 replied to Dreadnaught's topic in Project & Site Management
If you pay attention the green beacon keeps flashing when some operators get out. They know the tricks -
Leave howdens 4 weeks, they will call you, tell them your ready to place order half price and your not playing their silly games of sending competitor quotes. They will drop their price, at this point I usually still go with someone else just to discourage this business model.
Have trusses ever been at 400 centres or are you referring to rafters? I bet it's more common than you think people using 19mm batten with 60p centre spacing which would likely cause a roof to look bumpy.
I find 22mm about right. Even that can catch with thick underlay
Wasn't specifically talking about that case, just in general. I've never really met a window fitter who takes pride in their work. Seems to be a rough trade then you get the firms expert come to fix up or adjust any issues. -
@craig is there not an industry standard fitting guide a bit like the one BWF produces for stairs. It's very generic but covers most essentials. I'm sure most carpenters would be capable of fitting these Windows if they knew the exact specifications/details. Always seems to be a lottery with window fitters whereas if the customer has a chippie they trust I'm sure they could manage. Neck I even think @Russell griffiths even fitted his own And he's a rough arse tree surgeon. -
Just do your roof if you want a chance of passing ?
I got offered £12 m2 as a goodwill gesture for replacing some faulty click LVT. I'd guess more though I bet people want 30 quid
